How does the REST API for OVMS work?
RalphW
I have an OVMS running in a docker container and tried to use the KServe API via HTTP according to the following documentation: https://docs.openvino.ai/latest/ovms_docs_binary_input_kfs.html#doxid-ovms-docs-binary-input-kfs.
The container was started as follows:
docker run -d --rm -u $(id -u):$(id -g) -v $(pwd)/model:/models/face-detection -p 9000:9000 -p 9001:9001 openvino/model_server:latest --model_path /models/face-detection --model_name face-detection --port 9000 --rest_port 9001 --plugin_config '{"CPU_THROUGHPUT_STREAMS": "1"}' --shape auto --log_level DEBUG /bin/bash --layout NHWC:NCHW
To launch the inference I called:
curl -H "Content-Type: application/octet-stream" -H "Inference-Header-Content-Length: 141" http://192.168.121.123:9001/v2/models/face-detection/infer -d '{"model_name":"face-detection", "inputs":[{"name":"model_input", "shape":[1],"datatype":"BYTES","parameters":{"binary_data_size":"210765"}}]}' --data-binary @images/people1.jpeg
and got {"error": "Missing input with specific name - Required input: data"} as the result, so it seems OVMS is expecting the "data" field to be present  in the inference header - but if I got the documentation right, that field is not required when the binary extensions is used, instead the image should simply be appended to the inference header. Any idea how the request should look like?
RalphW
Hi Wan,
thanks again for the quick answer. In the mean time I found the issue. When using multiple -d (or --dataxxxx) options,  curl concatenates them, but with ampersands - so with my curl call the image was proceeded with & - thus, the encoding failed.
I found no solution that would send the correct request with just curl commandline options - but by appending the json header to the image and storing that to a file first I got a valid response from OVMS.
Thanks again,
Ralph
Wan_Intel
Hi RalphW,
Yes, you are right. The error you encountered: "error": "Missing input with specific name - Required input: data" was due to OpenVINO™ Model Server expecting the “data” field to be present.
On another note, are you using face-detection-adas-0001 from Intel’s Pre-Trained model? For your information, the input name for face-detection-adas-0001 is “data”.
Could you please change the input name to data instead of model_input and see if your issue was able to resolve?
Wan
RalphW
Hi Wan,
Thanks for your answer, I'm indeed a step further now!
I'm following the OVMS Quick Start Guide that uses model face-detection-retail-0004, that has indeed data as input name.
Now I'm getting the following error: {"error": "Image parsing failed"} with the image "people1.jpeg" that was used in the quick start guide.
I know that the shape of the image (1200x800) doesn't match the model's specification, but I thought that OVMS would resize the image accordingly. Would you have some suggestions?
Ralph
Wan_Intel
Hi RalphW,
Thanks for your information.
May I know which demo application are you using? Referring to sample code from KServe API usage samples, there is no --data-binary command but --binary_data command.
On another note, could you please follow the steps from Run the Client to perform inference with binary encoded image in KServe API usage samples and see if you still encounter the same issue?
Wan
RalphW
Hi Wan,
Thanks again,
Ralph
Wan_Intel
Hi RalphW,
Glad to know that you have solved your issue and thanks for sharing your answer in the community.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Wan
