Hi ,
I am using openvino latest Release R2, on windows 10 machine.
I tried converting the fasterRCNN with resnet 101 of .pb to IR format. But getting issues as follows :
The .pb is from : https://storage.googleapis.com/intel-optimized-tensorflow/models/resnet101_fp32_pretrained_model.pb
(tf_1.14) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>python ..\mo.py --input_model C:\Users\GF63\Documents\Intel\OpenVINO\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb --input_shape (100,224,224,3) --output_dir D:\Openvino\ --log_level DEBUG
[ 2019-08-21 15:09:20,540 ] [ DEBUG ] [ main:134 ]  Namespace(batch=None, blobs_as_inputs=False, caffe_parser_path='..\\mo\\front\\caffe\\proto', counts=None, data_type='float', disable_fusing=None, disable_gfusing=None, disable_nhwc_to_nchw=False, disable_omitting_optional=False, disable_resnet_optimization=False, enable_concat_optimization=False, enable_flattening_nested_params=False, enable_ssd_gluoncv=False, extensions='C:\\Program Files (x86)\\IntelSWTools\\openvino\\deployment_tools\\model_optimizer\\extensions', finegrain_fusing=None, framework='tf', freeze_placeholder_with_value=None, generate_deprecated_IR_V2=None, generate_experimental_IR_V10=False, input=None, input_checkpoint=None, input_meta_graph=None, input_model='C:\\Users\\GF63\\Documents\\Intel\\OpenVINO\\faster_rcnn_resnet101_coco_2018_01_28\\frozen_inference_graph.pb', input_model_is_text=False, input_proto=None, input_shape='(100,224,224,3)', input_symbol=None, k='..\\extensions\\front\\caffe\\CustomLayersMapping.xml', keep_quantize_ops_in_IR=False, keep_shape_ops=False, legacy_mxnet_model=False, log_level='DEBUG', mean_file=None, mean_file_offsets=None, mean_values=(), model_name=None, move_to_preprocess=False, nd_prefix_name=None, output=None, output_dir='D:\\Openvino\\', pretrained_model_name=None, remove_output_softmax=False, reverse_input_channels=False, save_params_from_nd=False, saved_model_dir=None, saved_model_tags=None, scale=None, scale_values=(), silent=False, tensorboard_logdir=None, tensorflow_custom_layer_libraries=None, tensorflow_custom_operations_config_update=None, tensorflow_object_detection_api_pipeline_config=None, tensorflow_operation_patterns=None, tensorflow_subgraph_patterns=None, tensorflow_use_custom_operations_config=None, version=False)
[ 2019-08-21 15:09:20,540 ] [ DEBUG ] [ main:135 ]  Model Optimizer started
[ 2019-08-21 15:09:20,540 ] [ DEBUG ] [ main:149 ]  Output model name would be frozen_inference_graph{.xml, .bin}
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      C:\Users\GF63\Documents\Intel\OpenVINO\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb
        - Path for generated IR:        D:\Openvino\
        - IR output name:       frozen_inference_graph
        - Log level:    DEBUG
        - Batch:        Not specified, inherited from the model
        - Input layers:         Not specified, inherited from the model
        - Output layers:        Not specified, inherited from the model
        - Input shapes:         (100,224,224,3)
        - Mean values:  Not specified
        - Scale values:         Not specified
        - Scale factor:         Not specified
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
TensorFlow specific parameters:
        - Input model in text protobuf format:  False
        - Path to model dump for TensorBoard:   None
        - List of shared libraries with TensorFlow custom layers implementation:        None
        - Update the configuration file with input/output node names:   None
        - Use configuration file used to generate the model with Object Detection API:  None
        - Operations to offload:        None
        - Patterns to offload:  None
        - Use the config file:  None
Model Optimizer version:        2019.2.0-436-gf5827d4
[ 2019-08-21 15:09:21,453 ] [ DEBUG ] [ main:235 ]  Placeholder shapes : [100 224 224   3]
[ INFO ]  Importing extensions from: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo
[ INFO ]  New subclass: <class 'extensions.ops.gather.Gather'>
[ INFO ]  Registered a new subclass with key: Gather
[ INFO ]  New subclass: <class 'mo.ops.const.Const'>
[ INFO ]  Registered a new subclass with key: Const
[ INFO ]  New subclass: <class 'extensions.ops.transpose.Transpose'>
[ INFO ]  Registered a new subclass with key: Transpose
[ INFO ]  New subclass: <class 'mo.ops.reshape.Reshape'>
[ INFO ]  Registered a new subclass with key: Reshape
[ INFO ]  New subclass: <class 'mo.ops.scale_shift.ScaleShiftOp'>
[ INFO ]  Registered a new subclass with key: ScaleShift
[ INFO ]  New subclass: <class 'mo.ops.clamp.Clamp'>
[ INFO ]  Registered a new subclass with key: Clamp
[ INFO ]  New subclass: <class 'extensions.ops.activation_ops.Activation'>
[ INFO ]  New subclass: <class 'extensions.ops.activation_ops.LeakyReLU'>
[ INFO ]  Registered a new subclass with key: LeakyReLU
[ INFO ]  New subclass: <class 'mo.ops.concat.Concat'>
[ INFO ]  Registered a new subclass with key: Concat
[ INFO ]  New subclass: <class 'mo.ops.convolution.Convolution'>
[ INFO ]  Registered a new subclass with key: Convolution
[ INFO ]  New subclass: <class 'mo.ops.crop.Crop'>
[ INFO ]  Registered a new subclass with key: Crop
[ INFO ]  New subclass: <class 'mo.ops.softmax.Softmax'>
[ INFO ]  Registered a new subclass with key: SoftMax
[ INFO ]  New subclass: <class 'extensions.ops.elementwise.Elementwise'>
[ INFO ]  New subclass: <class 'mo.ops.activation.Activation'>
[ INFO ]  Registered a new subclass with key: Activation
[ INFO ]  New subclass: <class 'mo.ops.broadcast.Broadcast'>
[ INFO ]  Registered a new subclass with key: Broadcast
[ INFO ]  New subclass: <class 'mo.ops.deconvolution.Deconvolution'>
[ INFO ]  Registered a new subclass with key: Deconvolution
[ INFO ]  New subclass: <class 'mo.ops.deformable_convolution.DeformableConvolution'>
[ INFO ]  Registered a new subclass with key: DeformableConvolution
[ INFO ]  New subclass: <class 'mo.ops.eltwise.Eltwise'>
[ INFO ]  Registered a new subclass with key: Eltwise
[ INFO ]  New subclass: <class 'mo.ops.eltwise_n.EltwiseN'>
[ INFO ]  Registered a new subclass with key: EltwiseN
[ INFO ]  New subclass: <class 'mo.ops.eltwise_ninputs_in_1.EltwiseNin1'>
[ INFO ]  Registered a new subclass with key: EltwiseNin1
[ INFO ]  New subclass: <class 'mo.ops.expand_dims.ExpandDims'>
[ INFO ]  Registered a new subclass with key: ExpandDims
[ INFO ]  New subclass: <class 'mo.ops.fill.Fill'>
[ INFO ]  Registered a new subclass with key: Fill
[ INFO ]  New subclass: <class 'mo.ops.flatten.Flatten'>
[ INFO ]  Registered a new subclass with key: Flatten
[ INFO ]  New subclass: <class 'mo.ops.flatten_onnx.FlattenONNX'>
[ INFO ]  Registered a new subclass with key: FlattenONNX
[ INFO ]  New subclass: <class 'mo.ops.group_norm.GroupNorm'>
[ INFO ]  Registered a new subclass with key: GroupNorm
[ INFO ]  New subclass: <class 'mo.ops.inner_product.InnerProduct'>
[ INFO ]  Registered a new subclass with key: FullyConnected
[ INFO ]  New subclass: <class 'mo.ops.lrn.LRN'>
[ INFO ]  Registered a new subclass with key: LRN
[ INFO ]  New subclass: <class 'mo.ops.lstmnonlinearity.LstmNonLinearity'>
[ INFO ]  Registered a new subclass with key: LstmNonLinearity
[ INFO ]  New subclass: <class 'mo.ops.memory.Memory'>
[ INFO ]  Registered a new subclass with key: Memory
[ INFO ]  New subclass: <class 'mo.ops.memoryoffset.MemoryOffset'>
[ INFO ]  Registered a new subclass with key: MemoryOffset
[ INFO ]  New subclass: <class 'mo.ops.pad.Pad'>
[ INFO ]  Registered a new subclass with key: Pad
[ INFO ]  New subclass: <class 'mo.ops.permute.Permute'>
[ INFO ]  Registered a new subclass with key: Permute
[ INFO ]  New subclass: <class 'mo.ops.pooling.Pooling'>
[ INFO ]  Registered a new subclass with key: Pooling
[ INFO ]  New subclass: <class 'mo.ops.power.Power'>
[ INFO ]  Registered a new subclass with key: Power
[ INFO ]  New subclass: <class 'mo.ops.result.Result'>
[ INFO ]  Registered a new subclass with key: Result
[ INFO ]  New subclass: <class 'mo.ops.roipooling.ROIPooling'>
[ INFO ]  Registered a new subclass with key: ROIPooling
[ INFO ]  New subclass: <class 'mo.ops.shape.Shape'>
[ INFO ]  Registered a new subclass with key: ShapeOf
[ INFO ]  New subclass: <class 'mo.ops.slice.Slice'>
[ INFO ]  Registered a new subclass with key: Slice
[ INFO ]  New subclass: <class 'mo.ops.split.Split'>
[ INFO ]  Registered a new subclass with key: Split
[ INFO ]  New subclass: <class 'mo.ops.squeeze.Squeeze'>
[ INFO ]  Registered a new subclass with key: Squeeze
[ INFO ]  New subclass: <class 'mo.ops.strided_slice.StridedSlice'>
[ INFO ]  Registered a new subclass with key: StridedSlice
[ INFO ]  New subclass: <class 'mo.ops.tile.Tile'>
[ INFO ]  Registered a new subclass with key: Tile
[ INFO ]  New subclass: <class 'mo.ops.unsqueeze.Unsqueeze'>
[ INFO ]  Registered a new subclass with key: Unsqueeze
[ INFO ]  New subclass: <class 'mo.front.common.replacement.FrontReplacementSubgraph'>
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileGeneral'>
[ INFO ]  New subclass: <class 'mo.front.common.replacement.FrontReplacementOp'>
[ INFO ]  Registered a new subclass with key: UnknownOp
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileSubGraph'>
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileOp'>
[ WARNING ]  Skipped <class 'mo.front.common.replacement.FrontReplacementSubgraph'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileGeneral'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.common.replacement.FrontReplacementOp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileSubGraph'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileOp'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.middle.ConcatOptimization.ConcatOptimization'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseChecker.EltwiseChecker'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputReshape.Eltwise1DInputReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputReshape.EltwiseInputReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputNormalization.EltwiseInputNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.CreateConstNodes.CreateConstNodesReplacement'>
[ INFO ]  New subclass: <class 'extensions.back.FuseReshapesSequence.FuseReshapesSequence'>
[ INFO ]  New subclass: <class 'extensions.back.InsertLayoutPropagationTransposes.InsertLayoutPropagationTranspose'>
[ INFO ]  New subclass: <class 'extensions.back.RemoveRedundantReshapes.RemoveRedundantReshapes'>
[ INFO ]  New subclass: <class 'extensions.middle.LayoutChangeForConstantShapePaths.LayoutChangeForConstantShapePaths'>
[ INFO ]  New subclass: <class 'mo.front.tf.extractors.strided_slice.StridedSliceFrontExtractor'>
[ INFO ]  Importing extensions from: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\extensions
[ WARNING ]  Skipped <class 'extensions.ops.gather.Gather'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.const.Const'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.transpose.Transpose'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.reshape.Reshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.scale_shift.ScaleShiftOp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.clamp.Clamp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.activation_ops.Activation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.activation_ops.LeakyReLU'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.concat.Concat'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.convolution.Convolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.crop.Crop'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.softmax.Softmax'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.elementwise.Elementwise'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.activation.Activation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.broadcast.Broadcast'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.deconvolution.Deconvolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.deformable_convolution.DeformableConvolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise.Eltwise'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise_n.EltwiseN'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise_ninputs_in_1.EltwiseNin1'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.expand_dims.ExpandDims'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.fill.Fill'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.flatten.Flatten'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.flatten_onnx.FlattenONNX'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.group_norm.GroupNorm'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.inner_product.InnerProduct'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.lrn.LRN'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.lstmnonlinearity.LstmNonLinearity'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.memory.Memory'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.memoryoffset.MemoryOffset'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.pad.Pad'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.permute.Permute'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.pooling.Pooling'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.power.Power'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.result.Result'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.roipooling.ROIPooling'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.shape.Shape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.slice.Slice'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.split.Split'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.squeeze.Squeeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.strided_slice.StridedSlice'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.tile.Tile'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.unsqueeze.Unsqueeze'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.ops.BatchMatMul.BatchMatMul'>
[ INFO ]  Registered a new subclass with key: BatchMatMul
[ INFO ]  New subclass: <class 'extensions.ops.BlockLSTM.BlockLSTM'>
[ INFO ]  Registered a new subclass with key: BlockLSTM
[ INFO ]  New subclass: <class 'extensions.ops.Cast.Cast'>
[ INFO ]  Registered a new subclass with key: Cast
[ INFO ]  New subclass: <class 'extensions.ops.DetectionOutput.DetectionOutput'>
[ INFO ]  Registered a new subclass with key: DetectionOutput
[ INFO ]  New subclass: <class 'extensions.ops.Enter.Enter'>
[ INFO ]  Registered a new subclass with key: Enter
[ INFO ]  New subclass: <class 'extensions.ops.Exit.Exit'>
[ INFO ]  Registered a new subclass with key: Exit
[ INFO ]  New subclass: <class 'extensions.ops.RNN.RNN'>
[ INFO ]  Registered a new subclass with key: RNN
[ INFO ]  New subclass: <class 'extensions.ops.GRU.GRU'>
[ INFO ]  Registered a new subclass with key: GRU
[ INFO ]  New subclass: <class 'extensions.ops.GRUCell.GRUCell'>
[ INFO ]  Registered a new subclass with key: GRUCell
[ INFO ]  New subclass: <class 'extensions.ops.GatherNd.GatherNd'>
[ INFO ]  Registered a new subclass with key: GatherNd
[ INFO ]  New subclass: <class 'extensions.ops.GatherTree.GatherTree'>
[ INFO ]  Registered a new subclass with key: GatherTree
[ INFO ]  New subclass: <class 'extensions.ops.LSTM.LSTM'>
[ INFO ]  Registered a new subclass with key: LSTM
[ INFO ]  New subclass: <class 'extensions.ops.Log.LogOp'>
[ INFO ]  Registered a new subclass with key: Log
[ INFO ]  New subclass: <class 'extensions.ops.NextIteration.NextIteration'>
[ INFO ]  Registered a new subclass with key: NextIteration
[ INFO ]  New subclass: <class 'extensions.ops.RNNCell.RNNCell'>
[ INFO ]  Registered a new subclass with key: RNNCell
[ INFO ]  New subclass: <class 'extensions.ops.ReduceOps.ReduceOp'>
[ INFO ]  New subclass: <class 'extensions.ops.Reverse.Reverse'>
[ INFO ]  Registered a new subclass with key: Reverse
[ INFO ]  New subclass: <class 'extensions.ops.SquaredDifference.SquaredDifference'>
[ INFO ]  Registered a new subclass with key: SquaredDifference
[ INFO ]  New subclass: <class 'extensions.ops.TensorArray.TensorArray'>
[ INFO ]  Registered a new subclass with key: TensorArrayV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayGather.TensorArrayGather'>
[ INFO ]  Registered a new subclass with key: TensorArrayGatherV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayRead.TensorArrayReader'>
[ INFO ]  Registered a new subclass with key: TensorArrayReadV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayScatter.TensorArrayScatter'>
[ INFO ]  Registered a new subclass with key: TensorArrayScatterV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArraySize.TensorArraySize'>
[ INFO ]  Registered a new subclass with key: TensorArraySizeV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayWrite.TensorArrayWriter'>
[ INFO ]  Registered a new subclass with key: TensorArrayWriteV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorInput'>
[ INFO ]  Registered a new subclass with key: TensorIteratorInput
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorOutput'>
[ INFO ]  Registered a new subclass with key: TensorIteratorOutput
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorCondition'>
[ INFO ]  Registered a new subclass with key: TensorIteratorCondition
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorBackEdge'>
[ INFO ]  Registered a new subclass with key: TensorIteratorBackEdge
[ INFO ]  New subclass: <class 'extensions.ops.accum.AccumOp'>
[ INFO ]  Registered a new subclass with key: Accum
[ INFO ]  New subclass: <class 'extensions.ops.argmax.ArgMaxOp'>
[ INFO ]  Registered a new subclass with key: ArgMax
[ INFO ]  New subclass: <class 'extensions.ops.assert_op.Assert'>
[ INFO ]  Registered a new subclass with key: Assert
[ INFO ]  New subclass: <class 'extensions.ops.axpy.AxpyOp'>
[ INFO ]  Registered a new subclass with key: Axpy
[ INFO ]  New subclass: <class 'extensions.ops.binarization.Binarization'>
[ INFO ]  Registered a new subclass with key: Binarization
[ INFO ]  New subclass: <class 'extensions.ops.bn.BNOp'>
[ INFO ]  Registered a new subclass with key: BN
[ INFO ]  New subclass: <class 'extensions.ops.box_nms.BoxNms'>
[ INFO ]  Registered a new subclass with key: _contrib_box_nms
[ INFO ]  New subclass: <class 'extensions.ops.constant_fill.ConstantFill'>
[ INFO ]  Registered a new subclass with key: ConstantFill
[ INFO ]  New subclass: <class 'extensions.ops.copy.CopyOp'>
[ INFO ]  Registered a new subclass with key: copy
[ INFO ]  New subclass: <class 'extensions.ops.correlation.CorrelationOp'>
[ INFO ]  Registered a new subclass with key: Correlation
[ INFO ]  New subclass: <class 'extensions.ops.ctc_greedy_decoder.CTCGreedyDecoderOp'>
[ INFO ]  Registered a new subclass with key: CTCGreedyDecoder
[ INFO ]  New subclass: <class 'extensions.ops.data_augmentation.DataAugmentationOp'>
[ INFO ]  Registered a new subclass with key: DataAugmentation
[ INFO ]  New subclass: <class 'extensions.ops.depth_to_space.DepthToSpaceOp'>
[ INFO ]  Registered a new subclass with key: DepthToSpace
[ INFO ]  New subclass: <class 'extensions.ops.detectionoutput_onnx.ExperimentalDetectronDetectionOutput'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronDetectionOutput
[ INFO ]  New subclass: <class 'extensions.ops.exp.ExpOp'>
[ INFO ]  New subclass: <class 'extensions.ops.fakequantize.FakeQuantize'>
[ INFO ]  Registered a new subclass with key: FakeQuantize
[ INFO ]  New subclass: <class 'extensions.ops.grn.GRNOp'>
[ INFO ]  Registered a new subclass with key: GRN
[ INFO ]  New subclass: <class 'extensions.ops.identity.IdentityOp'>
[ INFO ]  Registered a new subclass with key: Identity
[ INFO ]  New subclass: <class 'extensions.ops.instance_normalization.InstanceNormalization'>
[ INFO ]  Registered a new subclass with key: InstanceNormalization
[ INFO ]  New subclass: <class 'extensions.ops.interp.InterpOp'>
[ INFO ]  Registered a new subclass with key: Interp
[ INFO ]  New subclass: <class 'extensions.ops.interpolate.Interpolate'>
[ INFO ]  Registered a new subclass with key: Interpolate
[ INFO ]  New subclass: <class 'extensions.ops.lstm_cell.LSTMCell'>
[ INFO ]  Registered a new subclass with key: LSTMCell
[ INFO ]  New subclass: <class 'extensions.ops.lstm_sequence.LSTMSequence'>
[ INFO ]  Registered a new subclass with key: LSTMSequence
[ INFO ]  New subclass: <class 'extensions.ops.merge.Merge'>
[ INFO ]  Registered a new subclass with key: Merge
[ INFO ]  New subclass: <class 'extensions.ops.mvn.MVN'>
[ INFO ]  Registered a new subclass with key: MVN
[ INFO ]  New subclass: <class 'extensions.ops.normalize.NormalizeOp'>
[ INFO ]  Registered a new subclass with key: Normalize
[ INFO ]  New subclass: <class 'extensions.ops.one_hot.OneHot'>
[ INFO ]  Registered a new subclass with key: OneHot
[ INFO ]  New subclass: <class 'extensions.ops.pack.PackOp'>
[ INFO ]  Registered a new subclass with key: Pack
[ INFO ]  New subclass: <class 'extensions.ops.parameter.Parameter'>
[ INFO ]  Registered a new subclass with key: Parameter
[ INFO ]  New subclass: <class 'extensions.ops.power_file.PowerFileOp'>
[ INFO ]  Registered a new subclass with key: PowerFile
[ INFO ]  New subclass: <class 'extensions.ops.prediction_heatmap.PredictionHeatmapOp'>
[ INFO ]  Registered a new subclass with key: PredictionHeatmap
[ INFO ]  New subclass: <class 'extensions.ops.prelu.PreluOp'>
[ INFO ]  Registered a new subclass with key: PReLU
[ INFO ]  New subclass: <class 'extensions.ops.priorbox.PriorBoxOp'>
[ INFO ]  Registered a new subclass with key: PriorBox
[ INFO ]  New subclass: <class 'extensions.ops.priorbox_clustered.PriorBoxClusteredOp'>
[ INFO ]  Registered a new subclass with key: PriorBoxClustered
[ INFO ]  New subclass: <class 'extensions.ops.priorgridgenerator_onnx.ExperimentalDetectronPriorGridGenerator'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronPriorGridGenerator
[ INFO ]  New subclass: <class 'extensions.ops.proposal.ProposalOp'>
[ INFO ]  Registered a new subclass with key: Proposal
[ INFO ]  New subclass: <class 'extensions.ops.proposal_onnx.ExperimentalDetectronGenerateProposalsSingleImage'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronGenerateProposalsSingleImage
[ INFO ]  New subclass: <class 'extensions.ops.psroipooling.PSROIPoolingOp'>
[ INFO ]  Registered a new subclass with key: PSROIPooling
[ INFO ]  New subclass: <class 'extensions.ops.range.Range'>
[ INFO ]  Registered a new subclass with key: Range
[ INFO ]  New subclass: <class 'extensions.ops.rank.Rank'>
[ INFO ]  Registered a new subclass with key: Rank
[ INFO ]  New subclass: <class 'extensions.ops.regionyolo.RegionYoloOp'>
[ INFO ]  Registered a new subclass with key: RegionYolo
[ INFO ]  New subclass: <class 'extensions.ops.reorgyolo.ReorgYoloOp'>
[ INFO ]  Registered a new subclass with key: ReorgYolo
[ INFO ]  New subclass: <class 'extensions.ops.resample.ResampleOp'>
[ INFO ]  Registered a new subclass with key: Resample
[ INFO ]  New subclass: <class 'extensions.ops.reverse_sequence.ReverseSequence'>
[ INFO ]  Registered a new subclass with key: ReverseSequence
[ INFO ]  New subclass: <class 'extensions.ops.roifeatureextractor_onnx.ExperimentalDetectronROIFeatureExtractor'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronROIFeatureExtractor
[ INFO ]  New subclass: <class 'extensions.ops.select.Select'>
[ INFO ]  Registered a new subclass with key: Select
[ INFO ]  New subclass: <class 'extensions.ops.shufflechannel.ShuffleChannelOp'>
[ INFO ]  Registered a new subclass with key: ShuffleChannel
[ INFO ]  New subclass: <class 'extensions.ops.simplernms.SimplerNMSOp'>
[ INFO ]  Registered a new subclass with key: SimplerNMS
[ INFO ]  New subclass: <class 'extensions.ops.size.Size'>
[ INFO ]  Registered a new subclass with key: Size
[ INFO ]  New subclass: <class 'extensions.ops.space_to_depth.SpaceToDepth'>
[ INFO ]  Registered a new subclass with key: SpaceToDepth
[ INFO ]  New subclass: <class 'extensions.ops.spatial_transformer.SpatialTransformOp'>
[ INFO ]  Registered a new subclass with key: SpatialTransformer
[ INFO ]  New subclass: <class 'extensions.ops.splice.Splice'>
[ INFO ]  Registered a new subclass with key: Splice
[ INFO ]  New subclass: <class 'extensions.ops.splitv.SplitV'>
[ INFO ]  Registered a new subclass with key: SplitV
[ INFO ]  New subclass: <class 'extensions.ops.stop_gradient.StopGradientOp'>
[ INFO ]  Registered a new subclass with key: StopGradient
[ INFO ]  New subclass: <class 'extensions.ops.swapaxis.SwapAxis'>
[ INFO ]  Registered a new subclass with key: SwapAxis
[ INFO ]  New subclass: <class 'extensions.ops.switch.Switch'>
[ INFO ]  Registered a new subclass with key: Switch
[ INFO ]  New subclass: <class 'extensions.ops.tensor_iterator.TensorIterator'>
[ INFO ]  New subclass: <class 'extensions.ops.topk.TopK'>
[ INFO ]  Registered a new subclass with key: TopK
[ INFO ]  New subclass: <class 'extensions.ops.topkrois_onnx.ExperimentalDetectronTopKROIs'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronTopKROIs
[ INFO ]  New subclass: <class 'extensions.ops.upsample.UpsampleOp'>
[ INFO ]  Registered a new subclass with key: Upsample
[ WARNING ]  Skipped <class 'mo.front.tf.extractors.strided_slice.StridedSliceFrontExtractor'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.LRNReplacer.LRNReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.Pack.Pack'>
[ INFO ]  New subclass: <class 'extensions.front.PowerToEltwises.PowerToEltwises'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'>
[ INFO ]  Registered a new subclass with key: FakeQuantWithMinMaxVars
[ INFO ]  New subclass: <class 'extensions.front.div.Div'>
[ INFO ]  Registered a new subclass with key: Div
[ INFO ]  New subclass: <class 'extensions.front.eltwise_n.EltwiseNReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.image_scaler.ImageScaler'>
[ INFO ]  Registered a new subclass with key: ImageScaler
[ INFO ]  New subclass: <class 'extensions.front.instance_normalization.InstanceNormalization'>
[ INFO ]  New subclass: <class 'extensions.front.reciprocal.ReciprocalReplacer'>
[ INFO ]  Registered a new subclass with key: Reciprocal
[ INFO ]  New subclass: <class 'extensions.front.sub.Sub'>
[ INFO ]  Registered a new subclass with key: Sub
[ INFO ]  New subclass: <class 'extensions.front.squared_difference.SquaredDifference'>
[ INFO ]  New subclass: <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'>
[ INFO ]  New subclass: <class 'extensions.front.FillToBroadcast.FillToBroadcast'>
[ INFO ]  New subclass: <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'>
[ INFO ]  New subclass: <class 'extensions.front.TopKNormalize.TopKNormalize'>
[ INFO ]  New subclass: <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'>
[ INFO ]  New subclass: <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'>
[ INFO ]  New subclass: <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'>
[ INFO ]  New subclass: <class 'extensions.front.input_cut.InputCut'>
[ INFO ]  New subclass: <class 'extensions.front.output_cut.OutputCut'>
[ INFO ]  New subclass: <class 'extensions.front.override_batch.OverrideBatch'>
[ INFO ]  New subclass: <class 'extensions.front.pass_separator.FrontStart'>
[ INFO ]  New subclass: <class 'extensions.front.pass_separator.FrontFinish'>
[ INFO ]  New subclass: <class 'extensions.front.user_data_repack.UserDataRepack'>
[ INFO ]  New subclass: <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'>
[ INFO ]  New subclass: <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'>
[ INFO ]  New subclass: <class 'extensions.front.no_op_eraser.NoOpEraser'>
[ INFO ]  New subclass: <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.restore_ports.RestorePorts'>
[ INFO ]  New subclass: <class 'extensions.front.softmax.SoftmaxFromKeras'>
[ INFO ]  New subclass: <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'>
[ INFO ]  New subclass: <class 'extensions.front.tf.BatchMatMul_ext.BatchMatMulExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.BlockLSTM_ext.BlockLSTMExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.CTCGreedyDecoder_ext.CTCCGreedyDecoderFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.Cast_ext.CastFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FakeQuantWithMinMaxVars_ext.FakeQuantWithMinMaxVarsExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FloorMod_ext.EltwiseFrontExtractor'>
[ INFO ]  Registered a new subclass with key: FloorMod
[ INFO ]  New subclass: <class 'extensions.front.tf.GatherTree_ext.GatherTreeFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.LoopCond_ext.LoopCondFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LoopCond
[ INFO ]  New subclass: <class 'extensions.front.tf.Not_ext.LogicalNotFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalNot
[ INFO ]  New subclass: <class 'extensions.front.tf.TensorArrayExtractors.TensorArrayExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.TensorArrayGatherV3.TensorArrayGatherV3Exteractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.all_ext.AllFrontExtractor'>
[ INFO ]  Registered a new subclass with key: All
[ INFO ]  New subclass: <class 'extensions.front.tf.argmax_ext.ArgMaxFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.concat_ext.ConcatFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.Conv2DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv2D
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.DepthwiseConv2dNativeFrontExtractor'>
[ INFO ]  Registered a new subclass with key: DepthwiseConv2dNative
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.Conv3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv3D
[ INFO ]  New subclass: <class 'extensions.front.tf.crop_and_resize_ext.CropAndResizeFrontExtractor'>
[ INFO ]  Registered a new subclass with key: CropAndResize
[ INFO ]  New subclass: <class 'extensions.front.tf.deconv_ext.Conv2DBackpropInputFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv2DBackpropInput
[ INFO ]  New subclass: <class 'extensions.front.tf.deconv_ext.Conv3DBackpropInputV2InputFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv3DBackpropInputV2
[ INFO ]  New subclass: <class 'extensions.front.tf.depth_to_space.DepthToSpaceFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.AddExtractor'>
[ INFO ]  Registered a new subclass with key: Add
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.AddNExtractor'>
[ INFO ]  Registered a new subclass with key: AddN
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.BiasAddExtractor'>
[ INFO ]  Registered a new subclass with key: BiasAdd
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MulExtractor'>
[ INFO ]  Registered a new subclass with key: Mul
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SubExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.DivExtractor'>
[ INFO ]  Registered a new subclass with key: RealDiv
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SqrtExtractor'>
[ INFO ]  Registered a new subclass with key: Sqrt
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.RsqrtExtractor'>
[ INFO ]  Registered a new subclass with key: Rsqrt
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SquareExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.NegExtractor'>
[ INFO ]  Registered a new subclass with key: Neg
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.ZerosLike'>
[ INFO ]  Registered a new subclass with key: ZerosLike
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MaximumExtractor'>
[ INFO ]  Registered a new subclass with key: Maximum
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MinimumExtractor'>
[ INFO ]  Registered a new subclass with key: Minimum
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.PowExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LogicalAndFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalAnd
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LogicalOrFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalOr
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.EqualExtractor'>
[ INFO ]  Registered a new subclass with key: Equal
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LessEqualExtractor'>
[ INFO ]  Registered a new subclass with key: LessEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LessExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.GreaterExtractor'>
[ INFO ]  Registered a new subclass with key: Greater
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.GreaterEqualExtractor'>
[ INFO ]  Registered a new subclass with key: GreaterEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.NotEqualExtractor'>
[ INFO ]  Registered a new subclass with key: NotEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elu_ext.EluFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Elu
[ INFO ]  New subclass: <class 'extensions.front.tf.erf_ext.ErfFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Erf
[ INFO ]  New subclass: <class 'extensions.front.tf.exp_ext.ExpExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.expand_dims_ext.ExpandDimsExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.extract_image_patches_ext.ExtractImagePatchesExtractor'>
[ INFO ]  Registered a new subclass with key: ExtractImagePatches
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_queue_v2_ext.FIFOQueueV2Extractor'>
[ INFO ]  Registered a new subclass with key: FIFOQueueV2
[ INFO ]  New subclass: <class 'extensions.front.tf.fill_ext.FillExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.GatherFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.ResourceGatherFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResourceGather
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.GatherV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: GatherV2
[ INFO ]  New subclass: <class 'extensions.front.tf.leaky_relu_ext.LeakyReLUFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LeakyRelu
[ INFO ]  New subclass: <class 'extensions.front.tf.max_ext.MaxFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mean_ext.MeanExtractor'>
[ INFO ]  Registered a new subclass with key: Mean
[ INFO ]  New subclass: <class 'extensions.front.tf.next_iteration_ext.NextIterationExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.one_hot_ext.OneHotFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.PadFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.PadV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: PadV2
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.MirrorPadFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MirrorPad
[ INFO ]  New subclass: <class 'extensions.front.tf.placeholder_ext.PlaceholderFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Placeholder
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.AvgPoolFrontExtractor'>
[ INFO ]  Registered a new subclass with key: AvgPool
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.MaxPoolFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MaxPool
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.MaxPool3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MaxPool3D
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.AvgPool3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: AvgPool3D
[ INFO ]  New subclass: <class 'extensions.front.tf.prod_ext.ProdFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Prod
[ INFO ]  New subclass: <class 'extensions.front.tf.rank_ext.RankFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.relu6_ext.Relu6FrontExtractor'>
[ INFO ]  Registered a new subclass with key: Relu6
[ INFO ]  New subclass: <class 'extensions.front.tf.relu_ext.ReluFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reshape_ext.ReshapeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.resize_bilinear.ResizeBilinearFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResizeBilinear
[ INFO ]  New subclass: <class 'extensions.front.tf.resize_nearest_neighbor.ResizeNearestNeighborFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResizeNearestNeighbor
[ INFO ]  New subclass: <class 'extensions.front.tf.reverse_sequence.ReverseSequenceFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reverse_v2.ReverseV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: ReverseV2
[ INFO ]  New subclass: <class 'extensions.front.tf.select_ext.SelectExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.shape_ext.ShapeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sigmoid.SigmoidFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sigmoid
[ INFO ]  New subclass: <class 'extensions.front.tf.size_ext.SizeFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.slice_ext.SliceExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.softmax_ext.SoftmaxFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Softmax
[ INFO ]  New subclass: <class 'extensions.front.tf.space_to_depth_ext.SpaceToDepthFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.split_ext.SplitVExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.squeeze_ext.SqueezeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.stop_gradient_ext.StopGradientExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sum_ext.SumFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sum
[ INFO ]  New subclass: <class 'extensions.front.tf.tanh.TanhFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Tanh
[ INFO ]  New subclass: <class 'extensions.front.tf.tile_ext.TileExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.topk_ext.TopKExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.topk_ext.TopKV2Extractor'>
[ INFO ]  Registered a new subclass with key: TopKV2
[ INFO ]  New subclass: <class 'extensions.front.tf.transpose_ext.TransposeFrontExtractorTF'>
[ INFO ]  New subclass: <class 'extensions.front.tf.variable_ext.VariableExtractor'>
[ INFO ]  Registered a new subclass with key: Variable
[ INFO ]  New subclass: <class 'extensions.front.tf.variable_ext.VariableV2Extractor'>
[ INFO ]  Registered a new subclass with key: VariableV2
[ WARNING ]  Skipped <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.LRNReplacer.LRNReplacer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.Pack.Pack'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.PowerToEltwises.PowerToEltwises'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.div.Div'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.eltwise_n.EltwiseNReplacement'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.image_scaler.ImageScaler'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.instance_normalization.InstanceNormalization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reciprocal.ReciprocalReplacer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.sub.Sub'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.squared_difference.SquaredDifference'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.BlockLSTM.BlockLSTM'>
[ INFO ]  New subclass: <class 'extensions.front.tf.CropAndResizeReplacement.CropAndResizeReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.LogSoftmax.LogSoftmaxFrontReplacer'>
[ INFO ]  Registered a new subclass with key: LogSoftmax
[ INFO ]  New subclass: <class 'extensions.front.tf.Unpack.Unpack'>
[ INFO ]  Registered a new subclass with key: Unpack
[ INFO ]  New subclass: <class 'extensions.front.tf.SizeReplacer.SizeFrontReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignElimination'>
[ INFO ]  Registered a new subclass with key: Assign
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignSubElimination'>
[ INFO ]  Registered a new subclass with key: AssignSub
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignAddElimination'>
[ INFO ]  Registered a new subclass with key: AssignAdd
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssertElimination'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fake_const_ext.FakeConstToConst'>
[ INFO ]  Registered a new subclass with key: FakeConst
[ WARNING ]  Skipped <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.FillToBroadcast.FillToBroadcast'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.TopKNormalize.TopKNormalize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.input_cut.InputCut'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.output_cut.OutputCut'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.override_batch.OverrideBatch'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.pass_separator.FrontStart'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.pass_separator.FrontFinish'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.user_data_repack.UserDataRepack'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.GNMT_DynamicSequenceLengths.GNMT_sequence_lengths'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_custom_operations_config_update.TensorflowCustomOperationsConfigUpdate'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_patterns.TensorflowSubgraphPatterns'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_patterns.TensorflowOperationPatterns'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_use_custom_operations_config.TensorflowUseCustomOperationsConfig'>
[ INFO ]  New subclass: <class 'extensions.front.tf.variables_values_freezing.VariablesToConstants'>
[ WARNING ]  Skipped <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.no_op_eraser.NoOpEraser'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.restore_ports.RestorePorts'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.softmax.SoftmaxFromKeras'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.CTCGreedyDecoder.CTCGreedyDecoderReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.nearest_neighbor_upsampling.NearestNeighborUpsampling'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FlattenToReshape.FlattenToReshapeableReshape'>
[ INFO ]  New subclass: <class 'extensions.front.tf.basic_lstm_cell.BasicLSTMCell'>
[ INFO ]  New subclass: <class 'extensions.front.tf.concat.Concat'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_replacer.FIFOQueue'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_replacer.QueueDequeueManyV2'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mvn.MVN'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mvn_unrolled.MVNUnrolled'>
[ INFO ]  New subclass: <class 'extensions.front.tf.prelu.PReLU'>
[ INFO ]  New subclass: <class 'extensions.front.tf.prelu.PReLUWithAbs'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessorReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNROIPoolingSecondReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIProposalReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPISSDPostprocessorReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPSROIPoolingReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.RetinaNetFilteredDetectionsReplacement.RetinaNetFilteredDetectionsReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.SSDToolboxDetectionOutput.SSDToolboxDetectionOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNSigmoidReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIConstValueOverride'>
[ INFO ]  New subclass: <class 'extensions.front.tf.YOLO.YoloRegionAddon'>
[ INFO ]  New subclass: <class 'extensions.front.tf.YOLO.YoloV3RegionAddon'>
[ WARNING ]  Skipped <class 'extensions.middle.ConcatOptimization.ConcatOptimization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseChecker.EltwiseChecker'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseInputReshape.Eltwise1DInputReshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseInputReshape.EltwiseInputReshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseInputNormalization.EltwiseInputNormalize'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.middle.PartialInfer.PartialInfer'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.LoopConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.SimpleConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.DynamicDecoderConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.MulFakeQuantizeFuse.MulFakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.AddFakeQuantizeFuse.AddFakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.AddIsCyclicAttribute.AddIsCyclicAttribute'>
[ INFO ]  New subclass: <class 'extensions.middle.AddMeanScaleValues.AddMeanScaleValues'>
[ INFO ]  New subclass: <class 'extensions.middle.AnchorToPriorBox.AnchorToPriorBoxes'>
[ INFO ]  New subclass: <class 'extensions.middle.ArgMaxToTopK.ArgMaxToTopK'>
[ INFO ]  New subclass: <class 'extensions.middle.CheckForCycle.CheckForCycle'>
[ INFO ]  New subclass: <class 'extensions.middle.DeleteNotExecutable.DeleteNotExecutable'>
[ INFO ]  New subclass: <class 'extensions.middle.BinarizeWeightsM1P1.BinarizeWeightsM1P1'>
[ INFO ]  New subclass: <class 'extensions.middle.BlockLSTMtoLSTMSequence.BlockLSTMtoLSTMSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveIdentity'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveDropout'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveNodesWithZeroPhase'>
[ INFO ]  New subclass: <class 'extensions.middle.Cast.CastToFloatMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ChangePlaceholderTypes.ChangePlaceholderTypes'>
[ INFO ]  New subclass: <class 'extensions.middle.ConstSwitchResolver.ConstSwitchEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvToBinaryConv.ConvToBinaryConv'>
[ INFO ]  New subclass: <class 'extensions.middle.SliceConverter.ConvertSlice'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertGroupedStridedSlice.ConvertGroupedStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertLayoutDependentOperations.ConvertLayoutDependentOperations'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertMultiInputConv.ConvertMultiInputConv'>
[ INFO ]  New subclass: <class 'extensions.middle.CustomSubgraphCall.CustomSubgraphCall'>
[ INFO ]  New subclass: <class 'extensions.middle.DecomposeBias.DecomposeBias'>
[ INFO ]  New subclass: <class 'extensions.middle.DecomposeBidirectionalRNNSequence.DecomposeBidirectionalRNNSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.DeleteControlFlowEdges.DeleteControlFlowEdges'>
[ INFO ]  New subclass: <class 'extensions.middle.DepthToSpace.DepthToSpace'>
[ INFO ]  New subclass: <class 'extensions.middle.DilatedConvolution.DilatedConvolutionConverter'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorMerge.TensorIteratorMerge'>
[ INFO ]  New subclass: <class 'extensions.middle.FakeSplitOutputs.AddFakeOutputsToSplit'>
[ INFO ]  New subclass: <class 'extensions.middle.FlattenONNXToReshape.FlattenONNXToReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.FusedBatchNormNonConstant.FusedBatchNormNonConstant'>
[ INFO ]  New subclass: <class 'extensions.middle.FusedBatchNormTrainingCatch.FusedBatchNormTrainingCatch'>
[ INFO ]  New subclass: <class 'extensions.middle.GRURNNSequenceToTensorIterator.GRUAndRNNToTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.middle.GatherNdNormalizer.GatherNdNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.GemmResolver.GemmResolver'>
[ INFO ]  New subclass: <class 'extensions.middle.GemmToFullyConnected.GemmToFullyConnected'>
[ INFO ]  New subclass: <class 'extensions.middle.GroupNorm.GroupNormToMVN'>
[ INFO ]  New subclass: <class 'extensions.middle.InputCut.MiddleInputCut'>
[ INFO ]  New subclass: <class 'extensions.middle.L2NormToNorm.L2NormToNorm'>
[ INFO ]  New subclass: <class 'extensions.middle.RNNSequenceNormalizeToIE.RNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.LSTMRNNSequenceToTensorIterator.LSTMToTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.middle.MXNetRNNSequenceNormalize.MXNetRNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.MXNetSplitMultiLayers.MXNetSplitLayersToRNNSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.MinimumMiddleReplacer.MinimumMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.NasNet.NasNet'>
[ INFO ]  New subclass: <class 'extensions.middle.NormalizeFullyConnected.NormalizeFullyConnected'>
[ INFO ]  New subclass: <class 'extensions.middle.NormalizePad.NormalizePad'>
[ INFO ]  New subclass: <class 'extensions.middle.ONNXRNNSequenceNormalize.ONNXRNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ReluFakeQuantizeMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ClampQuantizeMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ReluQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveDuplicationMemory.RemoveMemoryDuplicationPattern'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveRedundantReshapeAfterCropAndResize.RemoveRedundantReshapeAfterCropAndResize'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveUselessCrops.RemoveUselessCropsPattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetWithMemoryNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceSpliceNodePattern.ReplaceSpliceNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReverseTransposeNormalization.ReverseTransposeNormalization'>
[ INFO ]  New subclass: <class 'extensions.middle.ReverseV2ToReverseSequence.ReverseToReverseSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.ScaleInput.ScaleInput'>
[ INFO ]  New subclass: <class 'extensions.middle.SharedWeightsDuplication.SharedWeightsDuplication'>
[ INFO ]  New subclass: <class 'extensions.middle.ShuffleChannel.ShuffleChannel'>
[ INFO ]  New subclass: <class 'extensions.middle.SwapAxesMiddleReplacer.SwapAxisMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.SmartInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.SimpleInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.BackEdgeSimpleInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.SwitchMergeOptimization.SwitchMergeMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.TF_lstm_cell_to_generic.TensorFlowLSTMtoGeneric'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorBackEdge.BackEdgesMatching'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorConditionChecker.ConditionChecks'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorLSTMToLSTMSequence.TensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorOutput.SmartOutputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorOutput.SimpleOutputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TileReplacer.TileMultipleAxisReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.UpsampleToResample.UpsampleToResample'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessMerge.UselessMergeEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessSplitEraser.UselessSplitEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessStridedSlice.UselessStridedSliceEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.PreMiddleStart'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.MiddleStart'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.MiddleFinish'>
[ INFO ]  New subclass: <class 'extensions.middle.permute_tensor_iterator.TransposeTensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.quantize_fuses.MarkNodesToFuseUpToFakeQuantize'>
[ INFO ]  New subclass: <class 'extensions.middle.quantize_fuses.FakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.reverse_tensor_iterator.ReverseTensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.space_to_depth.SpaceToDepth'>
[ INFO ]  New subclass: <class 'extensions.middle.ssd_anchors_to_const.SsdAnchorsMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.wights_permute_normalizer.WeightsPermuteNormalizer'>
[ WARNING ]  Skipped <class 'extensions.back.CreateConstNodes.CreateConstNodesReplacement'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.FuseReshapesSequence.FuseReshapesSequence'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.InsertLayoutPropagationTransposes.InsertLayoutPropagationTranspose'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.RemoveRedundantReshapes.RemoveRedundantReshapes'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.LayoutChangeForConstantShapePaths.LayoutChangeForConstantShapePaths'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.back.ActivationsNormalizer.ActivationsNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.AvgPool.AvgPool'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionNormalizer.ConvolutionNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.EltwiseBroadcast.EltwiseBroadcast'>
[ INFO ]  New subclass: <class 'extensions.back.ForceStrictPrecision.ForceStrictPrecision'>
[ INFO ]  New subclass: <class 'extensions.back.FuseTransposesSequence.FuseTransposesSequence'>
[ INFO ]  New subclass: <class 'extensions.back.OptimizeTransposeReshapeSequence.OptimizeTransposeReshapeSequence'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.ReshapeMutation'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.FlattenMutation'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.DisableReshapeMutationInTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionReshaper.ConvolutionReshaper'>
[ INFO ]  New subclass: <class 'extensions.back.CropToStridedSlice.CropToStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.back.DumpFakeQuantStat.DumpFakeQuantStat'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.SimpleEltwiseToEltwiseOp'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.DivideToEltwises'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.SubtractToEltwises'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.EltwisesWithScalarInputToPower'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.AddPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.EnableConstantStridedSlice.EnableConstantStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.back.GroupedConvWeightsNormalize.GroupedConvWeightsNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.InterpolateToInterpOrResample.InterpolateToInterpOrResample'>
[ INFO ]  New subclass: <class 'extensions.back.LRNToNorm.LRNToNorm'>
[ INFO ]  New subclass: <class 'extensions.back.LeakyReluToReluWithNegativeSlope.LeakyReluToReluWithNegativeSlope'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.MatMulNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.MaxPool.MaxPool'>
[ INFO ]  New subclass: <class 'extensions.back.NormalizeToNormalizeL2.NormalizeToNormalizeL2'>
[ INFO ]  New subclass: <class 'extensions.back.PackBinaryWeights.PackBinaryWeights'>
[ INFO ]  New subclass: <class 'extensions.back.PadNormalizer.PadNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.ParameterToPlaceholder.ParameterToInput'>
[ INFO ]  New subclass: <class 'extensions.back.RNNSequenceTypeRename.RNNSequence'>
[ INFO ]  New subclass: <class 'extensions.back.ReduceToPooling.ReduceReplacer'>
[ INFO ]  New subclass: <class 'extensions.back.ReduceTransposeDimensions.ReduceTransposeDimensions'>
[ INFO ]  New subclass: <class 'extensions.back.RepackFCWeightsNHWCToNCHW.RepackFCWeightsNHWCToNCHW'>
[ INFO ]  New subclass: <class 'extensions.back.ResultNormalizer.ResultNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.ScalarConstNormalize.ScalarNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.ScalarConstNormalize.ScalarNormalizeForSpecificOps'>
[ INFO ]  New subclass: <class 'extensions.back.SelectBroadcast.SelectBroadcast'>
[ INFO ]  New subclass: <class 'extensions.back.SelectInputNormalizer.SelectInputNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.ShapeOfToShape.ShapeOfToShape'>
[ INFO ]  New subclass: <class 'extensions.back.TransposeToPermute.TransposeToPermute'>
[ INFO ]  New subclass: <class 'extensions.back.ShuffleChannelPatternOptimization.ShuffleChannelPatternOptimization'>
[ INFO ]  New subclass: <class 'extensions.back.ShufflenetReLUReorder.ShufflenetReLUReorder'>
[ INFO ]  New subclass: <class 'extensions.back.TileReshaper.TileReshaper'>
[ INFO ]  New subclass: <class 'extensions.back.TopKNormalizer.TopKNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.TransposeFCWeights.TransposeFCWeights'>
[ INFO ]  New subclass: <class 'extensions.back.blob_normalizer.BlobNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.disable_unsupported_ND_operations.DisableUnsupportedNDOperations'>
[ INFO ]  New subclass: <class 'extensions.back.insert_compatibility_l2normalization.CompatibilityL2NormalizationPattern'>
[ INFO ]  New subclass: <class 'extensions.back.kaldi_remove_memory_output.KaldiRemoveMemoryOutputBackReplacementPattern'>
[ INFO ]  New subclass: <class 'extensions.back.priorbox_mutation.PriorboxMutation'>
[ INFO ]  New subclass: <class 'extensions.back.remove_last_softmax_pattern.RemoveLastSoftMaxPattern'>
[ 2019-08-21 15:09:22,223 ] [ DEBUG ] [ class_registration:48 ]  All replacers has unique idxs.
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_44/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/ExpandDims_11547/Dims
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/ExpandDims_/Dims
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/ExpandDims_11544/Dims
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/ExpandDims_/Dims
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_11541/Dims
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_11540/Dims
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,517 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_11539/Dims
[ 2019-08-21 15:11:16,519 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/ExpandDims_11536/Dims
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/ExpandDims_/Dims
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/ExpandDims_11533/Dims
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/ExpandDims_/Dims
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/ExpandDims_11530/Dims
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/ExpandDims_/Dims
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_11527/Dims
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_11526/Dims
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,528 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_11525/Dims
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_11522/Dims
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_11521/Dims
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_11520/Dims
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_11517/Dims
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_11516/Dims
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_11515/Dims
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,539 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/ExpandDims_11512/Dims
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/ExpandDims_/Dims
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_11509/Dims
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_11508/Dims
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_11507/Dims
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_11504/Dims
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_11503/Dims
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_11502/Dims
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_11499/Dims
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,550 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_11498/Dims
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_11497/Dims
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/ExpandDims_11494/Dims
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/ExpandDims_/Dims
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_11491/Dims
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_11490/Dims
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_11489/Dims
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/ExpandDims_11486/Dims
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/ExpandDims_/Dims
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/ExpandDims_11483/Dims
[ 2019-08-21 15:11:16,562 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/ExpandDims_/Dims
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_11480/Dims
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_11479/Dims
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_11478/Dims
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_11475/Dims
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_11474/Dims
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_11473/Dims
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_/Dims
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/ExpandDims_11470/Dims
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/ExpandDims_/Dims
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11467
[ 2019-08-21 15:11:16,574 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 -1]
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11465
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11463
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11461
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11459
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11457
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11455
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11453
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11451
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11449
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11447
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11445
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11443
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11441
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11439
[ 2019-08-21 15:11:16,586 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,588 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11437
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11435
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11433
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11431
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11429
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11427
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11425
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11423
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11421
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11419
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11417
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,597 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,599 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11415
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11413
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11411
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11409
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11407
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11405
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11403
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11401
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11399
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11397
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11395
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11393
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11391
[ 2019-08-21 15:11:16,608 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,610 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11389
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11387
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11385
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11383
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11381
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11379
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11377
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11375
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11373
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11371
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11369
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11367
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11365
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11363
[ 2019-08-21 15:11:16,621 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11361
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11359
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11357
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11355
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11353
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11351
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11349
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11347
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11345
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11343
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11341
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11339
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11337
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11335
[ 2019-08-21 15:11:16,632 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11333
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11331
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11329
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11327
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11325
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11323
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11321
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11319
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11317
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11315
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11313
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11311
[ 2019-08-21 15:11:16,643 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11309
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11307
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11305
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11303
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11301
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11299
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11297
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11295
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11293
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11291
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11289
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11287
[ 2019-08-21 15:11:16,654 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11285
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11283
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11281
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11279
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_89/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_88/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_87/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_86/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_85/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_84/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_83/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_82/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,663 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_81/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_80/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_79/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_78/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_77/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_76/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_75/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_74/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_73/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_72/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_71/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,674 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,676 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,676 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_70/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_69/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_68/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_67/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_66/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_65/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_64/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_63/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_62/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_61/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_60/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,685 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,687 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,687 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_59/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_58/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_57/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_56/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_55/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_54/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_53/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_52/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_51/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_50/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_49/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,696 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,698 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_48/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,698 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_47/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_46/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_45/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_44/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_43/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_42/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_41/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_40/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_39/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_38/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_37/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_36/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,707 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,709 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_35/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_34/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_33/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_32/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_31/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_30/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_29/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_28/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_27/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,718 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,720 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_26/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,720 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_25/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_24/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_23/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_22/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_21/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_20/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_19/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_18/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_17/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_16/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,729 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,731 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,731 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_15/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_14/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_13/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_12/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_11/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_10/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_9/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_8/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_7/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_6/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_5/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,740 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,742 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_4/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_3/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_2/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_1/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze_3/Dims
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze_2/Dims
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze_1/Dims
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze/Dims
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Squeeze/Dims
[ 2019-08-21 15:11:16,753 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,753 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:130 ]  Partial infer for add/y
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/delta
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/start
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_2/range/delta
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_2/range/start
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_1/range/delta
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_1/range/start
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/start
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_89/shape
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_89/begin
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 89]
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_89/1
[ 2019-08-21 15:11:16,762 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,764 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_89/ExpandDims_1162012508
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_88/shape
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_88/begin
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 88]
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_88/1
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_88/ExpandDims_1173312674
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_87/shape
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_87/begin
[ 2019-08-21 15:11:16,773 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,775 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 87]
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_87/1
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_87/ExpandDims_1218013344
[ 2019-08-21 15:11:16,777 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,777 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,777 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_86/shape
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_86/begin
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 86]
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_86/1
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_86/ExpandDims_1201413096
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_85/shape
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_85/begin
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 85]
[ 2019-08-21 15:11:16,784 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/1
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/ExpandDims_1154712398
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_84/shape
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_84/begin
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 84]
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_84/1
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_84/ExpandDims_1222013404
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_83/shape
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_83/begin
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 83]
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_83/1
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_83/ExpandDims_1193112972
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,795 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,798 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,798 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,798 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_82/shape
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_82/begin
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 82]
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_82/1
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_82/ExpandDims_1177312732
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,803 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,803 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_81/shape
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_81/begin
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 81]
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_81/1
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_81/ExpandDims_1166112568
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,807 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,809 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_80/shape
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_80/begin
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 80]
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_80/1
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_80/ExpandDims_1227913494
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_79/shape
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_79/begin
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 79]
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_79/1
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_79/ExpandDims_1194812996
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,818 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_78/shape
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_78/begin
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 78]
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_78/1
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_78/ExpandDims_1212813268
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_77/shape
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_77/begin
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 77]
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_77/1
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_77/ExpandDims_1199513068
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,829 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_76/shape
[ 2019-08-21 15:11:16,831 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,832 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,832 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,832 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_76/begin
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 76]
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_76/1
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_76/ExpandDims_1216113316
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_75/shape
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_75/begin
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 75]
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_75/1
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_75/ExpandDims_1165812564
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,840 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,842 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_74/shape
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_74/begin
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 74]
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_74/1
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_74/ExpandDims_1164612548
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_73/shape
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_73/begin
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 73]
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_73/1
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_73/ExpandDims_1210013228
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_72/shape
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_72/begin
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 72]
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/1
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/ExpandDims_1153312378
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_71/shape
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_71/begin
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 71]
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_71/1
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_71/ExpandDims_1210313232
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,862 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_70/shape
[ 2019-08-21 15:11:16,864 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_70/begin
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,866 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,866 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 70]
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_70/1
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_70/ExpandDims_1165212556
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_69/shape
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_69/begin
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 69]
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_69/1
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_69/ExpandDims_1227313486
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,873 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,875 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_68/shape
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_68/begin
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 68]
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_68/1
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,879 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,879 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_68/ExpandDims_1210613236
[ 2019-08-21 15:11:16,879 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_67/shape
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_67/begin
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 67]
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_67/1
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,883 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_67/ExpandDims_1180412780
[ 2019-08-21 15:11:16,883 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,883 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,884 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_66/shape
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_66/begin
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 66]
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/1
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/ExpandDims_1149412318
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,891 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,891 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,891 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_65/shape
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_65/begin
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 65]
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/1
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/ExpandDims_1148612306
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,895 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,897 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_64/shape
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_64/begin
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 64]
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/1
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/ExpandDims_1148312302
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_63/shape
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_63/begin
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 63]
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_63/1
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_63/ExpandDims_1201113092
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,906 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,908 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_62/shape
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_62/begin
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 62]
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_62/1
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_62/ExpandDims_1191812952
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_61/shape
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_61/begin
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 61]
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_61/1
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_61/ExpandDims_1172712666
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_60/shape
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,917 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_60/begin
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 60]
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_60/1
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,922 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,922 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_60/ExpandDims_1199813072
[ 2019-08-21 15:11:16,922 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_59/shape
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_59/begin
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 59]
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_59/1
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_59/ExpandDims_1160712488
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_58/shape
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,928 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,930 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_58/begin
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 58]
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_58/1
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_58/ExpandDims_1160412484
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,933 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,933 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_57/shape
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_57/begin
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 57]
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/1
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/ExpandDims_1151212346
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_56/shape
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,939 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,941 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,941 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_56/begin
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 56]
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_56/1
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_56/ExpandDims_1212213260
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_55/shape
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_55/begin
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 55]
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_55/1
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_55/ExpandDims_1197713040
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_54/shape
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_54/begin
[ 2019-08-21 15:11:16,950 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 54]
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_54/1
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_54/ExpandDims_1157512440
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_53/shape
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_53/begin
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 53]
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_53/1
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_53/ExpandDims_1217713340
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_52/shape
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_52/begin
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 52]
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_52/1
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,966 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_52/ExpandDims_1221713400
[ 2019-08-21 15:11:16,966 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,966 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_51/shape
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_51/begin
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 51]
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_51/1
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_51/ExpandDims_1205313156
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_50/shape
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_50/begin
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 50]
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_50/1
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_50/ExpandDims_1214513292
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,974 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_49/shape
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_49/begin
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 49]
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_49/1
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_49/ExpandDims_1187012880
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_48/shape
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_48/begin
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 48]
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_48/1
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_48/ExpandDims_1187312884
[ 2019-08-21 15:11:16,984 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,984 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,987 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_47/shape
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_47/begin
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 47]
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_47/1
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_47/ExpandDims_1205613160
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_46/shape
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_46/begin
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 46]
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_46/1
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_46/ExpandDims_1173612678
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_45/shape
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,996 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_45/begin
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 45]
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_45/1
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_45/ExpandDims_1194212988
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,002 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,002 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,002 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_44/shape
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_44/begin
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 44]
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_44/1
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_44/ExpandDims_1157812444
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_43/shape
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,010 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_43/begin
[ 2019-08-21 15:11:17,010 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 43]
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_43/1
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_43/ExpandDims_1171612650
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_42/shape
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_42/begin
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 42]
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_42/1
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_42/ExpandDims_1160112480
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_41/shape
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,019 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,021 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_41/begin
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 41]
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_41/1
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_41/ExpandDims_1170312630
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,024 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,024 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,024 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_40/shape
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_40/begin
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 40]
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_40/1
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_40/ExpandDims_1223513426
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_39/shape
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,030 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,032 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,033 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,033 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_39/begin
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 39]
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_39/1
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,036 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,036 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_39/ExpandDims_1163812536
[ 2019-08-21 15:11:17,036 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_38/shape
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_38/begin
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 38]
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_38/1
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_38/ExpandDims_1217413336
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,041 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,043 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_37/shape
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_37/begin
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 37]
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_37/1
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,046 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,046 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_37/ExpandDims_1220613384
[ 2019-08-21 15:11:17,046 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_36/shape
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_36/begin
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 36]
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_36/1
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_36/ExpandDims_1181812800
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,051 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,051 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,052 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,054 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,054 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_35/shape
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_35/begin
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 35]
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_35/1
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_35/ExpandDims_1176612722
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_34/shape
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_34/begin
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 34]
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_34/1
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_34/ExpandDims_1173912682
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_33/shape
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,063 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_33/begin
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 33]
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_33/1
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_33/ExpandDims_1168012596
[ 2019-08-21 15:11:17,069 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,069 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,069 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_32/shape
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_32/begin
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 32]
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_32/1
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,073 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,073 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_32/ExpandDims_1175812710
[ 2019-08-21 15:11:17,073 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_31/shape
[ 2019-08-21 15:11:17,075 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_31/begin
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 31]
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_31/1
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_31/ExpandDims_1195113000
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_30/shape
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_30/begin
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 30]
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_30/1
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_30/ExpandDims_1191512948
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_29/shape
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_29/begin
[ 2019-08-21 15:11:17,086 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,088 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 29]
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/1
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/ExpandDims_1153012374
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_28/shape
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_28/begin
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 28]
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_28/1
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_28/ExpandDims_1204013136
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_27/shape
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_27/begin
[ 2019-08-21 15:11:17,097 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 27]
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_27/1
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_27/ExpandDims_1210913240
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,102 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,102 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,102 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_26/shape
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_26/begin
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 26]
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_26/1
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_26/ExpandDims_1213713280
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_25/shape
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_25/begin
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 25]
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_25/1
[ 2019-08-21 15:11:17,112 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,112 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_25/ExpandDims_1178112744
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_24/shape
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_24/begin
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 24]
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_24/1
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_24/ExpandDims_1169512618
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_23/shape
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_23/begin
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 23]
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_23/1
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,121 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_23/ExpandDims_1173012670
[ 2019-08-21 15:11:17,123 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,124 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,124 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,124 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_22/shape
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_22/begin
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 22]
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_22/1
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_22/ExpandDims_1183912832
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_21/shape
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_21/begin
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 21]
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_21/1
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_21/ExpandDims_1166412572
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,132 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_20/shape
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_20/begin
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 20]
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/1
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/ExpandDims_1153612382
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_19/shape
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_19/begin
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 19]
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_19/1
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_19/ExpandDims_1185212852
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_18/shape
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_18/begin
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 18]
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/1
[ 2019-08-21 15:11:17,144 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/ExpandDims_1147012282
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_17/shape
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_17/begin
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 17]
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_17/1
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_17/ExpandDims_1213413276
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_16/shape
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_16/begin
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 16]
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_16/1
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_16/ExpandDims_1189712920
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,156 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_15/shape
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_15/begin
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 15]
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_15/1
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_15/ExpandDims_1220313380
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_14/shape
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_14/begin
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 14]
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_14/1
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_14/ExpandDims_1165512560
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_13/shape
[ 2019-08-21 15:11:17,166 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,169 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,169 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,169 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_13/begin
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 13]
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_13/1
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_13/ExpandDims_1195913012
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_12/shape
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_12/begin
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 12]
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_12/1
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_12/ExpandDims_1156012418
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_11/shape
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_11/begin
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 11]
[ 2019-08-21 15:11:17,178 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_11/1
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,182 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_11/ExpandDims_1171912654
[ 2019-08-21 15:11:17,182 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_10/shape
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_10/begin
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 10]
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_10/1
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_10/ExpandDims_1193412976
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_9/shape
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,191 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,191 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_9/begin
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 9]
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_9/1
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_9/ExpandDims_1180712784
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_8/shape
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_8/begin
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 8]
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_8/1
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_8/ExpandDims_1167712592
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_7/shape
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_7/begin
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,200 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 7]
[ 2019-08-21 15:11:17,202 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_7/1
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,204 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_7/ExpandDims_1187612888
[ 2019-08-21 15:11:17,204 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,204 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_6/shape
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_6/begin
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 6]
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_6/1
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_6/ExpandDims_1213113272
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_5/shape
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_5/begin
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 5]
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_5/1
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_5/ExpandDims_1188912908
[ 2019-08-21 15:11:17,211 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,214 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,214 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_4/shape
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_4/begin
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 4]
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_4/1
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_4/ExpandDims_1227613490
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_3/shape
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_3/begin
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 3]
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_3/1
[ 2019-08-21 15:11:17,222 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,225 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,225 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_3/ExpandDims_1175012698
[ 2019-08-21 15:11:17,225 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_2/shape
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_2/begin
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 2]
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_2/1
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_2/ExpandDims_1215813312
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_1/shape
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_1/begin
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_1/1
[ 2019-08-21 15:11:17,233 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_1/ExpandDims_1208813210
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape/shape
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice/begin
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/1
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_1194512992
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,241 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,241 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,241 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/Const
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/Enter
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/Merge
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/delta
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,245 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/start
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_2
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_1
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/delta
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/start
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_2
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_1
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/delta
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/start
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,259 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack_2
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack_1
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,268 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,271 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,271 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_2/stack_2
[ 2019-08-21 15:11:17,271 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,272 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,272 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,272 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_2/stack_1
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 2]
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_2/stack
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_1/stack_2
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_1/stack_1
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_1/stack
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_6/shape
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ -1 100  90]
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice_1/size
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [-1 -1 -1]
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice_1/begin
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [0 0 1]
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/concat/axis
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/concat/values_0
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice/size
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/scale_logits/y
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/scale_logits/reciprocal_
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/3
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/ExpandDims_1226013466
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/2
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 90
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/ExpandDims_1225913464
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 90
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [90]
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/1
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/ExpandDims_1225813462
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,291 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [100]
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_7/y
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_7/reciprocal_
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_6/y
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_6/reciprocal_
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_5/y
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_5/reciprocal_
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_4/y
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_4/reciprocal_
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_3/y
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_3/reciprocal_
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_2/y
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,303 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,305 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_2/reciprocal_
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_1/y
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_1/reciprocal_
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div/y
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div/reciprocal_
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div_1/y
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div_1/reciprocal_
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div/y
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div/reciprocal_
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_3/shape
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,317 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,317 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_2/shape
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Tile/multiples
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [ 1  1 90  1]
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/ExpandDims/dim
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice/stack_2
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice/stack_1
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice/stack
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_1/shape
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ -1 100  91]
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape/shape
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [ -1 100  90   4]
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/Const
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,326 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/while/Enter
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/while/Merge
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/strided_slice/stack
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,337 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,339 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/Reshape_1/shape
[ 2019-08-21 15:11:17,339 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [-1  1 91]
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/Reshape/shape
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [-1  1 90  4]
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/AvgPool/reduction_indices
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 2]
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:130 ]  Partial infer for CropAndResize/crop_size
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [14 14]
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:130 ]  Partial infer for Reshape_6/shape
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_6/dim
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:130 ]  Partial infer for range/delta
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:130 ]  Partial infer for range/start
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_15/stack_2
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_15/stack_1
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_15/stack
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,348 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:130 ]  Partial infer for ones/Const
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_14/stack_2
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_14/stack_1
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_14/stack
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/1
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/ExpandDims_1154412394
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,356 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,356 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,356 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:130 ]  Partial infer for mul/y
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_13/stack_2
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_13/stack_1
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,360 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_13/stack
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/Const
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/while/Enter
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/while/Merge
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/range/delta
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/range/start
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/strided_slice/stack
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,372 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,374 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/strided_slice/stack
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/strided_slice/stack_2
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/strided_slice/stack_1
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/strided_slice/stack
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/delta
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/start
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,383 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape/shape
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice/begin
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/1
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_1220913388
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/Const
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/Enter
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/Merge
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/delta
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/start
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,395 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_2
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_1
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/delta
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/start
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_2
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_1
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/delta
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/start
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,407 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/strided_slice/stack_2
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/strided_slice/stack_1
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/strided_slice/stack
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/ones/Const
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice_1/stack_2
[ 2019-08-21 15:11:17,420 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,420 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice_1/stack_1
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice_1/stack
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice/stack_2
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice/stack_1
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice/stack
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_5/dim
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_4/dim
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_12/stack_2
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_12/stack_1
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 2]
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_12/stack
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_11/stack_2
[ 2019-08-21 15:11:17,431 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,431 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_11/stack_1
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_11/stack
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_10/stack_2
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [1 1 1]
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_10/stack_1
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [0 0 2]
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [0 0 1]
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:130 ]  Partial infer for concat/axis
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:130 ]  Partial infer for concat/values_0
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:130 ]  Partial infer for Slice/size
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/3
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/ExpandDims_1172412662
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,439 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,439 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,440 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,442 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/2
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,444 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,444 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/ExpandDims_1172312660
[ 2019-08-21 15:11:17,444 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_7/y
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_7/reciprocal_
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_6/y
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_6/reciprocal_
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_5/y
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,451 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,453 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_5/reciprocal_
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_4/y
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_4/reciprocal_
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_3/y
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_3/reciprocal_
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_2/y
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_2/reciprocal_
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_1/y
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_1/reciprocal_
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div/y
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,462 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div/reciprocal_
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div_1/y
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div_1/reciprocal_
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div/y
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div/reciprocal_
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:130 ]  Partial infer for Reshape_1/shape
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:130 ]  Partial infer for Reshape/shape
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_2/multiples
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [1 1 1 1]
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_3/dim
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_9/stack_2
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_9/stack_1
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,474 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,476 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_8/stack_2
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_8/stack_1
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_8/stack
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/2
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/ExpandDims_1209713224
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/1
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/ExpandDims_1209613222
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,483 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,483 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,483 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_2/dim
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_6/stack_2
[ 2019-08-21 15:11:17,485 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_6/stack_1
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_6/stack
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_1/dim
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile/multiples/1
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile/multiples/ExpandDims_1181012788
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_5/stack_2
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_5/stack_1
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims/dim
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_4/stack_2
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_4/stack_1
[ 2019-08-21 15:11:17,497 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,499 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_4/stack
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Reshape/shape
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Greater/y
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.0
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Area/split/split_dim
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/concat/axis
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/split/split_dim
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/1
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/ExpandDims_1225313454
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/0
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/ExpandDims_13452
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_3/stack_2
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_3/stack_1
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_3/stack
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_2/stack_2
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_2/stack_1
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack_1/2
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack_1/ExpandDims_1177012728
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/mul_3/y
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,519 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 12
[ 2019-08-21 15:11:17,521 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,521 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/3
[ 2019-08-21 15:11:17,521 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/ExpandDims_1167412588
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/2
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/ExpandDims_1167312586
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/mul_1/y
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 12
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_2/stack_2
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_2/stack_1
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_1/stack_2
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_1/stack_1
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice/stack_2
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice/stack_1
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice/stack
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:130 ]  Partial infer for Conv/weights
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,539 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   3    3 1024  512], value = [[[[ 2.99645518e-03  1.42790871e-02 -9.73897986e-04 ...  5.27989957e-03
     1.17567473e-03 -5.48...
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:130 ]  Partial infer for Conv/weights/read
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,543 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [   3    3 1024  512], value = [[[[ 2.99645518e-03  1.42790871e-02 -9.73897986e-04 ...  5.27989957e-03
[ 2019-08-21 15:11:17,544 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   3    3 1024  512], value = [[[[ 2.99645518e-03  1.42790871e-02 -9.73897986e-04 ...  5.27989957e-03
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/concat/axis
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/mul_6/x
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/mul_5/x
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Reshape_3/shape
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  2]
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Reshape_2/shape
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/concat/axis
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/Slice_1/size
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/Slice/begin
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/concat/axis
[ 2019-08-21 15:11:17,553 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,555 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/Slice_1/size
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/Slice/begin
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/concat/axis
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/Slice_1/size
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/Slice/begin
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/concat/axis
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/Slice_1/size
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/Slice/begin
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range_1/delta
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range_1/start
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range/delta
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range/start
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,564 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_1/stack_2
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_1/stack_1
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_1/stack
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice/stack_2
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice/stack_1
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice/stack
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/Pad/paddings
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4 2], value = [[0 0]
 [1 1]
 [1 1]
 [0 0]]
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/Pad/paddings
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4 2], value = [[0 0]
 [1 1]
 [1 1]
 [0 0]]
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/Pad/paddings
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4 2], value = [[0 0]
 [3 3]
 [3 3]
 [0 0]]
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/sub/y
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1 1 3], value = [[[123.68  116.779 103.939]]]
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/sub/negate_
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:131 ]  Op: Mul
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [1 1 3], value = [[[123.68  116.779 103.939]]]
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1
[ 2019-08-21 15:11:17,576 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,579 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1 1 3], value = [[[-123.68  -116.779 -103.939]]]
[ 2019-08-21 15:11:17,579 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,579 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack_1/range/delta
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack_1/range/start
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/Const
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Enter
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Merge
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,588 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice/stack_2
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice/stack_1
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice/stack
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/conv1/weights/read/_502__cf__508
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,599 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 7  7  3 64], value = [[[[ 4.64108249e-04 -1.74941553e-04 -1.95158224e-04 ...  1.61375152e-04
     4.36045288e-04 -2.63...
[ 2019-08-21 15:11:17,599 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,600 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,603 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,603 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,603 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [ 1.3811203   1.0502448  -1.540443    5.452084    3.9308462   3.6434348
  2.334713   -1.9265155  ...
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/conv1/weights/read/_497__cf__503
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,605 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 1  1 64 64], value = [[[[ 0.00031623 -0.01128012  0.01996796 ...  0.05222897  0.00173036
    -0.05491556]
   [ 0.05375...
[ 2019-08-21 15:11:17,605 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,605 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-2.4751043e+00  3.9588630e-02 -1.8484299e+00  3.5001514e+00
 -1.5810425e+00  5.3505678e+00  3.14...
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/conv2/weights/read/_492__cf__498
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,609 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 3  3 64 64], value = [[[[-3.55904340e-05 -5.05569438e-03  9.64875612e-03 ... -2.76672356e-02
     6.59038022e-04 -5.97...
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,611 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-0.7343422   0.8418256   3.7955399   0.900686    2.051835    2.3549833
 -0.88262045 -1.578823   ...
[ 2019-08-21 15:11:17,614 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,614 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/conv3/weights/read/_487__cf__493
[ 2019-08-21 15:11:17,614 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,615 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,615 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[ 4.30948194e-06 -1.33537435e-06  2.20004907e-07 ... -1.22277243e-06
     2.51581191e-08  1.48...
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,618 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [  0.424349    -1.972537     1.3978754   -0.7982131    2.4827313
  -0.15707403  -0.74834514   2.0...
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/shortcut/weights/read/_507__cf__513
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[-0.0224003  -0.01278749 -0.01815509 ... -0.03889255  0.03967233
    -0.0447415 ]
   [-0.01585...
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,621 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,622 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 8.59432817e-02  1.44665825e+00  3.55349970e+00 -1.94488358e+00
  4.73191977e+00  2.60677481e+00...
[ 2019-08-21 15:11:17,622 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,623 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_2/bottleneck_v1/conv1/weights/read/_482__cf__488
[ 2019-08-21 15:11:17,625 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,626 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,626 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,626 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256  64], value = [[[[ 4.63978686e-05 -4.76801688e-05  6.97050473e-06 ...  9.23398966e-06
     1.11675663e-05  5.53...
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-1.9465362e+00 -2.3402996e+00  5.8809769e-01  7.2492504e-01
 -5.4025662e-01  5.2374399e-01 -6.46...
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_2/bottleneck_v1/conv2/weights/read/_477__cf__483
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 3  3 64 64], value = [[[[ 4.45543565e-02 -2.64205672e-02  2.18123924e-02 ... -6.17487682e-03
     1.30373263e-03  1.34...
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,632 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,632 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-0.5421555  -0.77099836  2.6010833   0.95333755 -1.5628878   2.0529711
 -0.21615231 -1.7814732  ...
[ 2019-08-21 15:11:17,632 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_2/bottleneck_v1/conv3/weights/read/_472__cf__478
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,634 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[-0.00893994 -0.03818517 -0.01459556 ... -0.00323571  0.15353067
     0.08434541]
   [-0.00432...
[ 2019-08-21 15:11:17,636 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.56972611e-01  3.90341222e-01 -1.99360085e+00 -3.62123370e-01
 -7.77979493e-02  1.80408776e-01...
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_3/bottleneck_v1/conv1/weights/read/_467__cf__473
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,640 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,640 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,640 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256  64], value = [[[[ 5.0230687e-05 -7.3706848e-05  1.3710212e-04 ...  9.9079574e-05
    -5.8603277e-05 -8.5390806...
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-1.3790115   0.7470263  -0.16422507 -0.27383205 -1.6613547  -0.05829925
  0.06354634  1.0735474 ...
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_3/bottleneck_v1/conv2/weights/read/_462__cf__468
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,645 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 3  3 64 64], value = [[[[-1.27601977e-02 -3.24738733e-02  5.49894981e-02 ... -2.21614763e-02
     3.83016057e-02 -4.01...
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,649 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-2.08606929e-01 -1.90749019e-01 -5.89796126e-01  8.77718925e-02
 -4.78530601e-02  1.27046812e+00...
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_3/bottleneck_v1/conv3/weights/read/_457__cf__463
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[-3.1780124e-01 -4.9120084e-05  3.8937628e-02 ...  1.7965302e-01
     9.4941501e-03 -2.2689693...
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,652 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,652 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,653 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 2.93428206e+00 -4.96919407e-03 -1.60695672e+00  2.57921720e+00
  2.69810051e-01 -1.83299184e-04...
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/conv1/weights/read/_452__cf__458
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256 128], value = [[[[ 0.01242925 -0.01617105  0.01928404 ... -0.03529073  0.12490322
     0.01086236]
   [ 0.00119...
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,656 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 5.9609628e-01  9.8397374e-01  2.4939221e-01 -1.0748929e+00
 -2.2251666e+00  2.3392036e+00 -2.45...
[ 2019-08-21 15:11:17,656 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,656 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/conv2/weights/read/_447__cf__453
[ 2019-08-21 15:11:17,657 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,659 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,660 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[-6.27585053e-02 -2.27093901e-02 -7.22831255e-03 ...  2.15149907e-04
    -5.87685313e-03 -1.02...
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,663 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,663 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-2.437534    0.03366986  0.8704955  -0.13714042  1.1917963   0.15543246
  3.3507264  -2.0535135 ...
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/conv3/weights/read/_442__cf__448
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[ 3.3026312e-02  9.4565272e-02 -7.8057669e-02 ... -1.8512672e-05
     7.0298538e-03  9.1885731...
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,666 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,666 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,666 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,669 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 1.26984537e-01  2.55484033e+00 -7.68113285e-02  1.21026313e+00
 -1.31856978e+00  1.44113564e+00...
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/shortcut/weights/read/_512__cf__518
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256 512], value = [[[[-0.06350439 -0.00074033  0.19874777 ... -0.07117056 -0.08085252
     0.00090254]
   [-0.02478...
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,673 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,673 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-4.80958641e-01  2.01284215e-01 -3.37211967e+00  2.26378369e+00
  2.90555656e-01  2.42487955e+00...
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_2/bottleneck_v1/conv1/weights/read/_437__cf__443
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,677 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,677 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,677 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 128], value = [[[[ 0.03788782 -0.00450122  0.01117337 ... -0.00831605  0.01049219
     0.00545716]
   [-0.01825...
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,680 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-2.3570065e+00  8.2345062e-01  6.6208571e-01 -8.1076598e-01
 -1.2077824e-01  4.1758227e-01 -1.35...
[ 2019-08-21 15:11:17,682 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,682 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_2/bottleneck_v1/conv2/weights/read/_432__cf__438
[ 2019-08-21 15:11:17,682 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,683 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,683 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,685 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[ 0.00942923 -0.0267888  -0.02339642 ... -0.02133972  0.00591949
    -0.00099709]
   [-0.03661...
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,687 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 4.88662124e-02 -4.10541564e-01 -5.56426644e-02  2.37432480e+00
 -8.22197914e-01 -6.81068778e-01...
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_2/bottleneck_v1/conv3/weights/read/_427__cf__433
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[-0.17786048  0.00280232 -0.00139161 ...  0.06216362  0.02002652
     0.01175307]
   [-0.10157...
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,690 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,690 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,693 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-4.40973341e-02 -5.95078051e-01 -1.18573380e+00 -1.42431101e-02
 -4.23805594e-01  3.00072134e-01...
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_3/bottleneck_v1/conv1/weights/read/_422__cf__428
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 128], value = [[[[-0.00987589 -0.00400306 -0.02098291 ... -0.0148908  -0.00690196
     0.01284756]
   [-0.07214...
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,696 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 7.81671226e-01 -4.98379827e-01  4.89879012e-01 -9.48889554e-02
  5.06000161e-01  5.66401958e-01...
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_3/bottleneck_v1/conv2/weights/read/_417__cf__423
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,698 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,700 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[-0.03417458  0.00853314  0.01176196 ... -0.05733049 -0.0343987
    -0.03268218]
   [-0.019002...
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,702 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-1.21702516e+00 -2.01508045e-01  3.36793423e-01  7.92401135e-02
  4.78265882e-02 -3.93141359e-01...
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_3/bottleneck_v1/conv3/weights/read/_412__cf__418
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[-0.06310017 -0.01471212  0.00044062 ... -0.01175126 -0.11508672
    -0.03335478]
   [-0.03131...
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,707 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,707 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-2.85549760e-01 -2.64841616e-01 -1.58844978e-01 -1.66807985e+00
  2.51951635e-01  2.97003746e-01...
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_4/bottleneck_v1/conv1/weights/read/_407__cf__413
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,711 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,711 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,711 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 128], value = [[[[ 0.0072258  -0.04049483  0.01404724 ... -0.04347908 -0.02087065
    -0.01399305]
   [-0.02546...
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,713 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-9.17880535e-02  5.25092483e-01 -6.40227735e-01 -2.38739252e-01
  3.06392312e-01 -1.48420990e-01...
[ 2019-08-21 15:11:17,714 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,717 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_4/bottleneck_v1/conv2/weights/read/_402__cf__408
[ 2019-08-21 15:11:17,717 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,718 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,718 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,720 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[ 1.90913733e-02  3.55658531e-02  3.88441086e-02 ... -3.77886333e-02
     1.56798551e-03 -1.27...
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,722 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 0.09800774  0.03799695  0.4950545   0.28906214 -0.11270463  0.3860771
 -0.66385466 -0.24618977 ...
[ 2019-08-21 15:11:17,722 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,722 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_4/bottleneck_v1/conv3/weights/read/_397__cf__403
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[-1.6549410e-02 -6.4734765e-03 -3.2181110e-02 ...  6.6934258e-04
     1.2504861e-01 -6.3026050...
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,728 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 2.69558239e+00  1.63806483e-01 -2.18443608e+00  2.31741357e+00
  1.21764183e-01 -2.39354954e-03...
[ 2019-08-21 15:11:17,729 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,729 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/conv1/weights/read/_392__cf__398
[ 2019-08-21 15:11:17,729 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,730 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,730 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,730 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 256], value = [[[[-0.00405173 -0.01054402 -0.03977202 ... -0.00359251 -0.00125046
    -0.02903028]
   [ 0.01140...
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,733 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.7113526   1.0857633   0.8299122  -1.1718578   0.11896931 -0.2419886
 -1.0371301  -0.7652793  ...
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/conv2/weights/read/_387__cf__393
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,737 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-8.71284679e-03  1.81176271e-02 -1.65016558e-02 ...  7.90401921e-03
     2.51549971e-03 -6.15...
[ 2019-08-21 15:11:17,737 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,737 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,738 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,740 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,741 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,742 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.40119505 -0.691105   -0.3883029   1.274854    0.38154036  0.2032451
  0.5815004  -0.9339087  ...
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/conv3/weights/read/_382__cf__388
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.01777647 -0.05629966 -0.00290748 ... -0.05425401  0.03030267
     0.02421303]
   [-0.61191...
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.22093366  1.5324203   0.53350055 ... -0.25482124 -0.24413952
 -0.41256803]
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/shortcut/weights/read/_517__cf__523
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 1024], value = [[[[-0.11115226 -0.00698497 -0.04536846 ... -0.07111143 -0.06974979
     0.03325446]
   [-0.05400...
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.79828227  4.239912   -0.2516005  ...  0.48758242 -0.53584623
  1.6774969 ]
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_2/bottleneck_v1/conv1/weights/read/_377__cf__383
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01133961  0.01263868 -0.00534887 ... -0.00451139 -0.00263864
     0.00249622]
   [ 0.00207...
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,750 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.35520422 -0.7842494  -0.83296835 -0.5839054  -0.43344134  0.1874555
  0.98109436 -0.40291536 ...
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_2/bottleneck_v1/conv2/weights/read/_372__cf__378
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,755 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.19557507e-04 -3.01199791e-04 -8.69192928e-03 ... -6.53646048e-03
     6.96349237e-03 -1.71...
[ 2019-08-21 15:11:17,755 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,755 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,756 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,756 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,756 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.3826265  -0.29609573 -0.44054222 -0.67305017  0.4246816  -0.8633474
 -0.58027685  1.346803   ...
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_2/bottleneck_v1/conv3/weights/read/_367__cf__373
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,759 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,759 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-2.30304687e-03  9.70856100e-03 -1.32876486e-01 ...  3.93917114e-02
     4.69251722e-03  7.28...
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.1793291   0.09759636  0.9659663  ...  0.08486253 -0.9534179
  0.07942396]
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_3/bottleneck_v1/conv1/weights/read/_362__cf__368
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.00382992  0.00216053 -0.0116993  ... -0.01373266 -0.00308101
    -0.00765375]
   [ 0.00565...
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,766 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 7.03340530e-01  1.59973216e+00  3.34033310e-01 -3.61618936e-01
 -1.82068157e+00 -6.56980753e-01...
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_3/bottleneck_v1/conv2/weights/read/_357__cf__363
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,769 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 1.03563378e-02  1.18010370e-02 -4.12396118e-02 ...  1.58134114e-03
    -1.23850713e-02 -4.21...
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,772 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,774 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,776 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 5.79534888e-01 -1.36327744e-02 -5.69676757e-02  2.23652482e-01
 -6.97614253e-01 -3.15594077e-01...
[ 2019-08-21 15:11:17,776 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_3/bottleneck_v1/conv3/weights/read/_352__cf__358
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.02069903 -0.00116222 -0.04376029 ...  0.0524575  -0.0655622
    -0.01419311]
   [ 0.030328...
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.05567572 -0.17946015  0.47063375 ...  0.22522157 -0.5962442
 -0.3664487 ]
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_4/bottleneck_v1/conv1/weights/read/_347__cf__353
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 1.0596439e-02  1.0093055e-02 -5.8755130e-03 ... -6.3341069e-03
    -7.4430043e-03  5.9202602...
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_4/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-8.16664100e-01 -7.59975672e-01 -6.10798597e-04 -1.46581173e-01
 -1.36470631e-01 -2.92771578e-01...
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_4/bottleneck_v1/conv2/weights/read/_342__cf__348
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,785 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 0.02423852 -0.01132412  0.03339144 ... -0.0004745   0.02629062
    -0.00981945]
   [-0.00411...
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_4/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 1.11297297e+00  5.41678667e-02  1.95151865e-01 -9.17464972e-01
 -1.41584456e-01  3.94261926e-01...
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_4/bottleneck_v1/conv3/weights/read/_337__cf__343
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.03947022  0.06245787 -0.03144765 ... -0.06009795 -0.01443091
     0.03650019]
   [ 0.00913...
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_4/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.0762777  -0.55019695  0.60213864 ... -0.09102306 -0.5356765
 -0.3146617 ]
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_5/bottleneck_v1/conv1/weights/read/_332__cf__338
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 2.8684628e-03 -4.5896890e-03 -4.5487178e-03 ...  9.4198771e-03
    -1.0981573e-05 -2.7068988...
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_5/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,792 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,792 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,793 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.8838623   0.5314789  -0.16913846 -1.2915249  -0.17988437 -0.62399304
 -0.29771698 -0.16374615...
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_5/bottleneck_v1/conv2/weights/read/_327__cf__333
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,797 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-3.74361016e-02 -5.09657757e-03 -9.95790397e-05 ...  8.48262198e-03
    -2.95320264e-04  2.10...
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_5/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,800 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.118797   -1.0454847   0.49328157 -0.1204524  -0.8885338  -0.1215387
  0.19107527 -0.23166981 ...
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_5/bottleneck_v1/conv3/weights/read/_322__cf__328
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.00342742  0.14500782 -0.01213852 ... -0.36036238  0.17305407
    -0.00149647]
   [ 0.01594...
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_5/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.10354734  0.00079679  0.44429773 ...  0.12962627 -0.41226017
 -0.5313784 ]
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_6/bottleneck_v1/conv1/weights/read/_317__cf__323
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.00443793 -0.01845037 -0.0061293  ...  0.0058228   0.00357379
     0.00678192]
   [ 0.00046...
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_6/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.7205193   0.42818356 -0.9767865   0.32112375 -1.1003852  -0.15591028
  0.07104766 -1.3628464 ...
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_6/bottleneck_v1/conv2/weights/read/_312__cf__318
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,811 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 0.00986296 -0.00553223  0.02304729 ... -0.01467825 -0.00067494
    -0.01051523]
   [-0.00607...
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_6/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,814 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.28737706  0.02091849  0.13317609 -0.50066096  0.05553234 -0.30614182
  0.23491505 -0.05276984...
[ 2019-08-21 15:11:17,814 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_6/bottleneck_v1/conv3/weights/read/_307__cf__313
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.05125834 -0.06581296 -0.11316475 ... -0.27769384  0.20829429
     0.04256414]
   [ 0.17945...
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_6/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.24281871 -0.22264242  0.22961232 ...  0.20283046 -0.21185799
 -0.73926973]
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_7/bottleneck_v1/conv1/weights/read/_302__cf__308
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,820 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01858268  0.00715097 -0.0063538  ...  0.00998313  0.00643032
     0.00846394]
   [ 0.00264...
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_7/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,822 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,822 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,822 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.16669732  0.7776865  -0.79015565 -1.0900884   0.21281198  0.25894648
 -0.00528789 -1.1452413 ...
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_7/bottleneck_v1/conv2/weights/read/_297__cf__303
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.31164340e-02  2.31752335e-03  3.25918086e-02 ...  1.54007487e-02
     2.68840939e-02  5.78...
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_7/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,829 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 4.45931256e-01 -4.08496857e-02  2.47798562e-02 -2.44028389e-01
  2.18019307e-01  4.32908535e-02...
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_7/bottleneck_v1/conv3/weights/read/_292__cf__298
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,833 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.0195188   0.02067995 -0.00068872 ...  0.52524984  0.26216403
     0.03104902]
   [-0.03791...
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_7/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.3774263  -0.3761122  -0.08942723 ...  0.61681014  0.41731378
 -0.47806782]
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_8/bottleneck_v1/conv1/weights/read/_287__cf__293
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.02978607  0.00581992 -0.00705271 ... -0.00622403  0.00590882
     0.00348403]
   [-0.00958...
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_8/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,837 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,837 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-5.8433825e-01 -9.5147640e-01 -9.5011216e-01 -2.6720712e-01
 -2.9048467e-01  2.6145089e-01 -3.14...
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_8/bottleneck_v1/conv2/weights/read/_282__cf__288
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,842 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 2.08052378e-02  3.60903516e-02  3.89397033e-02 ... -5.07981554e-02
     8.71954020e-04  3.86...
[ 2019-08-21 15:11:17,843 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_8/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.4175248  -0.16458601 -0.7466825  -0.22808975  0.18114522 -0.22137505
  0.22076625  0.29203224...
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_8/bottleneck_v1/conv3/weights/read/_277__cf__283
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.22957745 -0.0885928   0.08172584 ... -0.06124607  0.13293473
    -0.00105588]
   [ 0.04487...
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_8/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.6739772  -0.39573833 -0.14817068 ... -0.4774291  -0.26073232
 -0.32155573]
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_9/bottleneck_v1/conv1/weights/read/_272__cf__278
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.00343918  0.00661883 -0.0056509  ... -0.00288614 -0.00336998
     0.00236383]
   [-0.02325...
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_9/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,852 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.9138236  -0.63814276 -0.5391281  -0.97924423 -0.08791906 -0.7286261
 -1.2555107  -0.59011626 ...
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_9/bottleneck_v1/conv2/weights/read/_267__cf__273
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 1.49458703e-02  7.21594021e-02 -9.10941660e-02 ... -4.49147224e-02
     2.67457832e-02  9.79...
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_9/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,860 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 5.32522678e-01 -2.80919909e-01 -5.60434222e-01  1.71560645e-02
  1.38803571e-01  4.22450304e-01...
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_9/bottleneck_v1/conv3/weights/read/_262__cf__268
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,862 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.0480752   0.02153455 -0.07169733 ... -0.08926089  0.03374584
    -0.16050044]
   [-0.01334...
[ 2019-08-21 15:11:17,862 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,862 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_9/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,866 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,866 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,866 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [0.01975647 0.37272942 0.14801654 ... 0.16525522 0.2137172  3.2086868 ]
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_10/bottleneck_v1/conv1/weights/read/_257__cf__263
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,868 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,868 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,868 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00581512 -0.00726025 -0.01454726 ... -0.01057408 -0.01523411
    -0.01083865]
   [ 0.01108...
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_10/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,871 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.00437874 -1.0407349  -0.20897731  0.8353066   0.00382417 -0.01226807
 -0.1483759  -0.09940428...
[ 2019-08-21 15:11:17,871 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_10/bottleneck_v1/conv2/weights/read/_252__cf__258
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,874 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-5.26833646e-02  3.81134520e-03  2.28320677e-02 ... -2.53645405e-02
     7.87444972e-03 -8.55...
[ 2019-08-21 15:11:17,876 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_10/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.7658075e-01  2.5479272e-01 -9.8050284e-01  4.0418875e-01
 -1.3318160e-01  4.6557549e-01 -1.86...
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_10/bottleneck_v1/conv3/weights/read/_247__cf__253
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 2.07422599e-01 -1.02116644e-01  6.27835169e-02 ...  1.18874684e-01
     1.24141447e-01 -1.45...
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_10/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.1289697   0.08561569  0.21018787 ... -0.3687311  -0.13785255
 -0.05144531]
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_11/bottleneck_v1/conv1/weights/read/_242__cf__248
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.01112397 -0.01631949 -0.00930312 ... -0.0264788  -0.00584631
     0.01867755]
   [-0.00139...
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_11/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,884 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-5.23794234e-01 -6.30773067e-01 -1.31218582e-01 -4.51147020e-01
  8.33667815e-04  3.95931005e-02...
[ 2019-08-21 15:11:17,884 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,887 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_11/bottleneck_v1/conv2/weights/read/_237__cf__243
[ 2019-08-21 15:11:17,887 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,888 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,888 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,890 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-0.02066823 -0.01819543 -0.00598208 ... -0.02192373  0.02425792
     0.01738521]
   [-0.00142...
[ 2019-08-21 15:11:17,890 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_11/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.40241766e-01  1.06453419e-01  1.78684413e-01  2.21279114e-01
  6.02098703e-02 -4.06702161e-01...
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_11/bottleneck_v1/conv3/weights/read/_232__cf__238
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.06340767 -0.08853634  0.24140546 ...  0.00620968 -0.06282786
    -0.01075423]
   [-0.00112...
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_11/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.13077869 -0.0710028   0.4475705  ... -0.32948688  0.23885196
  0.07583773]
[ 2019-08-21 15:11:17,896 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_12/bottleneck_v1/conv1/weights/read/_227__cf__233
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,900 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.0130918   0.00776875  0.00526549 ... -0.01739492 -0.00882907
    -0.02217237]
   [ 0.00756...
[ 2019-08-21 15:11:17,900 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,900 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_12/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,901 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,901 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,901 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,903 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.80954725 -0.39100164 -0.66784585 -0.6013833  -0.8866539  -0.5866025
 -0.55701005 -1.3769547  ...
[ 2019-08-21 15:11:17,903 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,903 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_12/bottleneck_v1/conv2/weights/read/_222__cf__228
[ 2019-08-21 15:11:17,904 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,904 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,904 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,906 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 2.93080211e-02  6.12828089e-03  3.82028669e-02 ... -7.63920275e-03
     4.74995710e-02  6.96...
[ 2019-08-21 15:11:17,906 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,906 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_12/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,908 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,909 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,909 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.14419913 -0.30514467 -0.19178951  0.19376618  0.48141885 -0.08922195
  0.8209733  -1.1228702 ...
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_12/bottleneck_v1/conv3/weights/read/_217__cf__223
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-1.15616526e-02  2.74158359e-01  5.86961722e-03 ... -9.00606588e-02
     1.95284367e-01 -4.03...
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_12/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.09588763  0.4233136   0.3496337  ...  0.14031777 -0.45476997
 -0.15886222]
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_13/bottleneck_v1/conv1/weights/read/_212__cf__218
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00725111  0.01212684  0.01876062 ... -0.00231433  0.00179822
     0.00180749]
   [ 0.00745...
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_13/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,917 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-7.75056303e-01 -6.57834649e-01 -1.25451535e-01 -4.09150094e-01
  1.49536908e-01  3.16332787e-01...
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_13/bottleneck_v1/conv2/weights/read/_207__cf__213
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,922 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-1.15350876e-02 -1.97521187e-02  3.16374213e-03 ...  1.72976013e-02
    -6.88625187e-06  1.49...
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_13/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.38262022e+00  1.88896060e-02  1.07554626e+00  5.34664094e-01
  4.64452147e-01 -3.98691595e-01...
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_13/bottleneck_v1/conv3/weights/read/_202__cf__208
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.00175914  0.07438327 -0.00630371 ... -0.1765044  -0.04310325
     0.01758979]
   [ 0.09180...
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_13/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.047244    0.09320438  0.53586257 ...  0.16003078  0.22417682
 -0.1630114 ]
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_14/bottleneck_v1/conv1/weights/read/_197__cf__203
[ 2019-08-21 15:11:17,928 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,930 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,931 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,931 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 7.7334982e-03 -1.5297175e-02 -1.0391486e-02 ...  4.3668561e-03
     1.3524702e-02 -1.3250215...
[ 2019-08-21 15:11:17,931 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_14/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,934 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.3307007  -0.5042166   0.19714135 -0.34478956 -0.45056477 -0.3563705
 -1.0150865  -0.08122861 ...
[ 2019-08-21 15:11:17,934 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,934 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_14/bottleneck_v1/conv2/weights/read/_192__cf__198
[ 2019-08-21 15:11:17,935 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,935 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,935 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,937 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-9.41939279e-02 -1.79741029e-02 -4.52345386e-02 ...  2.45908350e-01
    -4.40380275e-02 -7.73...
[ 2019-08-21 15:11:17,937 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_14/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,940 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.4842568   0.55843544  0.3400754   0.5067639  -0.8318213  -0.2961461
 -0.6402489   0.31525642 ...
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_14/bottleneck_v1/conv3/weights/read/_187__cf__193
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.00720567 -0.00200151  0.01015673 ...  0.03668773 -0.05951352
    -0.02205336]
   [-0.05897...
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_14/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.4529221   0.4557873   0.32937253 ...  0.4998069  -0.11963736
  0.20405117]
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_15/bottleneck_v1/conv1/weights/read/_182__cf__188
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 2.2569809e-02 -1.5708400e-03  2.3117068e-03 ...  2.7447097e-02
    -9.8316157e-03 -6.8231276...
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_15/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.651842   -1.0716193  -0.8554064  -0.96792185 -0.72640264 -0.19798249
 -0.5830505  -1.0988182 ...
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_15/bottleneck_v1/conv2/weights/read/_177__cf__183
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,948 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,948 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.49345670e-03 -3.35693844e-02  1.25841210e-02 ... -3.97911072e-02
     2.43474878e-02 -5.07...
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_15/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,951 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,954 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,955 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 2.86961615e-01 -4.18123126e-01  4.00913477e-01  2.48694718e-01
 -1.38688028e-01 -5.70992410e-01...
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_15/bottleneck_v1/conv3/weights/read/_172__cf__178
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.0052174  -0.28927442 -0.18738721 ... -0.00996497  0.09861473
    -0.08105125]
   [ 0.05080...
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_15/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.15233228  0.25657028  0.61837655 ... -0.4418515  -0.01153734
 -0.19461437]
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_16/bottleneck_v1/conv1/weights/read/_167__cf__173
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 7.49659305e-03  2.17450550e-03  3.50223482e-03 ... -1.70154292e-02
    -2.89016636e-03 -4.81...
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_16/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,960 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,960 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,962 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.773336   -0.9121206  -0.5324215   0.03277653  0.3271107  -0.41582346
 -0.85520685 -0.37583843...
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_16/bottleneck_v1/conv2/weights/read/_162__cf__168
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,968 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-4.23654467e-02 -1.37500875e-02 -1.26220295e-02 ... -1.54328598e-02
     2.07913648e-02  6.50...
[ 2019-08-21 15:11:17,968 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,968 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_16/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,969 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,969 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,969 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.67092705e+00 -8.37914884e-01  5.02655327e-01  3.25867951e-01
  1.10877812e-01  1.95431113e-01...
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_16/bottleneck_v1/conv3/weights/read/_157__cf__163
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,972 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,972 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.0392926  -0.07441221 -0.06941497 ...  0.18499678  0.02093794
    -0.02630121]
   [-0.04745...
[ 2019-08-21 15:11:17,972 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,975 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_16/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.01531142  0.24804622 -0.21581566 ...  0.08206142 -0.2972537
 -0.05831825]
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_17/bottleneck_v1/conv1/weights/read/_152__cf__158
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00850539  0.00483116 -0.00337729 ...  0.00013587 -0.00885906
    -0.00064291]
   [ 0.01913...
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_17/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,980 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.0334977e-01 -4.9929121e-01 -7.7418441e-01 -2.4290439e-01
 -5.9077466e-01 -1.2013925e+00 -1.27...
[ 2019-08-21 15:11:17,980 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,980 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_17/bottleneck_v1/conv2/weights/read/_147__cf__153
[ 2019-08-21 15:11:17,981 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,981 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,981 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-6.49647638e-02  5.54414019e-02  2.09154356e-02 ... -6.04901426e-02
    -3.09483930e-02  2.07...
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_17/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,986 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,987 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,988 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-3.46656591e-02  2.62327522e-01  7.10912108e-01  4.22393501e-01
 -2.08011478e-01 -3.57801527e-01...
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_17/bottleneck_v1/conv3/weights/read/_142__cf__148
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.04878529 -0.16419953  0.03232806 ... -0.1233708   0.10814972
    -0.06757636]
   [-0.00175...
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_17/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.5527916   0.02878508  0.15311736 ...  0.17362443 -0.0481334
  0.5754384 ]
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_18/bottleneck_v1/conv1/weights/read/_137__cf__143
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01140081  0.01438149  0.00570319 ... -0.00556249  0.00248343
    -0.00492338]
   [-0.01723...
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_18/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,995 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-8.7760466e-01 -4.4335994e-01  3.0702287e-01 -2.5431961e-01
 -5.0035447e-02 -3.6621061e-01 -7.49...
[ 2019-08-21 15:11:17,998 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_18/bottleneck_v1/conv2/weights/read/_132__cf__138
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-0.01315852 -0.03900222 -0.09242561 ... -0.01338235  0.02814335
     0.02464122]
   [-0.00348...
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_18/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,003 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,004 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 9.10504460e-02 -3.99172306e-03 -8.52792203e-01 -4.89658117e-02
 -2.79446274e-01  4.77437884e-01...
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_18/bottleneck_v1/conv3/weights/read/_127__cf__133
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,006 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 3.38195823e-03 -9.25072879e-02  2.59109020e-01 ...  2.10712291e-02
     7.75615126e-02 -5.57...
[ 2019-08-21 15:11:18,006 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,007 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_18/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,009 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,009 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.23102246  0.08541796 -0.11555821 ... -0.002507    0.30109262
  0.38856566]
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_19/bottleneck_v1/conv1/weights/read/_122__cf__128
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.0061114   0.00753611 -0.00185965 ... -0.0090142  -0.01231551
     0.00830988]
   [ 0.00415...
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_19/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,014 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.51426113e+00  2.73546070e-01 -2.24737763e-01 -1.25644183e+00
 -2.72004426e-01  1.39551073e-01...
[ 2019-08-21 15:11:18,014 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,014 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_19/bottleneck_v1/conv2/weights/read/_117__cf__123
[ 2019-08-21 15:11:18,015 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,015 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,015 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,017 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-5.09289689e-02  1.07865809e-02 -3.13787581e-03 ... -4.40243594e-02
     1.76549125e-02 -2.60...
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_19/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,023 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.06277347  0.41370326 -0.39819002  1.1824706  -0.2500946  -0.6068819
  0.28107706 -0.05790341 ...
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_19/bottleneck_v1/conv3/weights/read/_112__cf__118
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.07311298 -0.05345644 -0.03690312 ...  0.12087156  0.11378829
    -0.02274548]
   [-0.00154...
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_19/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.17188254 -0.00495738 -0.67005384 ...  0.33126044  0.42149287
 -0.0539325 ]
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_20/bottleneck_v1/conv1/weights/read/_107__cf__113
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 3.09416908e-04 -1.87135395e-03 -2.97271907e-02 ... -5.38478186e-03
    -1.72796920e-02 -1.06...
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_20/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,028 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,028 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,028 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,029 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 8.14093053e-01 -1.01544037e-01 -3.43402445e-01 -5.67211151e-01
 -1.51276648e+00 -1.59439039e+00...
[ 2019-08-21 15:11:18,033 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,033 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_20/bottleneck_v1/conv2/weights/read/_102__cf__108
[ 2019-08-21 15:11:18,033 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,034 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,034 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,036 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 0.02033925 -0.05619948  0.02766515 ... -0.03943604 -0.02397275
     0.04895049]
   [-0.01205...
[ 2019-08-21 15:11:18,036 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_20/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 3.93973291e-01  6.75818443e-01  5.68278611e-01  4.82069731e-01
 -4.50898260e-01  2.63237834e-01...
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_20/bottleneck_v1/conv3/weights/read/_97__cf__103
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,040 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,040 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,040 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.08231747  0.02115379 -0.2575433  ... -0.06801777 -0.2339971
    -0.00444602]
   [ 0.180265...
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_20/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,042 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.15822881  0.21526286 -0.36310107 ...  0.14647907  0.02265519
  0.03741261]
[ 2019-08-21 15:11:18,045 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,045 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_21/bottleneck_v1/conv1/weights/read/_92__cf__98
[ 2019-08-21 15:11:18,045 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,046 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,046 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,046 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 1.13731390e-02 -8.37631896e-03  2.18193121e-02 ... -1.70757286e-02
    -3.48632387e-03  4.82...
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_21/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,049 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-7.42606819e-01 -8.55965793e-01 -9.54091966e-01 -1.24203396e+00
  9.21360254e-02 -8.59105825e-01...
[ 2019-08-21 15:11:18,049 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_21/bottleneck_v1/conv2/weights/read/_87__cf__93
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,052 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.01551933e-02 -5.34659764e-03 -8.06970801e-03 ...  8.18072446e-03
     5.55610226e-04 -3.48...
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_21/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,055 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-4.71896082e-01 -7.80885041e-01  4.65753019e-01 -2.56956518e-02
 -4.58646774e-01  4.05569375e-01...
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_21/bottleneck_v1/conv3/weights/read/_82__cf__88
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.00559025 -0.09025199  0.01876297 ...  0.05103797  0.04869816
     0.03763796]
   [-0.09497...
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_21/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.24008277  0.00148129 -0.72791934 ...  0.16210009 -0.10902369
  0.2810657 ]
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_22/bottleneck_v1/conv1/weights/read/_77__cf__83
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01313389  0.01255915 -0.00572969 ...  0.01309469  0.01282999
    -0.01747883]
   [-0.01413...
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_22/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,061 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,062 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.1755111  -0.5365908  -0.6500316  -1.0251931  -0.65722525  0.00882782
 -1.2013793  -0.2064715 ...
[ 2019-08-21 15:11:18,062 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_22/bottleneck_v1/conv2/weights/read/_72__cf__78
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,065 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 1.61153488e-02 -5.72048128e-02 -3.50767449e-02 ... -4.06095423e-02
     3.33643192e-03 -4.33...
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_22/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,069 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,070 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-7.92632163e-01  4.61506963e-01  2.20414937e-01  2.48360962e-01
 -1.55725062e-01  1.97303772e-01...
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_22/bottleneck_v1/conv3/weights/read/_67__cf__73
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.07055156 -0.12039565 -0.35282555 ...  0.02579648 -0.04902595
     0.04006082]
   [ 0.00324...
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_22/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.2687049  -0.31173667 -0.408555   ...  0.32076246  0.6928656
  0.32638955]
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_23/bottleneck_v1/conv1/weights/read/_62__cf__68
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00247971 -0.00503684 -0.01485991 ... -0.00062311 -0.01903238
    -0.0019224 ]
   [ 0.00540...
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_23/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,075 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,075 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,075 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,077 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.51112264  0.06879699 -0.13792351 -0.62954384 -1.1817067   0.62597656
 -0.5191443  -0.27764863...
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_23/bottleneck_v1/conv2/weights/read/_57__cf__63
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,083 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-0.0214379   0.01323416  0.07162884 ... -0.00383878 -0.08694868
     0.04481691]
   [-0.05313...
[ 2019-08-21 15:11:18,083 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,083 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_23/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,084 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,084 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,084 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.44861323  0.15291886 -0.6079556   0.37281704 -0.92528206  0.44079533
  0.00877315 -0.08752057...
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_23/bottleneck_v1/conv3/weights/read/_52__cf__58
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,087 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.0416985  -0.03404651 -0.05827026 ... -0.0467588  -0.04995513
    -0.02007625]
   [-0.01678...
[ 2019-08-21 15:11:18,087 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,087 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_23/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,090 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.7015135   0.79401284  0.58250046 ...  0.689971    0.8535386
 -0.50616866]
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv1/weights/read/_46__cf__52
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  512], value = [[[[-0.0100499   0.01746805  0.00606728 ... -0.01924445 -0.00484215
     0.00949551]
   [-0.00694...
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-1.34813488e+00 -1.06322479e+00 -1.04872656e+00 -1.82214534e+00
  6.14979088e-01  4.64484334e-01...
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv2/weights/read/_41__cf__47
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,100 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 512 512], value = [[[[ 2.55534449e-03 -4.48066220e-02 -1.98020437e-03 ...  1.18029548e-03
    -3.54787074e-02 -2.08...
[ 2019-08-21 15:11:18,102 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,102 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,102 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,103 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,103 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,106 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-5.02341211e-01 -8.47730637e-02  1.24618411e-01  5.31149447e-01
  3.77969146e-02  2.97774673e-02...
[ 2019-08-21 15:11:18,106 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv3/weights/read/_36__cf__42
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 2048], value = [[[[-1.1511395e-01  1.3495015e-01 -2.6494071e-01 ...  1.1587205e-01
    -3.2709050e-01  2.0824455...
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-0.04443729 -0.06957215 -0.40661395 ... -0.5239943  -0.35380042
  0.05741334]
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/shortcut/weights/read/_549__cf__555
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024 2048], value = [[[[-0.04662284  0.10389034 -0.05344971 ... -0.00439417 -0.0560176
     0.00560989]
   [-0.095212...
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,111 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:18,114 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,114 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-1.0082258  -1.3967133  -0.27703083 ... -0.8050508  -1.117923
 -1.6318885 ]
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv1/weights/read/_31__cf__37
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,116 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,116 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,116 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 2048  512], value = [[[[-0.00228747  0.00105643  0.00917423 ... -0.00156474  0.00991794
    -0.00409007]
   [-0.00853...
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-1.98309660e-01  2.77836621e-01 -2.46522784e-01 -1.55009270e-01
  3.64018679e-01  2.51267672e-01...
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv2/weights/read/_26__cf__32
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,122 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,122 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,124 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 512 512], value = [[[[-0.01245593 -0.02698608  0.02460378 ...  0.03418521  0.0137597
    -0.02065542]
   [-0.053296...
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,129 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-3.63835156e-01  8.32627416e-02 -2.18970597e-01  6.34945631e-02
  1.18263602e-01  3.64442110e-01...
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv3/weights/read/_21__cf__27
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 2048], value = [[[[-0.2368762  -0.4605358  -0.34834984 ... -0.03658137 -0.02586159
     0.02093196]
   [-0.28074...
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-1.0153909 -0.6674568 -0.875208  ... -1.103873  -1.3285267 -0.7974661]
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv1/weights/read/_16__cf__22
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,134 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 2048  512], value = [[[[-1.6256166e-03 -6.6833165e-03  1.7411307e-03 ... -4.5890920e-03
    -4.8535918e-03 -2.7233576...
[ 2019-08-21 15:11:18,136 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,140 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-8.50913644e-01 -9.37635899e-02 -2.53542960e-01 -3.17552984e-01
 -3.14328194e-01 -6.26975715e-01...
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv2/weights/read/_11__cf__17
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,143 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 512 512], value = [[[[ 0.0489965  -0.01051994  0.0411143  ... -0.00541099 -0.01142978
     0.02437654]
   [ 0.09674...
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,147 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 1.16400480e-01 -2.35121608e-01 -3.59815121e-01  2.66064703e-01
 -3.98253858e-01  1.24326885e-01...
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv3/weights/read/_6__cf__12
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,149 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 2048], value = [[[[ 0.02848594 -0.04761565 -0.19353807 ... -0.22083989 -0.18907347
    -0.05548693]
   [ 0.07501...
[ 2019-08-21 15:11:18,149 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-1.1425788 -1.141293  -1.2837434 ... -1.3432276 -1.0777199 -1.3441148]
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/BoxEncodingPredictor/biases/read/_0__cf__6
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [360], value = [-7.95166474e-03  2.06766520e-02  2.64950842e-01  8.11876133e-02
  7.40765221e-03  7.21091777e-03...
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/BoxEncodingPredictor/weights/read/_1__cf__7
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048  360], value = [[-2.3237381e-02 -2.8804217e-03  5.0827926e-03 ... -2.4562681e-02
   2.8157391e-02  5.0061975e-02...
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:130 ]  Partial infer for Conv/biases/read/_47__cf__53
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 2.64190719e-04  1.88985479e-03  8.92485492e-04 -2.03493261e-03
 -1.33740180e-03 -2.03066436e-03...
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/BoxEncodingPredictor/biases/read/_518__cf__524
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [48], value = [ 0.03166837  0.00908974 -0.01960882 -0.02548007  0.0149476  -0.00241546
  0.00176654  0.02480716...
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/BoxEncodingPredictor/weights/read/_519__cf__525
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512  48], value = [[[[ 0.11181056  0.00454487  0.12837438 ...  0.00214412  0.01436291
     0.02418564]
   [-0.01499...
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/ExpandDims/_520__cf__526
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/ExpandDims/_521__cf__527
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_3/_522__cf__528
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.0
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_2/_523__cf__529
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 16.0
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/ones/_524__cf__530
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/ExpandDims/_525__cf__531
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_5/_526__cf__532
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.0
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_4/_527__cf__533
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 16.0
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/ones/_528__cf__534
[ 2019-08-21 15:11:18,167 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/ones/_529__cf__535
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape/concat/_530__cf__536
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ 1  1 12]
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/Reshape/_531__cf__537
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 1  1 12], value = [[[ 45.25483   90.50966  181.01932  362.03864   63.999996 127.99999
   255.99998  511.99997   90....
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/ExpandDims/_532__cf__538
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/ones/_533__cf__539
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape/concat/_534__cf__540
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ 1  1 12]
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/Reshape/_535__cf__541
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 1  1 12], value = [[[ 90.509674 181.01935  362.0387   724.0774    64.00001  128.00002
   256.00003  512.00006   45....
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/ClassPredictor/biases/read/_539__cf__545
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [24], value = [ 0.09504959 -0.09504911  0.0573867  -0.05738634  0.02511273 -0.02511258
 -0.02817237  0.02817235...
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/ClassPredictor/weights/read/_540__cf__546
[ 2019-08-21 15:11:18,180 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512  24], value = [[[[ 0.00296129 -0.02949508  0.00342768 ... -0.02782438  0.02513614
    -0.02138193]
   [-0.00872...
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:130 ]  Partial infer for Slice/begin/_541__cf__547
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/ClassPredictor/biases/read/_553__cf__559
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,183 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,183 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [91], value = [ 7.17917085e-01  5.80758825e-02 -9.27161542e-04  3.94133702e-02
 -8.60467833e-03 -1.22773387e-02...
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/ClassPredictor/weights/read/_554__cf__560
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,185 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,185 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048   91], value = [[ 0.00950589  0.03144972 -0.06402664 ...  0.04240924  0.02076698
   0.03288592]
 [ 0.11044841 -0...
[ 2019-08-21 15:11:18,185 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice/begin/_555__cf__561
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:130 ]  Partial infer for image_tensor
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:131 ]  Op: Parameter
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:130 ]  Partial infer for ToFloat_3
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:131 ]  Op: Cast
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,191 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/Shape
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:131 ]  Op: ShapeOf
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,193 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,193 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/strided_slice
[ 2019-08-21 15:11:18,193 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/range
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:131 ]  Op: Range
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 100
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [], value = 1
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [100], value = [ 0  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
 24 25 26 27 28 29 30 31...
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/Shape
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:131 ]  Op: ShapeOf
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,198 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,198 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Less/Enter
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,200 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,202 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,202 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Less
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:131 ]  Op: Less
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 100
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/LoopCond
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:131 ]  Op: LoopCond
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Switch
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:131 ]  Op: Switch
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Identity
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/add/y
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/add
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:131 ]  Op: Add
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 1
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/NextIteration
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:131 ]  Op: NextIteration
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ExpandDims/dim
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_3/stack_2
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_3/stack_1
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:18,211 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,213 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Const_2
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Const_1
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1024.0
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Const
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 600.0
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_2/stack_2
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_2/stack_1
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_1/stack_2
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_1/stack_1
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice/stack_2
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice/stack_1
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,222 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArray_2
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayV3
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_2/Output_0/Data_
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayWrite_1/TensorArrayWriteV3/Enter
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray_2/Output_0/Data_
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_2/Output_0/Data_
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Enter_2
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Merge_2
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Switch_2
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:131 ]  Op: Switch
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Identity_2
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArray_1
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayV3
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_1/Output_0/Data_
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayWrite/TensorArrayWriteV3/Enter
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray_1/Output_0/Data_
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_1/Output_0/Data_
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Enter_1
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,233 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Merge_1
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Switch_1
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:131 ]  Op: Switch
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Identity_1
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArray
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayV3
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/TensorArrayScatter/TensorArrayScatterV3
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayScatterV3
[ 2019-08-21 15:11:18,241 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,241 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,241 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [100], value = [ 0  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayReadV3/Enter_1
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayReadV3/Enter
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayReadV3
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ExpandDims
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:18,248 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,248 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Shape
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:131 ]  Op: ShapeOf
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_2
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,252 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,252 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,252 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [3]
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 3
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/stack_2/ExpandDims_1156412424
[ 2019-08-21 15:11:18,254 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:18,254 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,254 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 3
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_1
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,256 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ToFloat_1
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:131 ]  Op: Cast
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,262 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,262 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ToFloat
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:131 ]  Op: Cast
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Maximum
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:131 ]  Op: Maximum
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/div_1/reciprocal_
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.004464285714285714
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/div_1/mul_
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:131 ]  Op: Mul
[ 2019-08-21 15:11:18,267 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,269 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0.004464285714285714
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 1024.0
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4.571428571428571
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/mul_3
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:131 ]  Op: Mul
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 4.571428571428571
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1024.0
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Round_3
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:131 ]  Op: Round
[ INFO ]  Called "tf_native_tf_node_infer" for node "Preprocessor/map/while/ResizeToRange/Round_3"
[ 2019-08-21 15:11:18,273 ] [ DEBUG ] [ tf:222 ]  Added placeholder with name 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder'
[ 2019-08-21 15:11:18,273 ] [ DEBUG ] [ tf:235 ]  update_input_in_pbs: replace input 'Preprocessor/map/while/ResizeToRange/mul_3' with input 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder'
[ 2019-08-21 15:11:18,273 ] [ DEBUG ] [ tf:243 ]  Replacing input '0' of the node 'Preprocessor/map/while/ResizeToRange/Round_3' with placeholder 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder'
[ ERROR ]  Cannot infer shapes or values for node "Preprocessor/map/while/ResizeToRange/Round_3".
[ ERROR ]  graph_def is invalid at node 'Preprocessor/map/while/ResizeToRange/Round_3': Input tensor 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder:0' Cannot convert a tensor of type float64 to an input of type float32.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x00000135DE6381E0>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ 2019-08-21 15:11:18,286 ] [ DEBUG ] [ infer:196 ]  Node "Preprocessor/map/while/ResizeToRange/Round_3" attributes: {'pb': name: "Preprocessor/map/while/ResizeToRange/Round_3"
op: "Round"
input: "Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder"
attr {
  key: "T"
  value {
    type: DT_FLOAT
, '_in_ports': {0: {'control_flow': False}}, '_out_ports': {0: {'control_flow': False}}, 'kind': 'op', 'name': 'Preprocessor/map/while/ResizeToRange/Round_3', 'op': 'Round', 'precision': 'FP32', 'infer': <function tf_native_tf_node_infer at 0x00000135DE6381E0>, 'is_output_reachable': True, 'is_undead': False, 'is_const_producer': False, 'is_partial_inferred': False}
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_3" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
[ 2019-08-21 15:11:18,290 ] [ DEBUG ] [ main:308 ]  Traceback (most recent call last):
  File "C:\Users\GF63\.conda\envs\tf_1.14\lib\site-packages\tensorflow\python\framework\importer.py", line 402, in import_graph_def
    op._add_input(source_tensor, dtype=input_type)
  File "C:\Users\GF63\.conda\envs\tf_1.14\lib\site-packages\tensorflow\python\framework\ops.py", line 1741, in _add_input
    (tensor.dtype.name, dtype.name))
TypeError: Cannot convert a tensor of type float64 to an input of type float32
During handling of the above exception, another exception occurred:
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\middle\passes\infer.py", line 132, in partial_infer
    node.infer(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\partial_infer\tf.py", line 60, in tf_native_tf_node_infer
    tf_subgraph_infer(tmp_node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\partial_infer\tf.py", line 135, in tf_subgraph_infer
    all_constants, output_tensors = get_subgraph_output_tensors(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\partial_infer\tf.py", line 115, in get_subgraph_output_tensors
    tf.import_graph_def(graph_def, name='')
  File "C:\Users\GF63\.conda\envs\tf_1.14\lib\site-packages\tensorflow\python\framework\importer.py", line 406, in import_graph_def
    node, 'Input tensor %r %s' % (input_name, te)))
ValueError: graph_def is invalid at node 'Preprocessor/map/while/ResizeToRange/Round_3': Input tensor 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder:0' Cannot convert a tensor of type float64 to an input of type float32.
The above exception was the direct cause of the following exception:
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 273, in apply_replacements
    for_graph_and_each_sub_graph_recursively(graph, replacer.find_and_replace_pattern)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\middle\pattern_match.py", line 58, in for_graph_and_each_sub_graph_recursively
    func(graph)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\extensions\middle\PartialInfer.py", line 31, in find_and_replace_pattern
    partial_infer(graph)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\middle\passes\infer.py", line 198, in partial_infer
    refer_to_faq_msg(38)) from err
mo.utils.error.Error: Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_3" node.
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 302, in main
    return driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 251, in driver
    is_binary=not argv.input_model_is_text)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 134, in tf2nx
    class_registration.apply_replacements(graph, class_registration.ClassType.MIDDLE_REPLACER)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 293, in apply_replacements
    )) from err
mo.utils.error.Error: Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_3" node.
(tf_1.14) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>
Thanks shubha that helped.
Now the IR conversion seem to go through as shown below here (followed steps of the link you shared):
(tyqi_tf) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>python ..\mo.py --input_model  D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28_openvino\frozen_inference_graph.pb  --tensorflow_use_custom_operations_config  ..\extensions\front\tf\faster_rcnn_support.json --output_dir D:\Openvino  --tensorflow_object_detection_api_pipeline_config D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28_openvino\pipeline.config
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28_openvino\frozen_inference_graph.pb
        - Path for generated IR:        D:\Openvino
        - IR output name:       frozen_inference_graph
        - Log level:    ERROR
        - Batch:        Not specified, inherited from the model
        - Input layers:         Not specified, inherited from the model
        - Output layers:        Not specified, inherited from the model
        - Input shapes:         Not specified, inherited from the model
        - Mean values:  Not specified
        - Scale values:         Not specified
        - Scale factor:         Not specified
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
TensorFlow specific parameters:
        - Input model in text protobuf format:  False
        - Path to model dump for TensorBoard:   None
        - List of shared libraries with TensorFlow custom layers implementation:        None
        - Update the configuration file with input/output node names:   None
        - Use configuration file used to generate the model with Object Detection API:  D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28_openvino\pipeline.config
        - Operations to offload:        None
        - Patterns to offload:  None
        - Use the config file:  C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites\..\extensions\front\tf\faster_rcnn_support.json
Model Optimizer version:        2019.2.0-436-gf5827d4
[ WARNING ] Model Optimizer removes pre-processing block of the model which resizes image keeping aspect ratio. The Inference Engine does not support dynamic image size so the Intermediate Representation file is generated with the input image size of a fixed size.
Specify the "--input_shape" command line parameter to override the default shape which is equal to (600, 600).
The Preprocessor block has been removed. Only nodes performing mean value subtraction and scaling (if applicable) are kept.
The graph output nodes "num_detections", "detection_boxes", "detection_classes", "detection_scores" have been replaced with a single layer of type "Detection Output". Refer to IR catalogue in the documentation for information about this layer.
[ SUCCESS ] Generated IR model.
[ SUCCESS ] XML file: D:\Openvino\frozen_inference_graph.xml
[ SUCCESS ] BIN file: D:\Openvino\frozen_inference_graph.bin
[ SUCCESS ] Total execution time: 68.55 seconds.
Now the demo code(object_detection_demo_faster_rcnn) running is giving issues as "deprecated IR version: 0" :
Please note that demo code works with VGG16 based faster RCNN.
Please let me know how i can fix the below error .
(tyqi_tf) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>C:\Users\GF63\Documents\Intel\OpenVINO\inference_engine_demos_build\intel64\Debug\object_detection_demo_faster_rcnn.exe -i C:\Users\GF63\Documents\Intel\OpenVINO\faster_rcnn_models\VGG16_FasterRCNN\000000002153.jpg -m D:\Openvino\frozen_inference_graph.mapping
[ INFO ] InferenceEngine:
        API version ............ 2.0
        Build .................. 27579
        Description ....... API
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     C:\Users\GF63\Documents\Intel\OpenVINO\faster_rcnn_models\VGG16_FasterRCNN\000000002153.jpg
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
        CPU
        MKLDNNPlugin version ......... 2.0
        Build ........... 27579
[ INFO ] Loading network files:
[ ERROR ] Error reading network: deprecated IR version: 0
..\src\inference_engine\ie_cnn_net_reader_impl.cpp:136
c:\program files (x86)\intelswtools\openvino\deployment_tools\inference_engine\include\details/ie_exception_conversion.hpp:71
Even with --reverse_input_channels also the behavior is same.
Any Ideas , Please !
Intel Folks,
Please help in resolving issues.
Dear Kulkarni, Vinay
That error usually means that you generated IR with an old version of Model Optimizer. Please do not mix and match Model Optimizer and Inference Engine versions. You should really use the same package for both. It's also not a good idea for instance to use the packaged version of OpenVino for Model Optimizer and then use the generated IR with inference engine from https://github.com/opencv/dldt
Also OpenVino 2019R2.01 has been released.
Please download it !
Shubha
I did not do mix and match , its same 2019 R2 version, that i am working on.
Only difference is i took .pb from link that you shared : MO converting Tensorflow Object Detection API (http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html)
Dear Kulkarni, Vinay,
rather than object_detection_demo_faster_rcnn.exe can you kindly try object_detection_sample_ssd.exe ? I know it's confusing. If you want the detailed reasons why, please review the following IDZ Post:
https://software.intel.com/en-us/forums/computer-vision/topic/815222
Hope it helps.
Shubha
Thanks shubha. It worked.
Just for completeness for those trying freshly, here are the steps :
1) Go to Model Zoo and get the topology/model,
2) Pick the model relvent, in this case please pick the following:
The Model : faster_rcnn_resnet101_coco
3) Get this model , untar and keep it in your working folder.
4) In the folder you will also find pipeline.config, which will be useful during the model optimizer.
5) As per this document : http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html ,
We need to give config file for the Model optimizer. Hence chose in this case the config file as :
6) Convert the Tensorflow frozen model in to IR format using Model optimizer as below :
python ..\mo.py --framework tf --input_model D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28_openvino\frozen_inference_graph.pb --output=detection_boxes,detection_scores,num_detections --tensorflow_use_custom_operations_config ..\extensions\front\tf\faster_rcnn_support.json --output_dir D:\Openvino --tensorflow_object_detection_api_pipeline_config D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28_openvino\pipeline.config --reverse_input_channels
Note : Just make sure your paths for mp.py and frozen buffer (.pb) and .json ,.config are properly given
7) Your output_dir will be used for further inferencing.
8) Run the SSD demo as mentioned by shubha, to get your object detection working :
"C:\Program Files (x86)\IntelSWTools\openvino_2019.2.242\deployment_tools\inference_engine\samples\intel64\Debug\object_detection_sample_ssd.exe" -m D:\Openvino\frozen_inference_graph.xml -i "C:\Users\GF63\Documents\Intel\OpenVINO\faster_rcnn_models\VGG16_FasterRCNN\000000002153.jpg"
Note: -m option is to be given with your output_dir having .xml , to get the IR format understandable to openvino.
You should see outputs in some what this format :
        CPU
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the device
[ INFO ] Create infer request
[ WARNING ] Image is resized from (640, 480) to (600, 600)
[ INFO ] Start inference
[ INFO ] Processing output blobs
[0,1] element, prob = 0.99866    (177,0)-(239,117) batch id : 0 WILL BE PRINTED!
[1,1] element, prob = 0.997371    (300,278)-(463,447) batch id : 0 WILL BE PRINTED!
[2,1] element, prob = 0.985378    (274,305)-(373,441) batch id : 0 WILL BE PRINTED!
[3,1] element, prob = 0.957495    (373,212)-(439,343) batch id : 0 WILL BE PRINTED!
[4,1] element, prob = 0.31087    (366,229)-(449,385) batch id : 0
[5,1] element, prob = 0.306353    (285,326)-(433,440) batch id : 0
[6,39] element, prob = 0.930603    (386,184)-(461,229) batch id : 0 WILL BE PRINTED!
[ INFO ] Image out_0.bmp created!
[ INFO ] Execution successful
[ INFO ] This sample is an API example, for any performance measurements please use the dedicated benchmark_app tool
Hope this helps to beginners.
I realize that Model Optimizer can be daunting for beginners. But thank you for your generous "Beginner's Help" and sharing it with the OpenVino community !
Sincerely,
Shubha
