How do I enable trace logging?
wearyhacker
I want to enable trace logging. So I can see in detail what this openvino-dev python snippet is doing.
import openvino.runtime as ov
core = ov.Core()
print (core.available_devices)
I have built and installed openvino with debug enabled. I have set the OPENVINO_LOG_LEVEL environment variable to 5.
What more do I need to do to see some trace logging. If log files are being created where are they?
Roger
Hairul_Intel
Hi Roger,
For your information, the LOG_LEVEL property is only for Debugging Auto-Device Plugin. As stated in the documentation, the OPENVINO_LOG_LEVEL provides the user with information on exceptions and error values for Auto-Device plugin only and not OpenVINO functions as a whole.
The code snippet you shared is only printing out a list of available devices and thus will not print any log info since it is not using the Auto-Device plugin.
Here is the result for setting the OPENVINO_LOG_LEVEL=5 and running Hello Classification Python Sample with AUTO device configuration:
Hairul
Hairul_Intel
Hi Roger,
Hairul
Hairul_Intel
Hi Roger,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Hairul
