How to convert ShuffleNet by using Model Optimizer?
He__Jinyang1
  Hello, everyone! I want to convert my ShuffleNet by using Model Optimizer. There is something wrong:
 [ ERROR ]  Exception occurred during running replacer "None" (<class 'extensions.front.tf.assign_elimination.AssignSubElimination'>): Data flow edge coming out of AssignSub node tower_0/ShuffleNetV2/Stage3/unit_7/depthwise/BatchNorm/AssignMovingAvg_1
I guess OpenVINO don't support some operation or node?  what should I do for converting the  ShuffleNet model? Thanks!!!!
Sahira_Intel
Hi Jinyang,
What version of Shufflenet are you using? OpenVINO only supports Shufflenet V2 on Caffe - please make sure you are using the correct version. To convert your model to IR, see here
Please let me know if this information is helpful.
Sahira
He__Jinyang1
Sahira R. (Intel) wrote:
Hi Jinyang,
Sahira
Thanks for your help Sahira! Actually, I want to convert a trained Shufflenet V2 network which is used to detect facial landmark. My network is trained by TensorFlow. I want to add the facial landmark network to the OpenVINO-Driver-Behaviour project for facial analysis.
Sahira_Intel
Hi Jinyang,
Shufflenet  V2 is currently not a supported topology by Tensorflow (only Caffe and ONNX) - see here for a list of supported Tensorflow topologies.
Please let me know if you have any further questions.
Sahira
