6605 Discussions
How to work the Yollo(Caffe) learned model which contains custom layers?
I want to infer the learned Yollo(Caffe) model with Movidius neural Compute Stick.
The learned model contains layers type which I created(custom layer).
The following error occurred when I am trying to make a Graph file using by mvNCCompile command.
/usr/local/bin/ncsdk/Controllers/CaffeParser.py:231: RuntimeWarning: invalid value encountered in sqrt [Error 4] Toolkit Error: Stage Type Not Supported: Reorg
https://movidius.github.io/ncsdk/caffe.html
According to the website…
"Caffe Layer Support:The following layers are supported in Caffe by the NCSDK.
The NCSDK does not support network training, so some layers that are only required for training are not supported."
So I have a question, is it possible to work the Yollo(Caffe) learned model which includes custom layer
with Movidius neural Compute Stick?
If custom layer isn't supported, how can I use it on Movid neural Compute Stick?
Do you have any suggestions?
