HDDL Support on ARM Platform or not
SC_Huang
Our customer had try the openVINO raspbian version could work with NCS2 with Ubuntu16.04 on ARM v7 platform (32bits)
Does HDDL card also work with Ubuntu16.04 on ARM v7 or v8 platform (32bits or 64bits)?
It seems no HDDL plugin in openVINO raspbian version, can we use openVINO Linux version instead?
Shubha_R_Intel
Dear SC Huang,
Raspberry Pi has an ARM chip and certainly, you can use it as a host with a Myriad stick plugged in. For Raspberry Pi, you must use the raspbian 32-bit OS.
If you are talking about an accelerator board like Mustang-V100-MX8 then 64-bit Linux OS (such as CentOS and Ubuntu) are supported. 32-bit Linux is not supported on this accelerator board.
Hope it helps,
Shubha
Shubha_R_Intel
Dear SC Huang,
Hope it helps,
Shubha
SC_Huang
Thanks for kindly reply, Shubha.
Shubha_R_Intel
Dear SC Huang,
Of course ! Anytime !
Shubha
BBi
hi, Shubha R. (Intel),
          here is a question i wanna share with you, hope you could help me. tks
platform: FireFly-RK3399 arm-64bit
os          : Linux firefly 4.4.167-gd9f2125 #4 SMP Thu Aug 15 10:19:24 CST 2019 aarch64 aarch64 aarch64 GNU/Linux
issue      :  when i insmod hddl myd_ion.ko and and myd_vsc.ko on this machine, an error always occured as below decription
     steps---
            root@firefly:/#source /opt/intelR3/bin/setupvars.sh
            [setupvars.sh] OpenVINO environment initialized
           root@firefly:/#insmod intelR3/deployment_tools/inference_engine/external/hddl/drivers/myd_ion.ko
           [58201.493849] myd_ion: version magic '4.4.52-armada-17.10.3 SMP preempt mod_unload aarch64' should be '4.4.167-gd9f2125 SMP mod_unload aarch64'
             insmod: ERROR: could not insert module intelR3/deployment_tools/inference_engine/external/hddl/drivers/myd_ion.ko: Invalid module format
root@firefly:/opt# dmesg | tail
[56626.553340] rockchip-dwc3 usb0: USB peripheral connected
[56626.556781] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[56643.624290] fusb302 4-0022: connection has disconnected
[56643.636903] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[56643.638276] rockchip-dwc3 usb0: USB unconnected
[56644.120274] phy phy-ff770000.syscon:usb2-phy@e450.7: charger = USB_SDP_CHARGER
[56644.163403] fusb302 4-0022: CC connected in CC1 as UFP
[56644.173030] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[56644.173833] rockchip-dwc3 usb0: USB peripheral connected
root@firefly:/opt#
then, i tried to rebuild these two module with the 4.4.167 kernel (downloaded from https://mirrors.edge.kernel.org/pub/linux/kernel/v4.x/linux-4.4.167.tar.gz) but the same issue mentioned above appeard. Now it's blocked here...
Q: Do you have some good ideas ? Or could you give me some good suggestion or sth?
tks
