Error while converting frozen graph to IR
SSong16
Hello everyone, I am working on the Movidius Neural Compute Stick 2 with OpenVino Toolkit. The model I am using is Faster R-CNN Inception V2 COCO. I have retrained the model to detect 4 classes of my own and exported and freeze the inference graph. However, when I'm trying to convert the frozen inference graph to IR in OpenVino, I have encountered the following error:
Model Optimizer arguments:
Common parameters:
    - Path to the Input Model:     /home/vudthi/inference_graph/frozen_inference_graph.pb
    - Path for generated IR:     /opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/.
    - IR output name:     frozen_inference_graph
    - Log level:     ERROR
    - Batch:     Not specified, inherited from the model
    - Input layers:     image_tensor
    - Output layers:     Not specified, inherited from the model
    - Input shapes:     [1,224,224,3]
    - Mean values:     Not specified
    - Scale values:     Not specified
    - Scale factor:     Not specified
    - Precision of IR:     FP32
    - Enable fusing:     True
    - Enable grouped convolutions fusing:     True
    - Move mean values to preprocess section:     False
    - Reverse input channels:     False
TensorFlow specific parameters:
    - Input model in text protobuf format:     False
    - Offload unsupported operations:     False
    - Path to model dump for TensorBoard:     None
    - List of shared libraries with TensorFlow custom layers implementation:     None
    - Update the configuration file with input/output node names:     None
    - Use configuration file used to generate the model with Object Detection API:     None
    - Operations to offload:     None
    - Patterns to offload:     None
    - Use the config file:     None
Model Optimizer version:     1.5.12.49d067a0
/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/ops/slice.py:111: FutureWarning: Using a non-tuple sequence for multidimensional indexing is deprecated; use `arr[tuple(seq)]` instead of `arr[seq]`. In the future this will be interpreted as an array index, `arr[np.array(seq)]`, which will result either in an error or a different result.
  value = value[slice_idx]
[ ERROR ]  Cannot infer shapes or values for node "Preprocessor/map/while/ResizeToRange/Round_3".
[ ERROR ]  Input 0 of node Preprocessor/map/while/ResizeToRange/Round_3 was passed double from Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder:0 incompatible with expected float.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x7f5f4e74b268>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.
[ ERROR ]  Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_3" node.
My script looks something like this: sudo python3 mo_tf.py --input_model <dir>/frozen_inference_graph.pb --input_shape [1,224,224,3] --input image_tensor --data_type FP32
I've seen similar problem on the forum and I tried their solution also, but it didn't work for me. Hoping to find the solution! Thanks
Shubha_R_Intel
Dear Sokha Vudthi, please use --log_level DEBUG in your Model Optimizer command and paste the ERROR part here.  I can help you if I see the detailed error.
Thanks !
Shubha
SSong16
Dear Shubha R., I've added --log_level=DEBUG and the following are the ERROR part:
[ ERROR ]  Cannot infer shapes or values for node "Preprocessor/map/while/ResizeToRange/Round_1".
[ ERROR ]  Input 0 of node Preprocessor/map/while/ResizeToRange/Round_1 was passed double from Preprocessor/map/while/ResizeToRange/mul_1_port_0_ie_placeholder:0 incompatible with expected float.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x7f166918e268>.
[ 2019-03-25 13:47:20,750 ] [ DEBUG ] [ infer:215 ]  Node "Preprocessor/map/while/ResizeToRange/Round_1" attributes: {'precision': 'FP32', 'dim_attrs': ['axis', 'batch_dims', 'channel_dims', 'spatial_dims'], 'is_output_reachable': True, 'is_undead': False, 'IE': [('layer', [('id', <function update_ie_fields.<locals>.<lambda> at 0x7f1667290ea0>), 'name', 'precision', 'type'], [('data', ['auto_pad', 'epsilon', 'min', 'max', ('axis', <function update_ie_fields.<locals>.<lambda> at 0x7f1667290f28>), 'tiles', ('dim', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291048>), 'num_axes', ('pool-method', 'pool_method'), 'group', ('rounding-type', 'rounding_type'), ('exclude-pad', 'exclude_pad'), 'operation', 'out-size', 'power', 'shift', 'alpha', 'beta', 'coords', 'classes', 'num', ('local-size', 'local_size'), 'region', 'knorm', 'num_classes', 'keep_top_k', 'variance_encoded_in_target', 'code_type', 'share_location', 'nms_threshold', 'confidence_threshold', 'background_label_id', 'top_k', 'eta', 'visualize', 'visualize_threshold', 'save_file', 'output_directory', 'output_name_prefix', 'output_format', 'label_map_file', 'name_size_file', 'num_test_image', 'prob', 'resize_mode', 'height', 'width', 'height_scale', 'width_scale', 'pad_mode', 'pad_value', 'interp_mode', 'img_size', 'img_h', 'img_w', 'step', 'step_h', 'step_w', ('offset', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291158>), 'variance', 'flip', 'clip', ('min_size', <function update_ie_fields.<locals>.<lambda> at 0x7f16672910d0>), ('max_size', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291268>), ('aspect_ratio', <function update_ie_fields.<locals>.<lambda> at 0x7f16672911e0>), 'decrease_label_id', 'normalized', 'scale_all_sizes', ('type', 'norm_type'), 'eps', 'across_spatial', 'channel_shared', 'negative_slope', 'engine', 'num_filter', ('type', 'sample_type'), ('order', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291378>), 'pooled_h', 'pooled_w', 'spatial_scale', 'cls_threshold', 'max_num_proposals', 'iou_threshold', 'min_bbox_size', 'feat_stride', 'pre_nms_topn', 'post_nms_topn', ('type', <function update_ie_fields.<locals>.<lambda> at 0x7f16672912f0>), ('value', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291400>), ('output', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291488>), ('input_nodes_names', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291510>), ('output_tensors_names', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291598>), ('real_input_dims', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291620>), ('protobuf', <function update_ie_fields.<locals>.<lambda> at 0x7f16672916a8>), {'custom_attributes': None}, ('strides', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291730>), ('kernel', <function update_ie_fields.<locals>.<lambda> at 0x7f16672917b8>), ('dilations', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291840>), ('pads_begin', <function update_ie_fields.<locals>.<lambda> at 0x7f16672918c8>), ('pads_end', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291950>), ('scale', <function update_ie_fields.<locals>.<lambda> at 0x7f16672919d8>), 'crop_width', 'crop_height', 'write_augmented', 'max_multiplier', 'augment_during_test', 'recompute_mean', 'write_mean', 'mean_per_pixel', 'mode', 'bottomwidth', 'bottomheight', 'chromatic_eigvec', 'kernel_size', 'max_displacement', 'stride_1', 'stride_2', 'single_direction', 'do_abs', 'correlation_type', 'antialias', 'resample_type', 'factor', 'coeff', ('ratio', <function update_ie_fields.<locals>.<lambda> at 0x7f1667291a60>)], []), '@ports', '@consts'])], 'kind': 'op', 'is_const_producer': False, 'is_partial_inferred': False, 'infer': <function tf_native_tf_node_infer at 0x7f166918e268>, 'pb': name: "Preprocessor/map/while/ResizeToRange/Round_1"
op: "Round"
input: "Preprocessor/map/while/ResizeToRange/mul_1_port_0_ie_placeholder"
attr {
  key: "T"
  value {
    type: DT_FLOAT
, 'shape_attrs': ['window', 'pad', 'shape', 'output_shape', 'stride'], 'name': 'Preprocessor/map/while/ResizeToRange/Round_1', 'op': 'Round'}
[ ERROR ]  Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_1" node.
 For more information please refer to Model Optimizer FAQ (<INSTALL_DIR>/deployment_tools/documentation/docs/MO_FAQ.html), question #38.
[ 2019-03-25 13:47:20,751 ] [ DEBUG ] [ main:331 ]  Traceback (most recent call last):
  File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/importer.py", line 426, in import_graph_def
    graph._c_graph, serialized, options)  # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: Input 0 of node Preprocessor/map/while/ResizeToRange/Round_1 was passed double from Preprocessor/map/while/ResizeToRange/mul_1_port_0_ie_placeholder:0 incompatible with expected float.
During handling of the above exception, another exception occurred:
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/middle/passes/infer.py", line 153, in partial_infer
    node.infer(node)
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/front/tf/partial_infer/tf.py", line 60, in tf_native_tf_node_infer
    tf_subgraph_infer(tmp_node)
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/front/tf/partial_infer/tf.py", line 135, in tf_subgraph_infer
    all_constants, output_tensors = get_subgraph_output_tensors(node)
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/front/tf/partial_infer/tf.py", line 115, in get_subgraph_output_tensors
    tf.import_graph_def(graph_def, name='')
  File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/deprecation.py", line 507, in new_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/importer.py", line 430, in import_graph_def
    raise ValueError(str(e))
ValueError: Input 0 of node Preprocessor/map/while/ResizeToRange/Round_1 was passed double from Preprocessor/map/while/ResizeToRange/mul_1_port_0_ie_placeholder:0 incompatible with expected float.
The above exception was the direct cause of the following exception:
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/main.py", line 325, in main
    return driver(argv)
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/main.py", line 267, in driver
    mean_scale_values=mean_scale)
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 256, in tf2nx
    partial_infer(graph)
  File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/middle/passes/infer.py", line 217, in partial_infer
    refer_to_faq_msg(38)) from err
mo.utils.error.Error: Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_1" node.
Thanks for the help!
Sokha Vudthi
Shubha_R_Intel
Dear Sokha:
Please give me the exact link from where you downloaded Faster R-CNN Inception V2 COCO.
We do support Faster R-CNN, please check this list for supported topologies. We supply the exact tar.gz which you should download. Did you try one of these ?
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
Shubha
SSong16
Dear Shubha,
I downloaded the pre-trained model from the TensorFlow model zoo. The following is the link to their github repository:
https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/detection_model_zoo.md
I haven't tried the ones from the openvinotoolkit website yet since I trained my model a few months back before I found out about Intel Movidius Neural Compute Stick.
I will download the exact tar.gz from openvino website, will try to convert it again and see how it goes.
Thanks!
Vudthi
SSong16
Dear Shubha,
I've downloaded the model from openvino website and tried to convert it again but it still shows the same error.
I've also tried a few other topologies also but all of them seem to output the same error as the previous one.
Vudthi
Mikhail_T_Intel
For proper conversion of Tensorflow Object Detection API models you usually have to specify two additional comand line options
  --tensorflow_use_custom_operations_config $MO_ROOT/extensions/front/tf/faster_rcnn_support.json for models frozen with TF version < 1.7; faster_rcnn_support_api_v1.7.json for TF version from 1.7 to 1.10 and faster_rcnn_support_api_v1.10.json for TF version starting from 1.10
--tensorflow_object_detection_api_pipeline_config pipeline.config The pipeline.config file is provided along with the models from Tensorflow detection model zoo.
Here is more detailed explanation about how MO works with Faster R-CNN TF models, and the paper about the general approach to the models created using the TensorFlow Object Detection API
om77
Just to add my 5 cents here...
frozen_inference_graph.pb should be obtained using tensorflow version <= 1.12 since the last tensorflow (e.g. 1.13.1) is not supported by openvino R5.
SSong16
Dear Mikhail, om77, and Shubha,
I have successfully converted the frozen inference graph into IR now after adding the custom operation config file.
Thank you very much for all the helps!
Vudthi
Shubha_R_Intel
Dear Sokha Vudthi,
congrats and thanks for using OpenVino !
Shubha
