6584 Discussions
Failed to compile visual studio project using OpenVino
Neves__João_Carlos
I created a new empty project using Visual Studio, and copied the code available in one of the samples provided in the Openvino.
Also, I copied from the sample the C++ include directories and linker directories.
Nevertheless, the project fails to compile due to the following error:
d:\openvinoproject\humandetection\humandetection\main.cpp(36): error C2512: 'InferenceEngine::PluginDispatcher': no appropriate default constructor available
issue in the following line:
PluginDispatcher P = PluginDispatcher({ "" });
Were someone able to create a project from scratch using openvino?
