6594 Discussions
How to set VPU_LOGGER_SECTION logging level
OKI__HIdetaka
I would like to get some trace log during compiling and loading network in Myriad Plugin. To look at source code, there seems I could use env.log->trace()  and  VPU_LOGGER_SECTION(env.log), but I cannot find how to set logging level to "trace" and to enable logging function.
I will appreciate to advise me how to use logging function.
Iffa_Intel
Greetings,
May I know where did you get this source code? If possible could you share it with me?
Besides,which device are you using (eg: NCS) and do you have hddl together with it?
If you have, then this method is possible for you: https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/hddldeamon-log-file-for-VPU/td-p/1165725
Sincerely,
Iffa
OKI__HIdetaka
Hi, thanks for your reply.
Regarding source code, I cloned from https://github.com/openvinotoolkit/openvino with -b  "releases/2020/3" for 2020.3 LTS.
I use arm64 box and Mustang-M2BM-MX2 board with Myriad plugin. I do not run HDDL plugin or hddl daemon on the box since I do not have them for arm64. I am afraid that I could not apply hddl daemon configuration described in the topic.
The original purpose for logging was to profile cpu runtime of compileNetwork() called from  ie.LoadNetwork() in Myraid plugin.  After posting this topic, I noticed that I could avoid compiling runtime to use ie.ImportNetwork() with pre-compiled .blob file. The priority of this issue is not so high, but I would like to confirm how to enable logging for some future analysis.
Iffa_Intel
Have you tried using --log_level=DEBUG together with the command you used to run the model? I believe this is one of the common ways for logger.
For instance: ./object_detection_sample_ssd -i <path_to_image>/inputImage.bmp -m <path_to_model>person-detection-retail-0013.xml -d VPU --log_level=DEBUG
Sincerely,
Iffa
OKI__HIdetaka
Usually I use benchmark_app in toolkit for network model evaluation, and it does not accept --log_level= option.
To look at the source code of benchmark_app, there is no declaration for  log_level or something in command line option.
I find the following code in the cpp source ;
else if (device == "MYRIAD") {
ie.SetConfig({{ CONFIG_KEY(LOG_LEVEL), CONFIG_VALUE(LOG_WARNING) }}, device);
It seems that modifying the source and  re-compiling would be needed to change the LOG_LEVEL.
Iffa_Intel
Could you help to specifically specify the location of the file, eg: deployment_tools/inference_engine/samples so I could take a closer look on this.
Basic functions in benchmark apps is as here: https://www.youtube.com/watch?v=n7HNNR3r4WE
Sincerely,
Iffa
OKI__HIdetaka
The source code location is  line 226 of openvino/inference-engine/samples/benchmark_app/main.cpp   in the tree downloaded from github or the same line of openvino_2020.3.194/deployment_tools/inference_engine/samples/cpp/benchmark_app/main.cpp in the downloaded  binary package.
Iffa_Intel
Any chance that you could build Benchmark app in debug mode with -DCMAKE_BUILD_TYPE=Debug parameter instead of -DCMAKE_BUILD_TYPE=Release from the article Build and Run Object Detection Sample - https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_raspbian.html#run-sample
Sincerely,
Iffa
petercoffin80
got solution to my problem. Thanks
OKI__HIdetaka
Hi ,
Thanks for update.
I built sample programs with -DCMAKE_BUILD_TYPE=Debug successfully and ran benchmark_app. I cannot find log output text in syslog or dmesg.  I will check the document again and will update status.
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
