6594 Discussions
How to make input fixed in a tensorflow zoo model?
I took a Resnet Inception V2 model from TensorFlow Zoo which should be supported and I retrained it on my custom dataset. After retraining, I took the weights from inference folder and tried to use the mvncCompile on them and got the error:
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 259, in parse_tensor
input_data = np.random.uniform(0, 1, shape)
File "mtrand.pyx", line 1309, in mtrand.RandomState.uniform
File "mtrand.pyx", line 242, in mtrand.cont2_array_sc
TypeError: 'NoneType' object cannot be interpreted as an integer
The command I used: mvNCCompile -s 12 frozen_inference_graph.pb -in=image_tensor -on=raw_detection_scores
Now I realize this is because movidius doesn't support variable sized inputs but can anyone please tell me where do I change the code to make the input fixed size?
This is the model code: https://github.com/tensorflow/models/blob/master/research/object_detection/models/faster_rcnn_inception_v2_feature_extractor.py
I'm just a beginner so any help will be appreciated.
Hi @ali18997
Since you're using Tensorflow, you'll have to change your code to declare a specific size for the input placeholder instead of using a variable size (variable sized inputs are set as "none"). Here is an example of a fixed input size:
input_image = tf.placeholder("float", [1, image_size, image_size, 3], name="input"). (if this was set to accept variable input sizes, type "None" would be passed).
I hope this is helpful!
Sahira
