6594 Discussions
Error with Clamp function while converting ONNX model to OpenVino IR
Sharma__Divyanshu
Hi!
I'm trying to convert an ONNX representation of the PMTD model, but I've run into an error:
AssertionError: Clamp should have exactly three inputs, but it has 2
The ONNX model seems to work fine, and I've supplied the correct input shape as the input_shape argument.
I would appreciate any help. Thanks!
Sharma__Divyanshu
Hi @Munesh_Intel
Thank you so much for replying. I figured it out. Turns out that either min or max in PyTorch's clamp function is optional. So, one of the two was missing in my code. I passed both the parameters and the error went away.
Thanks and Regards!
Munesh_Intel
Hi Divyanshu,
From what I can see, the node “Clip_678” has two inputs and lacking one more input. The clamp function expects three inputs instead.
More information is available at the following page:
https://docs.openvinotoolkit.org/2020.4/openvino_docs_ops_activation_Clamp_1.html
Also, Pyramid Mask Text Detector (PMTD) is not supported officially by OpenVINO.
However, you can try validating on your end.
Alternatively, I would also suggest you try inferencing using the function InferenceEngine::Core::ReadNetwork to read ONNX models via the Inference Engine Core API.
(For your information, Inference Engine enables reading ONNX models via the Inference Engine Core API since OpenVINO™ 2020.4 version)
https://docs.openvinotoolkit.org/2020.4/classInferenceEngine_1_1Core.html#ac716dda382aefd09264b60ea4...
Munesh.
Sharma__Divyanshu
Hi @Munesh_Intel
Thanks and Regards!
Munesh_Intel
Hi Divyanshu,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Munesh
