6595 Discussions
How to integrate OpenVINO with an existing C++ project (find_package, include_dir)
adammpolak
- Working through hello_classification example
- Would like to integrate hello_classification example into existing C++ project
- I must incorporate CMakeLists.txt needs of OpenVINO to run the project
- There is no explanation online of what you need to incorporate into an existing CMakeLists.txt
From /cpp/CMakeLists.txt, what is important to incorporate to run OpenVINO samples in an existing C++ project?
To find the InferenceEngine the current CMakeLists.txt has:
set(InferenceEngine_DIR "${CMAKE_BINARY_DIR}")
What is this instead if it is being incorporated in another project?
Also trying to build this issue occurs where it is not able to locate the header files, do I need to specify an include directory?
fatal error: inference_engine.hpp: No such file or directory
12 | #include <inference_engine.hpp>
adammpolak
Hello Iffa!
Thank you for your response!
So I followed the instruction and even with setting the variables and including what was included in the documentation, it was still not able to find the header files.
What is missing from the documentation is:
include_directories(${InferenceEngine_INCLUDE_DIRS})
include_directories(${InferenceEngine_INCLUDE_DIRS}/../samples/cpp/common/utils/include)
This will allow the samples to be run in other C++ projects, hope this helps anyone else that got stuck!
Iffa_Intel
You will need to carefully follow this guide :
https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_Integrate_with_customer_application_new_API.html
It is not as straightforward as you will need to change code/script accordingly to incorporate your requirements.
The most crucial thing is to Include Inference Engine, nGraph and OpenCV libraries in project/CMakeLists.txt.
OpenCV integration is needed mostly for pre-processing input data and ngraph for more complex applications using ngraph API. Please help to refer to the documentation for further details.
Sincerely,
Iffa
adammpolak
Hello Iffa!
Iffa_Intel
Glad you had found the solution for that.
Thanks for the information.
That would help others who might be facing the same issue.
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
