6592 Discussions
HDMI output cannot output audio after resetting the system
clongwai
My gadget is intel compute stick2. After resetting the system, the HDMI output cannot output audio, the volume symbol shows a red cross, and the output hardware cannot be recognized. What driver is needed? Or how to set it? I tried pairing it with a Bluetooth headset and it can output audio normally.
AlHill
What is the COMPLETE model number of your compute stick?
[Fear and the desire for control are primary motivators for shadow dwellers. ]
clongwai
AlHill
The wayback machine has these drivers archived for your stick:
https://web.archive.org/web/20210122232756/https://downloadcenter.intel.com/product/91065/Intel-Compute-Stick-STK1AW32SC
Be patient when using the wayback machine.  It is slow.
Also, you know that your stick is windows 10 32-bit only, correct?
clongwai
The problem has been solved. Thank you for your professional advice.
