Gstreamer cannot open file
jobdulo
I am trying to add a video file to my config.json for inferencing but I get the following errors;
OpenCV | GStreamer warning: Embedded video playback halted; module source reported: Could not open file...
OpenCV | GStreamer warning: unable to start pipeline
OpenCV | GStreamer warning: GStreamer: pipeline have not been created
I have tried following the temporary solution at https://github.com/boltgolt/howdy/issues/241
but exporting the variable in my terminal makes the program hang.
I am trying to add my own data in the setup at https://github.com/intel-iot-devkit/smart-retail-analytics#setup
How can I solve this error?
I am using OpenVINO toolkit 2020.3.341 on WSL2 Ubuntu 18.04LTS
Python 3.6.9
Intel(R) Core(TM) i7-1065G7 CPU
Adli
Hi jobdulo,
Thank you for reaching out to us. A quick check, what is your video file format? Did you encounter this issue when you are using camera input?
Adli
jobdulo
I am using a .mp4 video file for input.
I tried using my camera for input but got the following error:
[ WARN:0] global ../opencv/modules/videoio/src/cap_v4l.cpp (893) open VIDEOIO(V4L2:/dev/video0): can't open camera by index
What I have tried;
So I decided to fork the repo and uploaded my videos this way they get downloaded when running setup.sh file. This resulted in another error;
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x7f50e8218cc0] moov atom not found
[ WARN:0] global ../opencv/modules/videoio/src/cap_gstreamer.cpp (1759) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module decodebin0 reported: This appears to be a text file
[ WARN:0] global ../opencv/modules/videoio/src/cap_gstreamer.cpp (888) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global ../opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
jobdulo
Also, is there a way videos or cameras should be prepared before using them as inputs?
Adli
Hi jobdulo,
I think there is no 'input preparation steps' method for this case. Anyway, we are investigating this issue and will get back to you as soon as possible.
Adli
jobdulo
Thank you. I will be on the lookout for any updates.
Maksim_S_Intel
  • Please make sure corresponding GStreamer plugins are installed (gstreamer1.0-plugins-good, gstreamer1.0-plugins-bad, gstreamer1.0-plugins-ugly):
    apt list -i | grep gstreamer
  • Try to install ffmpeg:
    apt install ffmpeg
  • AFAIK USB is not supported in WSL, so cameras won't work in this environment.
jobdulo
After feeling like I am doing a lot of plastering in WSL I installed the Ubuntu OS.  Ran the application again. The GStreamer error went away.
The other thing I have learned during debugging this problem is that feeding the application a video input with audio will bring problems. Best to remove audio from own video recordings before using as input.
I would have loved it if the owners of the repo would have been more responsive. I realized the application puts an orange overlay on the live stream of any input video, and it's a mystery.
All in all, I am grateful for the help you guys have provided here. Thanks a lot!
Munesh_Intel
Hi Job,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Munesh
