6614 Discussions
How to compile customized yolo network with movidius? Compiling YOLO network fails with value error cannot reshape array of size 4056 into shape (1,1,1)
AAhma26
I have created inference model of yolo on tensorflow 1.13.1 and trying to compile to generate movidius graph. I have 3 classes and 3 anchor boxes predicted from network. However, I am facing the following error on compiling:
res.shape: (1, 13, 13, 3, 8)
Traceback (most recent call last):
 File "/usr/local/bin/mvNCCompile", line 206, in <module>
  create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args.cpp, args)
 File "/usr/local/bin/mvNCCompile", line 185, in create_graph
  load_ret = load_network(args, parser, myriad_config)
 File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 146, in load_network
  parse_ret = parse_tensor(arguments, myriad_conf)
 File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 1751, in parse_tensor
  res = res.reshape(1, 1, res.shape[0])
ValueError: cannot reshape array of size 4056 into shape (1,1,1)
Sahira_Intel
Hi AAhma26,
Are you using NCSDK2? Can you please attach your model and I can take a look at it.
Sincerely,
Sahira
AAhma26
Hello Sahira,
Thanks for your response. I am using Tensorflow 1.9.0 and also 1.13.0 with Movidius 2.10 .
I am attaching my model below [yolo_net] method. I tried compiling it again but instead of returning 13x13x3x8 shape from my model I combined these array and changed the last line of my model to
y = tf.reshape(net, shape=(-1, 13* 13* (len(anchor)//2)* (num_class+ 5)), name='output') which compiled successfully. Am I doing it the correct way?
import tensorflow as tf
import yolo.config as config
import cv2
import numpy as np
def maxpool_layer(x,size,stride,name):
with tf.name_scope(name):
x = tf.layers.max_pooling2d(x, size, stride, padding='SAME')
return x
def conv_layer(x, kernel, depth, train_logical,name):
with tf.variable_scope(name):
x = tf.layers.conv2d(x, depth, kernel, padding='SAME', kernel_initializer=tf.contrib.layers.xavier_initializer_conv2d(), bias_initializer=tf.zeros_initializer())
x = tf.layers.batch_normalization(x, training=train_logical, momentum=0.99, epsilon=0.001, center=True, scale=True)
return x
def yolo_net(x, train_logical=False):
x = conv_layer(x, (3, 3), 32, train_logical, 'conv1')
x = maxpool_layer(x, (2, 2), (2, 2), 'maxpool1')
x = conv_layer(x, (3, 3), 64, train_logical, 'conv2')
x = maxpool_layer(x, (2, 2), (2, 2), 'maxpool2')
x = conv_layer(x, (3, 3), 128, train_logical, 'conv3')
x = conv_layer(x, (1, 1), 64, train_logical, 'conv4')
x = conv_layer(x, (3, 3), 128, train_logical, 'conv5')
x = maxpool_layer(x, (2, 2), (2, 2), 'maxpool5')
x = conv_layer(x, (3, 3), 256, train_logical, 'conv6')
x = conv_layer(x, (1, 1), 128, train_logical, 'conv7')
x = conv_layer(x, (3, 3), 256, train_logical, 'conv8')
x = maxpool_layer(x, (2, 2), (2, 2), 'maxpool8')
x = conv_layer(x, (3, 3), 512, train_logical, 'conv9')
x = conv_layer(x, (1, 1), 256, train_logical, 'conv10')
x = conv_layer(x, (3, 3), 512, train_logical, 'conv11')
x = conv_layer(x, (1, 1), 256, train_logical, 'conv12')
x = maxpool_layer(x, (2, 2), (2, 2), 'maxpool13')
x = conv_layer(x, (3, 3), 1024, train_logical, 'conv14')
x = conv_layer(x, (1, 1), 512, train_logical, 'conv15')
x = conv_layer(x, (3, 3), 1024, train_logical, 'conv16')
x = conv_layer(x, (1, 1), 512, train_logical, 'conv17')
x = conv_layer(x, (3, 3), 1024, train_logical, 'conv18')
x = conv_layer(x, (3, 3), 1024, train_logical, 'conv19')
x = conv_layer(x, (3, 3), 1024, train_logical, 'conv20')
x = conv_layer(x, (1, 1), (len(anchor)//2) * (num_class + 5), train_logical, 'conv23')
                        #?,13,13,3,8
y = tf.reshape(x, shape=(-1, 13, 13, len(anchor)//2, num_class+ 5), name='y')
return y
def sigmoid(x):
  return 1./(1. + np.exp(-x))
def softmax(x):
  e_x = np.exp(x - np.max(x))
  out = e_x/e_x.sum()
  return out
##########Main Starts Here################
input_image=cv2.imread('./person_1.jpg')
actual_height,actual_width,_=input_image.shape
input_image=cv2.resize(input_image,(config.IMAGE_H,config.IMAGE_W))
image=tf.placeholder(tf.float32,shape=[1,config.IMAGE_SIZE,config.IMAGE_SIZE,3],name='Input')
saver = tf.train.Saver(tf.global_variables())
with tf.Session() as sess:
  sess.run(tf.global_variables_initializer())
  sess.run(tf.local_variables_initializer())
  #saver.restore(sess,'./yolo_data_model')#meta file stored during training, Uncomment to save Inference Model
saver.restore(sess,'.'+'/yolo_inference') #Generated Inference model, Comment if creating Inference Model
  print('model loaded')
  prediction=sess.run(y_conv=yolo_net(image),feed_dict={image:input_image})#Comment if creating Inference Model
  #read previously saved network
  #saver.save(sess,'./output/NN.ckpt')#Uncomment if creating Inference model
  tf.train.write_graph(sess.graph_def,"./output/","NN.pb",as_text=False)#Uncomment if creating Inference model
Sahira_Intel
Hi AAhma26,
I think y = tf.reshape(net, shape=(-1, 13* 13* (len(anchor)//2)* (num_class+ 5)), name='output') is correct. Please let me know if you have any further questions.
Sincerely,
Sahira
