6605 Discussions
How much memory does the Movidius™ Neural Compute Stick 2 have?
We know that NCS1 has 500MB internal memory (max. graphs up to 320MB).
What about NCS2? (could it fit YoloV2 or YoloV3?)
I'm currenty working on YoloV3 on NCS2. There are loads of problems currently (for example nearest-neighbor resampling is not supported and you must change it to bilinear). But the weight file for ssd_mobilenet_v2_coco is 33MB and for YoloV3 416x416 it's 119MB. So you should be able to fit YoloV3 even into NCS1.
If you find how to make YoloV3 work on NCS2, please message here.
Hi @bonastreyair
I apologize for not responding sooner.
The NCS2 has the same memory size (500 MB) as the NCS1
Sahira
I'm waiting for a solution to run yolov3 full version on NCSDK2
How much memory does that require? Just curious
