6594 Discussions
Failed to create plugin /opt/intel/openvino_2020.2.120/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so
Sertkaya__Orhan
Firstly, I followed instructions here
I received an error while trying to run this command:
python3 /opt/intel/openvino_2020.2.120/deployment_tools/open_model_zoo/demos/python_demos/object_detection_demo_yolov3_async/object_detection_demo_yolov3_async.py -i sample.mp4 -m yolov3/frozen_darknet_yolov3_model.xml -d GPU
Output of the command:
[ INFO ] Creating Inference Engine...
[ INFO ] Loading network files:
    yolov3/frozen_darknet_yolov3_model.bin
/opt/intel/openvino_2020.2.120/deployment_tools/open_model_zoo/demos/python_demos/object_detection_demo_yolov3_async/object_detection_demo_yolov3_async.py:184: DeprecationWarning: Reading network using constructor is deprecated. Please, use IECore.read_network() method instead
  net = IENetwork(model=model_xml, weights=model_bin)
[ INFO ] Preparing inputs
[ INFO ] Loading model to the plugin
/usr/lib/python3/dist-packages/apport/report.py:13: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses
  import fnmatch, glob, traceback, errno, sys, atexit, locale, imp
Traceback (most recent call last):
  File "/opt/intel/openvino_2020.2.120/deployment_tools/open_model_zoo/demos/python_demos/object_detection_demo_yolov3_async/object_detection_demo_yolov3_async.py", line 362, in <module>
    sys.exit(main() or 0)
  File "/opt/intel/openvino_2020.2.120/deployment_tools/open_model_zoo/demos/python_demos/object_detection_demo_yolov3_async/object_detection_demo_yolov3_async.py", line 233, in main
    exec_net = ie.load_network(network=net, num_requests=2, device_name=args.device)
  File "ie_api.pyx", line 178, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 187, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Failed to create plugin /opt/intel/openvino_2020.2.120/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so for device GPU
Please, check your environment
[CLDNN ERROR]. No GPU device was found.
My CPU is Intel® Core™ i5-6600K
Processor Graphics: Intel® HD Graphics 530
According to my research, I think these are the GPUs currently supported. => supported-platforms
Is this why I'm getting an error?
SIRIGIRI_V_Intel
Hi Orhan,
Can you confirm that you have followed the steps to configure Intel Processor Graphics(GPU).
If yes, the issue might be due to driver, Please uninstall the OpenVINO and drivers. Then restart the system to reflect the changes.
Then install the OpenVINO and drivers again.
Hope this helps.
Ram prasad
Sertkaya__Orhan
First of all thank you for your feedback.
I could only see dGPU with this command.
lspci | grep -i vga => 01:00.0 VGA compatible controller: NVIDIA Corporation GM206 [GeForce GTX 960] (rev a1)
According to my research, I learned that I need to enable iGPU Multi-monitor from BIOS setting.
I followed this path on BIOS. => 'Advanced' menu > System Agent (SA) Configuration\Graphics Configuration > iGPU Multi-Monitor setting > Enable
After that I ran commad again
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
After this steps, I was able to run the command I tried before with iGPU.
But when I want to run this model with C++, I get an error like this.
orhan@orhan:~/omz_demos_build/intel64/Release$ ./object_detection_demo_yolov3_async -i ~/Downloads/tensorflow-yolo-v3-master/sample.mp4 -m ~/Downloads/tensorflow-yolo-v3-master/yolov3/frozen_darknet_yolov3_model.xml -d GPU
InferenceEngine: 0x7ff0ee27b030
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
    GPU
    clDNNPlugin version ......... 2.1
    Build ........... 42025
[ INFO ] Checking that the inputs are as the demo expects
[ INFO ] Checking that the outputs are as the demo expects
[ INFO ] Loading model to the device
[ INFO ] Start inference
To close the application, press 'CTRL+C' here or switch to the output window and press ESC key
To switch between sync/async modes, press TAB key in the output window
[ ERROR ] Can't get ngraph::Function. Make sure the provided model is in IR version 10 or greater.
Why am I getting this error? How can I fix it?
My OpenVINO version is openvino_2020.2.120.
SIRIGIRI_V_Intel
Can you run the verification scripts with GPU, because the error seems to be the model incompatible issue.
Change the working directory to /opt/intel/openvino/deployment_tools/demo and run the below command:
./demo_security_barrier_camera.sh -d GPU
Let us know the results.
Ram prasad
ShivSD
Hi ,
I ran the demo application, same GPU not found error. Please can you suggest on how to enable GPU
openvino build : 2020 4
OS: ubuntu 18.04
lspci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation Device 3e9b (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1e90 (rev a1)
Run Inference Engine security_barrier_camera demo
Run ./security_barrier_camera_demo -d GPU -d_va GPU -d_lpr GPU -i /opt/intel/openvino/deployment_tools/demo/car_1.bmp -m /home/nagarajashivashankar/openvino_models/ir/intel/vehicle-license-plate-detection-barrier-0106/FP16/vehicle-license-plate-detection-barrier-0106.xml -m_lpr /home/nagarajashivashankar/openvino_models/ir/intel/license-plate-recognition-barrier-0001/FP16/license-plate-recognition-barrier-0001.xml -m_va /home/nagarajashivashankar/openvino_models/ir/intel/vehicle-attributes-recognition-barrier-0039/FP16/vehicle-attributes-recognition-barrier-0039.xml
[ INFO ] InferenceEngine: 0x7fa8c353a030
[ INFO ] Files were added: 1
[ INFO ] /opt/intel/openvino/deployment_tools/demo/car_1.bmp
[ INFO ] Loading device GPU
[ ERROR ] Failed to create plugin /opt/intel/openvino_2020.4.287/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so for device GPU
GeerthanaaRavi
Hi ShivSD,
Have you found a solution for this?
