6583 Discussions
[ GENERAL_ERROR ] Model file IRmodel\savedmodel.xml cannot be opened!
KentWane
The python code openvinotest.py can run normally if using
python openvinotest.py
However, it goes wrong after wrapping by pyinstaller package.
It will send error messages below, if I executed the openvinotest.exe file
INFO:nncf:NNCF initialized successfully. Supported frameworks detected: openvino
CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
GPU: Intel(R) UHD Graphics 630 (iGPU)
Traceback (most recent call last):
  File "openvinotest.py", line 20, in <module>
  File "openvino\runtime\ie_api.py", line 507, in read_model
RuntimeError: Exception from src\inference\src\core.cpp:100:
I had search related posts online,
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/XML-file-not-found/td-p/1226620
https://github.com/openvinotoolkit/openvino/issues/11293
, but any added files cannot make the .exe works. I'm wondering what kinds of linking or files missed during the wrapping process.
python code of openvinotest.py before Line 20:
from openvino.runtime import Core
import cv2
import numpy as np
import time
import subprocess
from pathlib import Path
from nncf import compress_weights
subprocess.call('D:\openvino_2023.1.0\setupvars.bat')
# try:
ie = Core()
devices = ie.available_devices
for device in devices:
    device_name = ie.get_property(device, "FULL_DEVICE_NAME")
    print(f"{device}: {device_name}")
ir_path = Path("./IRmodel/savedmodel.xml")
print(ir_path)
# ir_path = "D:\\test\\Openvino\\playground\\IRmode\\savedmodel.xml"
model = ie.read_model(model=ir_path)
Environment:
OS: Windows 10
Python: 3.8.10
openvino: 2023.1.0
Python package:
Package                   Version
about-time                4.2.1
alive-progress            3.1.4
altgraph                  0.17.4
attrs                     23.1.0
autograd                  1.6.2
cma                       3.2.2
colorama                  0.4.6
contourpy                 1.1.1
cycler                    0.12.1
Deprecated                1.2.14
dill                      0.3.7
fonttools                 4.43.1
future                    0.18.3
grapheme                  0.6.0
importlib-metadata        6.8.0
importlib-resources       6.1.0
joblib                    1.3.2
jsonschema                4.19.2
jsonschema-specifications 2023.7.1
jstyleson                 0.0.2
kiwisolver                1.4.5
matplotlib                3.7.3
natsort                   8.4.0
networkx                  2.8.2
ninja                     1.10.2.4
nncf                      2.6.0
numpy                     1.24.4
opencv-python             4.8.1.78
openvino                  2023.1.0
openvino-telemetry        2023.2.1
packaging                 23.2
pandas                    2.0.3
pefile                    2023.2.7
Pillow                    10.1.0
pip                       21.1.1
pkgutil-resolve-name      1.3.10
psutil                    5.9.6
pydot                     1.4.2
pyinstaller               6.1.0
pyinstaller-hooks-contrib 2023.10
pymoo                     0.6.0.1
pyparsing                 2.4.7
python-dateutil           2.8.2
pytz                      2023.3.post1
pywin32-ctypes            0.2.2
referencing               0.30.2
rpds-py                   0.10.6
scikit-learn              1.3.2
scipy                     1.10.1
setuptools                56.0.0
six                       1.16.0
texttable                 1.7.0
threadpoolctl             3.2.0
tqdm                      4.66.1
tzdata                    2023.3
wrapt                     1.15.0
zipp                      3.17.0
Aznie_Intel
Hi KentWane,
Thanks for reaching out.
For your information, PyInstaller is not officially supported by OpenVINO™.However, there are a few Community members have successfully created the executable file using that. Check out the following cases here:
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Are-pyinstaller-and-openvino-incompatible/td-p/1168565
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Exe-built-using-OpenVino-and-pyinstaller-does-not-work-with-R3/m-p/1188030
In your case, make sure you are giving a correct path into your XML file and running the inference in OpenVINO environment.
Aznie
Aznie_Intel
Hi KentWane,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
