Error when installing Intel RDK
whung6
I have a error when I install Intel RDK, when I ran the command
$ ./rdk.sh install-deps
from https://intel.github.io/robot_devkit_doc/pages/install.html, it gave me an error of this
seems that I have a problem with my InferenceEngine and TargetDevice.
By the way, I had openvino v2020.2 installed already, will the packages of v2020.2 conflict with the command I ran?
RandallMan_B_Intel
Hi whung6,
Thanks for reaching out.
It could be that OpenVINO is present, you can try to uninstall OpenVINO, and follow the guide again.
If you continue to have issues, please submit your question here: https://github.com/intel/robot_devkit/issues.
Randall B.
whung6
Thanks for the reply, instead of uninstalling openvino v2020.2, I had successfully install Intel RDK in a docker container, so I guest that there's a conflict between openvino from my local and from the command script.
Soon as I move to work in docker, everything works fine.
RandallMan_B_Intel
Thanks for your reply. I'm glad to hear your problem is resolved.
Randall B.
