Graph contains 0 node after executing
yu__jia
Hi, everyone, I converted my trained VGG16 model parameters .meta, index, data to .pb format by freezing, and then reported the following error when performing model optimization
python mo_tf.py --input_model E:\VGG16\FLOPS_unchanged\train_logs_vgg16_layers_1\frozen_model.pb --batch 1 --data_type FP16 --output_dir E:\VGG16\FLOPS_unchanged\train_logs_vgg16_layers_1
E1130 21:17:00.961202 10816 main.py:307] Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.output_cut.OutputCut'>): Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual
However when I use the following command,
python mo_tf.py --input_meta_graph E:\VGG16\FLOPS_unchanged\train_logs_vgg16_layers_1\model.ckpt-951.meta --batch 1 --data_type FP16
I get another error:
E1130 21:49:50.934771   504 main.py:307] Unexpected exception happened during extracting attributes for node case/cond/is_jpeg/Substr/Switch.
Original exception message: 'ascii' codec can't decode byte 0xff in position 0: ordinal not in range(128)
What should I do ? Thanks.
