GetAvailableDevices and seg fault on exit
dangu
I recently updated to 2019 R2 and started experimenting with the new Core API. One problem I've noticed is that calling GetAvailableDevices leads to a seg fault when the program exits. This happens in the hello_query_device sample, but also in a trivial C++ application that only constructs a Core object and calls that function. It happens in Release mode only, making debugging difficult. I am on CentOS 7.
Can anyone else reproduce this, or provide any insights?
Thanks!
Ilya_L_Intel
Could you please provide more information?
1. What setup devices do you have in your system? E.g. GPU + installed driver, FPGA + BSP + OpenCL RTE, VPU devices?
2. Could you please take plugins.xml file located at the same folder as libinference_engine.so and remove plugins from this file one by one? I suppose after certain removed plugin the SEGFAULT at the end will disappear. It means we have issue with particular plugin and it's environment.
Ilya.
dangu
Thanks Ilya. Indeed if I take the GPU plugin out of plugins.xml the seg fault disappears.
This is a pretty barebones CentOS 7 VM, and I doubt I installed the necessary opencl driver, so that is probably the cause.
Mark_L_Intel1
Hi dangu,
We tried this issue and can't reproduce it, could you send us the instruction how to reproduce it?
Sorry for the delay, I will wait for several days and if not get any response, I will close our internal ticket and assume your issue is solved.
Mark Liu
dangu
Thanks, Mark. This does not seem to be happening in 2020 R1, I would go ahead and close it.
