6574 Discussions
Graphics compute Runtime version for OpenVINO 2021.4
Shigeyoshi_O_Intel
I'd like to run OpenVINO on Elkhart Lake. Referring to OpenVINO install guide,  I need to install Graphics compute Runtime 19.41.1441. Although OpenVINO 2021.4 supports Elkhart Lake, the version of runtime doesn't support Elkhart Lake iGPU.
Is it acceptable to use OpenVINO 2021.4 with later runtime, such as 20.38.17961?
Wan_Intel
Hi Shigeyoshi_O_Intel,
For your information, higher hardware versions require a higher driver version, namely 20.35 instead of 19.41.
Hence, it is acceptable to use OpenVINO 2021.4 with later runtime.
For more information, please refer to the following page:
https://docs.openvinotoolkit.org/2021.4/openvino_docs_install_guides_installing_openvino_linux.html#additional-GPU-steps
Wan
Shigeyoshi_O_Intel
Hi Wan_Intel,
Thank you so much!
Wan_Intel
Thanks for your question.
This thread will no longer be monitored since we have provided a suggestion.
If you need any additional information from Intel, please submit a new question.
Wan
