6584 Discussions
How to compile a model trianed with tensorflow estimator
I have trained a tensorflow model using the code for tensorflow triplet loss. The model was trained using a Tensorflow estimator. I tried to freeze the graph and run mvNCCompile but I'm getting errors. The list of operations is the following:
global_step/Initializer/zeros/shape_as_tensor
global_step/Initializer/zeros/Const
global_step
global_step/Assign
global_step/read
global_step/IsVariableInitialized
global_step/cond/Switch
global_step/cond/switch_t
global_step/cond/switch_f
global_step/cond/pred_id
global_step/cond/read
global_step/cond/read/Switch
global_step/cond/Switch_1
global_step/cond/Merge
global_step/add/y
global_step/add
filenames
compression_type
buffer_size
buffer_size_1
seed
seed2
count
batch_size
buffer_size_2
Iterator
TFRecordDataset
MapDataset
ShuffleDataset
RepeatDataset
BatchDataset
PrefetchDataset
MakeIterator
IteratorToStringHandle
IteratorGetNext
Reshape/shape
Reshape
model/block_1/conv2d/kernel/Initializer/random_uniform/shape
model/block_1/conv2d/kernel/Initializer/random_uniform/min
model/block_1/conv2d/kernel/Initializer/random_uniform/max
model/block_1/conv2d/kernel/Initializer/random_uniform/RandomUniform
model/block_1/conv2d/kernel/Initializer/random_uniform/sub
model/block_1/conv2d/kernel/Initializer/random_uniform/mul
model/block_1/conv2d/kernel/Assign
model/block_1/conv2d/kernel/read
model/block_1/conv2d/bias/Initializer/zeros/shape_as_tensor
model/block_1/conv2d/bias/Initializer/zeros/Const
model/block_1/conv2d/bias/Assign
model/block_1/conv2d/bias/read
model/block_1/conv2d/dilation_rate
model/block_1/conv2d/Conv2D
model/block_1/conv2d/BiasAdd
model/block_1/Relu
model/block_1/max_pooling2d/MaxPool
[other convolutions…]
model/block_4/max_pooling2d/MaxPool
model/Flatten/flatten/Shape
model/Flatten/flatten/strided_slice/stack
model/Flatten/flatten/strided_slice/stack_1
model/Flatten/flatten/strided_slice/stack_2
model/Flatten/flatten/Reshape/shape/1
model/fc_1/dense/kernel/Initializer/random_uniform/shape
[fully connected operations…]
model/fc_2/dense/bias/read
model/fc_2/dense/MatMul
model/fc_2/dense/BiasAdd
[other operations]
I am confused about what the input node to be passed to mvNCCompile should be, since there is not a "input" node.
