6594 Discussions
How to take outputs from multiple layers of the same Graph object ?
Some neural net architectures have more than one output layers. Movidius graph compilation command has option to specify only one output layer. Is it possible to take outputs from multiple layers of the same graph?
Sahad
@sahadcp We currently don't have a tool that takes outputs from multiple layers of the same graph. It may be possible if you concat the desired outputs together into one output.
Alright Tom, thanks..
