Get tensor from intermediate layers
Delgado__Guillem
Hello!
I have been looking for a way to get the tensor from the intermediate layers after the inference but I can't find anything on the documentation nor any example on the samples. How could I extract these tensors?
Shubha_R_Intel
OK I think I understand what you want now. Please look at inference_engine\samples\object_detection_demo where the method of adding your own outputs is demonstrated. You will need to add your own output to the list of output layers. Then you will be able to check the output data from the layer after inference (using output data for an InferRequest()).
Here are the steps:
1) Run your model through MO as usual and obtain the IR
2) Add output layers before IE infer(). Look at the following code in the object detection demo:
 network.addOutput(FLAGS_bbox_name, 0);
 network.addOutput(FLAGS_prob_name, 0);
 network.addOutput(FLAGS_proposal_name, 0);
3) Now after you attach these extra outputs on the end, you will want to perform infer() again but after loading the modified model to the plugin.
        // --------------------------- 4. Loading model to the plugin ------------------------------------------
        slog::info << "Loading model to the plugin" << slog::endl;
        ExecutableNetwork executable_network = plugin.LoadNetwork(network, {});
        // --------------------------- 5. Create infer request -------------------------------------------------
        InferRequest infer_request = executable_network.CreateInferRequest();
Shubha_R_Intel
Take a look at the code  samples\validation_app\Processor.cpp and samples\calibration_tool\calibrator_processors.cpp. Similar forum post here:
https://software.intel.com/en-us/forums/computer-vision/topic/804842
Delgado__Guillem
I've been reviewing the samples but I was not able to find what I was looking for. I might not be understanding it correctly on how to proceed.
I am working with a YOLO net and I want to get the activations values from my ObjectDetection layers, I tried these different options:
  • Convert my PB model to XML with mo_tf.py selecting as output the layers I want as output. However, I get the error mo.utils.error.Error: Stopped shape/value propagation at "2-maxpool" node.
    python3 mo_tf.py --input_model YOLOGRAPH.pb --batch 1 --input "input" --output "4-leaky,1-leaky" --output_dir MY_OUPUT
  • Convert my PB model to XML with mo_tf.py using the yolo_v1_v2.json as a parameter of custom operations. However, it's not really useful in this case.
  • Iterate over my network layers or get them by name but then I do not really know how to create a blob out of these layers and get the values once I infer.
Any suggestions?
Shubha_R_Intel
Hi Guillem:
So can you clarify what you mean by "after inference" ?
CNN Models have an input layer, hidden layers, and usually one output layer.
Thanks for using OpenVino !
Shubha
Delgado__Guillem
Hi Guillem:
Shubha
Hi Shubha!
When I mean "after inference" is after I feed the network with my image/images.  So, when I create the InferRequest() and fill the input tensor using
Blob::Ptr imageInput = infer_request.GetBlob(imageInputName);
unsigned char* data_buffer = static_cast<unsigned char*>(imageInput->buffer());
I would like to get the data tensors in the hidden layers but I am unable to do it with the InferRequest() because I do not have any blob for these hidden layers. I have tried creating one only for a given hidden layers but I cannot find how. Also, I thought about converting my model to Openvino format specifying as an output my hidden layers and then using network.getOutputsInfo() method to create the blob and get the data_buffer but I get errors on the conversion, so I have discarded this option.
Thanks for the help!
Shubha_R_Intel
Here are the steps:
Delgado__Guillem
That worked perfectly! Thank you very much for the help!
Ritwika_C_Intel
 I want to change the output of intermediate layers before feeding them as a input to the next layer. How can I do that?
Xanph
Hi All,
With version 2024.3 released, is there a new way to access the output of intermediate layers directly?
For example, during inference, I want to get the output of the third convolution layer in my model to perform a Grad-CAM calculation.
For context, my model has been converted from Tensorflow format and quantized into the OpenVINO IR format. I am in Python.
Flynn.
