6614 Discussions
Exception: mvncStatus.UNSUPPORTED_GRAPH_FILE
I've tried 'make run' in facenet but failed with Exception: mvncStatus.UNSUPPORTED_GRAPH_FILE
Makefile:144: recipe for target 'run' failed
make: *** [run] Error 1
Here is my error message after make run.
Hi @bigfoottt
Are you using the NCS1 or NCS2? What version of the NCSDK are you using?
Sahira
Thanks. I solved this issue.
I using NCS2 Compile TensorFlow model used in NCS1 example. So there was error.
Hi @bigfoottt
Glad to see your issue was resolved (:
Please let us know if you have any further questions!
Sahira
