Getting error while running "Image Classification Verification Script".
sjais14
C:\Users\Documents\Intel\OpenVINO\inference_engine_samples_build\CMakeFiles\3.17.2\VCTargetsPath.vcxproj(14,2): error MSB4019: The imported project "C:\Microsoft.Cpp.Default.props" was not found. Confirm that the path in the <Import> declaration is correc
Hello guys I'm knew to openvino toolkit and I don't know much about it . I have successfully installed all the requirements of application but while running  "Image Classification Verification Script" I'm getting above and below errors
"See also "C:/Users/Raj Jayswal/Documents/Intel/OpenVINO/inference_engine_samples_build/CMakeFiles/CMakeOutput.log".
Error"
please help thanks in advance.
JAIVIN_J_Intel
Hi Suarabh,
This seems like an issue with accessing path to Visual studio.
Have you installed Microsoft Visual Studio according to the Software Requirements?
Have you Set the Environment Variables?
Also, are you able to run the Verification Script from the Command Prompt?
Jaivin
