6585 Discussions
How to "kill HDDL plugin and reset VPU" for Windows OS
Hyun-Kyu_L_Intel
Dear team,
When I look at following configuration guide for Linux OS, it explains about how to Kill the HDDL Plugin backend service (hddldaemon) and reset VPUs.
Could you provide guide how I can do the same "kill HDDL plugin and reset VPU" for Windows OS, too?
Configuration Guide for the Intel® Distribution of OpenVINO™ toolkit and the Intel® Vision Accelerator Design with Intel® Movidius™ VPUs on Linux*
Troubleshooting
Unable to run inference with the MYRIAD Plugin after running with the HDDL Plugin
Running inference with the MYRIAD Plugin after running with the HDDL Plugin is failed with the following error generated:
  E: [ncAPI] [ 965618] [MainThread] ncDeviceOpen:677 Failed to find a device, rc: X_LINK_ERROR
Possible solutions (use one of the following):
  • Reboot the host system and run with the MYRIAD Plugin
  • Kill the HDDL Plugin backend service (hddldaemon) and reset all Intel® Movidius™ VPUs before running an application that uses the MYRIAD Plugin:
kill -9 $(pidof hddldaemon autoboot)
pidof hddldaemon autoboot # Make sure none of them is alive
source /opt/intel/openvino/bin/setupvars.sh
${HDDL_INSTALL_DIR}/bin/bsl_reset
Max_L_Intel
Hi, Hyun-Kyu L.
There's no such similar solid recommendation for Windows (except rebooting the host), but you can try to find something related to HDDL in the Windows Task Manager (Ctrl+Alt+Del) -> Processes section, and then do "End task" on it.
Then use IEI Reset software that being installed per this guide https://docs.openvinotoolkit.org/latest/_docs_install_guides_movidius_setup_guide.html#iei_reset_software_installation
Best regards, Max.
