6605 Discussions
Error with 'make examples' with ncsdk 2.08.01.02
Hi , for V2 (NCSDK-2.08.01.02) I get the below error on make examples. V1 installs and makes examples fine, and I can run examples with positive results
mark@mark-X58A-UD3R:~/Documents/ncsdk$ make examples ./install-opencv.sh OpenCV Installation Starting Reading installer configuration variables from ./ncsdk.conf Installing opencv python for non-Raspbian Collecting opencv-python>=3.4.0.12 Using cached https://files.pythonhosted.org/packages/8c/5a/51fbacac6cf508016916c96393405e2e10d939859322a6dcf7a92e041d0d/opencv_python-3.4.3.18-cp35-cp35m-manylinux1_x86_64.whl Requirement already satisfied (use --upgrade to upgrade): numpy>=1.11.1 in /usr/local/lib/python3.5/dist-packages (from opencv-python>=3.4.0.12) Installing collected packages: opencv-python Successfully installed opencv-python-3.4.3.18 You are using pip version 8.1.1, however version 18.1 is available. You should consider upgrading via the 'pip install --upgrade pip' command. Collecting opencv-contrib-python>=3.4.0.12 Using cached https://files.pythonhosted.org/packages/83/ad/2048145a7c2f187a8f41a074e11986cf885fb6ebcf7ee4a2297003249cde/opencv_contrib_python-3.4.3.18-cp35-cp35m-manylinux1_x86_64.whl Requirement already satisfied (use --upgrade to upgrade): numpy>=1.11.1 in /usr/local/lib/python3.5/dist-packages (from opencv-contrib-python>=3.4.0.12) Installing collected packages: opencv-contrib-python Successfully installed opencv-contrib-python-3.4.3.18 You are using pip version 8.1.1, however version 18.1 is available. You should consider upgrading via the 'pip install --upgrade pip' command. Collecting opencv-python>=3.4.0.12 Using cached https://files.pythonhosted.org/packages/51/3d/9b10d7159e10ac87bd6c1b403dbc72b1240e18da51f9d56f50bb06f75d15/opencv_python-3.4.3.18-cp27-cp27mu-manylinux1_x86_64.whl Requirement already satisfied (use --upgrade to upgrade): numpy>=1.11.1 in /usr/local/lib/python2.7/dist-packages (from opencv-python>=3.4.0.12) Installing collected packages: opencv-python Successfully installed opencv-python-3.4.3.18 You are using pip version 8.1.1, however version 18.1 is available. You should consider upgrading via the 'pip install --upgrade pip' command. Collecting opencv-contrib-python>=3.4.0.12 Using cached https://files.pythonhosted.org/packages/b6/fa/c044b049bf88793910552c116f65aeb7d4adde5d1366f52dee56faef31dd/opencv_contrib_python-3.4.3.18-cp27-cp27mu-manylinux1_x86_64.whl Requirement already satisfied (use --upgrade to upgrade): numpy>=1.11.1 in /usr/local/lib/python2.7/dist-packages (from opencv-contrib-python>=3.4.0.12) Installing collected packages: opencv-contrib-python Successfully installed opencv-contrib-python-3.4.3.18 You are using pip version 8.1.1, however version 18.1 is available. You should consider upgrading via the 'pip install --upgrade pip' command. OpenCV Installation Finished make examples starting. (cd examples; make) make[1]: Entering directory '/home/mark/Documents/ncsdk/examples' make -C apps/. ............content removed to reduce size---------------------------- make[5]: Leaving directory '/home/mark/Documents/ncsdk/examples/data/ilsvrc12' making prototxt Downloading Prototxt file --2018-10-10 10:26:36-- https://raw.githubusercontent.com/BVLC/caffe/master/models/bvlc_googlenet/deploy.prototxt Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.96.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.96.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 35862 (35K) [text/plain] Saving to: './deploy.prototxt’ deploy.prototxt 100%[=====================================================================================================>] 35.02K --.-KB/s in 0.02s 2018-10-10 10:26:37 (2.05 MB/s) - './deploy.prototxt’ saved [35862/35862] Adding input shape to prototxt file. making caffemodel Downloading caffemodel file --2018-10-10 10:26:37-- http://dl.caffe.berkeleyvision.org/bvlc_googlenet.caffemodel Resolving dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)... 169.229.222.251 Connecting to dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)|169.229.222.251|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 53533754 (51M) [application/octet-stream] Saving to: './bvlc_googlenet.caffemodel’ bvlc_googlenet.caffemodel 100%[=====================================================================================================>] 51.05M 847KB/s in 68s 2018-10-10 10:27:45 (767 KB/s) - './bvlc_googlenet.caffemodel’ saved [53533754/53533754] making compile mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt Makefile:80: recipe for target 'compile' failed make[4]: *** [compile] Illegal instruction (core dumped) make[4]: Leaving directory '/home/mark/Documents/ncsdk/examples/caffe/GoogLeNet' cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory Makefile:9: recipe for target 'googlenet' failed make[3]: *** [googlenet] Error 1 make[3]: Leaving directory '/home/mark/Documents/ncsdk/examples/apps/multistick_cpp' Makefile:13: recipe for target 'multistick_cpp/.' failed make[2]: *** [multistick_cpp/.] Error 2 make[2]: Leaving directory '/home/mark/Documents/ncsdk/examples/apps' Makefile:12: recipe for target 'apps/.' failed make[1]: *** [apps/.] Error 2 make[1]: Leaving directory '/home/mark/Documents/ncsdk/examples' Makefile:57: recipe for target 'examples' failed make: *** [examples] Error 2
Appreciate your help,
Mark
Some additional information.
This is a clean build for testing running Ubuntu 16.04.5.
Communications with the device appear to be working fine.
mark@mark-X58A-UD3R:~/Documents/ncsdk/examples/apps/hello_ncs_py$ python hello_ncs.py D.: [ 0] ncDeviceCreate:308 ncDeviceCreate index 0 D.: [ 0] ncDeviceCreate:308 ncDeviceCreate index 1 D.: [ 0] ncDeviceOpen:524 File path /usr/local/lib/mvnc/MvNCAPI-ma2450.mvcmd I: [ 0] ncDeviceOpen:530 ncDeviceOpen() XLinkBootRemote returned success 0 I: [ 0] ncDeviceOpen:568 XLinkConnect done - link Id 0 D.: [ 0] ncDeviceOpen:582 done I: [ 0] ncDeviceOpen:584 Booted 1-ma2450 -> VSC I: [ 0] getDevAttributes:383 Device attributes I: [ 0] getDevAttributes:386 Device FW version: 2.8.2450.16e I: [ 0] getDevAttributes:388 mvTensorVersion 2.8 I: [ 0] getDevAttributes:389 Maximum graphs: 10 I: [ 0] getDevAttributes:390 Maximum fifos: 20 I: [ 0] getDevAttributes:392 Maximum graph option class: 1 I: [ 0] getDevAttributes:394 Maximum device option class: 1 I: [ 0] getDevAttributes:395 Device memory capacity: 522059056 Hello NCS! Device opened normally. I: [ 0] ncDeviceClose:776 closing device Goodbye NCS! Device closed normally. NCS device working.
Update - Still working through what issue may be, but…
If I uninstall tensorflow (1.10 in requirements) and install 1.5.
pip3 uninstall tensorflow pip3 install tensorflow==1.5
I can 'make example' and run all examples.
I think for the issue that I am having, it is solved. (At least as best it will be till I do hardware upgrade)
From Tensorflow site "Note: Starting with TensorFlow 1.6, binaries use AVX instructions which may not run on older CPUs."
I identify this with the below commands on the two machines I have (One works with tensorflow 1.10 and the other only with 1.5)
Older machine with 1.5 only support. (no support for AVX)
mark@mark-X58A-UD3R:~/Downloads/tensorflow$ cat /proc/cpuinfo | grep avx
mark@mark-X58A-UD3R:~/Downloads/tensorflow$ cat /proc/cpuinfo | grep flags
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid dtherm ida flush_l1d
Newer machine with latest support.(see avx and avx2)
mtegg@ubuntu:~$ cat /proc/cpuinfo | grep avx
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid xsaveopt dtherm ida arat pln pts flush_l1d
