6584 Discussions
Getting the inference time for NCS and OpenVINO
SPaul19
Innovator
Hello.
In order to present a comparative study between OpenVINO (along with NCS 1) and the standard versions of Caffe and TensorFlow, I was using the standard `time` module of Python in the following way
```python
start_time = time.time()
# inference code for NCS
print("Time taken by NCS:", time.time() - start)
I am interested to know if this is the right method to draw such comparison or is there any other method (we had one in NCSDK) specifically suited for this.
Thanks in advance.
Shubha_R_Intel
Dear Sayak,
Your approach is solid. In fact if you look at the main.cpp for the classification_sample, you see the following:
 double total = 0.0;
        /** Start inference & calc performance **/
        for (size_t iter = 0; iter < FLAGS_ni; ++iter) {
            auto t0 = Time::now();
            infer_request.Infer();
            auto t1 = Time::now();
            fsec fs = t1 - t0;
            ms d = std::chrono::duration_cast<ms>(fs);
            total += d.count();
std::cout << std::endl << "total inference time: " << total << std::endl;
        std::cout << "Average running time of one iteration: " << total / static_cast<double>(FLAGS_ni) << " ms" << std::endl;
        std::cout << std::endl << "Throughput: " << 1000 * static_cast<double>(FLAGS_ni) * batchSize / total << " FPS" << std::endl;
        std::cout << std::endl;
Note that FLAGS_ni is the number of iterations which you pass in through the command-line. Also batchSize is the N in [NCHW], where C = Number of Channels, H = Height, W = Width.
Hope it helps,
Shubha
SPaul19
Innovator
I see. I am on the right track then. Just wanted to know if there exists anything specific as NCSDK2.
Shubha_R_Intel
Dear Sayak,
Keep in mind that NCSDK2 has been replaced by OpenVino. Please use OpenVino from now on.
Thanks !
Shubha
