6582 Discussions
I can't configure a .onnx extension file to IR
Ziad21
I'm receiving this kind of problem as i am trying to convert an .onnx extension through the model optimizer using both mo.py and mo_onnx.py so please i would be thankful if someone can help
thanks
ERROR:root:----------------- INTERNAL ERROR ----------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
ERROR:root:Unexpected exception happened.
[ ERROR ] Unexpected exception happened.
ERROR:root:Please contact Model Optimizer developers and forward the following information:
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
ERROR:root:[Errno 13] Permission denied: 'C:\\Program Files (x86)\\Intel\\openvino_2021.4.752\\deployment_tools\\model_optimizer\\.\\anomalydetect_tmp.bin'
[ ERROR ] [Errno 13] Permission denied: 'C:\\Program Files (x86)\\Intel\\openvino_2021.4.752\\deployment_tools\\model_optimizer\\.\\anomalydetect_tmp.bin'
ERROR:root:Traceback (most recent call last):
File "C:\Program Files (x86)\Intel\openvino_2021.4.752\deployment_tools\model_optimizer\mo\main.py", line 394, in main
ret_code = driver(argv)
File "C:\Program Files (x86)\Intel\openvino_2021.4.752\deployment_tools\model_optimizer\mo\main.py", line 356, in driver
ret_res = emit_ir(prepare_ir(argv), argv)
File "C:\Program Files (x86)\Intel\openvino_2021.4.752\deployment_tools\model_optimizer\mo\main.py", line 268, in emit_ir
prepare_emit_ir(graph=graph,
File "C:\Program Files (x86)\Intel\openvino_2021.4.752\deployment_tools\model_optimizer\mo\pipeline\common.py", line 213, in prepare_emit_ir
serialize_constants(graph, bin_file)
File "C:\Program Files (x86)\Intel\openvino_2021.4.752\deployment_tools\model_optimizer\mo\back\ie_ir_ver_2\emitter.py", line 38, in serialize_constants
with open(bin_file_name, 'wb') as bin_file:
PermissionError: [Errno 13] Permission denied: 'C:\\Program Files (x86)\\Intel\\openvino_2021.4.752\\deployment_tools\\model_optimizer\\.\\anomalydetect_tmp.bin'
[ ERROR ] Traceback (most recent call last):
IntelSupport
Community Manager
Hi Ziad21,
Thanks for reaching out.
This is an issue with writing permissions for the directory that you are converting the model. Since you are using Windows, I would suggest three approaches to you:
  • Open Command Prompt and run as Administrator.
  • Change to a directory that doesn't need Administrator rights to write to it, for example, C:\Users\your-username\Desktop
  • Disconnect your network from VPN.
Aznie
IntelSupport
Community Manager
Hi Ziad21,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
