6594 Discussions
Exception: Exception occurred during running replacer "REPLACEMENT_ID model conversion
MCC
I have issues while converting  a custom PB frozen model . Other custom models were work, but this one got some errors.
Below is my environment:
OS: Both Windows 10
Python Version : 3.6.8
TF version : 1.15.4
Openvino Version : openvino_2021.2.185
I am adding the log file here.
Rizal_Intel
Hi MCC,
You are receiving a lot of "Shape and content size of tensor don't match" warning.
You may need to specify the input size as it seems that the propagated size is not correct.
Rizal
MCC
Hi Rizal,
I provided  "--input" with "--input_shape" and "-b 1"   for mo.py, and both way got the same error.
MCC
MCC
Hi Rizal,
I fixed it. Just need to add "--static_shape".
MCC
Rizal_Intel
Hi MCC,
Congratulation on being able to fix it.
Can you share what is different compared to your other custom models for other readers that may encounter the same issue as you?
Is there anything else you would like to ask?
Rizal
MCC
Hi Rizal,
I guess the issue is kernel size between layers. For some reasons, this model did not use resnet like architecture.
MCC
Rizal_Intel
Hi MCC,
Thank you for the information.
Intel will no longer monitor this thread. If you need any additional information from Intel, please submit a new question.
Rizal
