6605 Discussions
I have a i9-11900k - What are the best CPU/GPU combinations for Open VINO Super Resolution?
JohnnieBG
I have a i9-11900k - What are the best CPU/GPU combinations for Open VINO Super Resolution?Open VINO SR.jpg
Aznie_Intel
Hi JohnnieBG,
Thank you for reaching out. We cannot recommend a specific system for you, as OpenVINO is optimized for Intel CPUs, iGPUs, and discrete GPUs. The best choice depends on your priorities whether you want to maximize performance, efficiency, or cost-effectiveness.
To ensure compatibility, I recommend referring to the OpenVINO System Requirements.
Aznie
JohnnieBG
You didn't understand my question!
I have an i9 and when I use Open VINO super resolution in Audacity a pop box appears (see above) allowing me to select either GPU or CPU processing for the three stages of Encoding, DDPM and Decoding.  What would the optimum settings be for these with an i9-11900K processeor?
Peh_Intel
Hi JohnnieBG,
I would suggest assigning CPU for Encoder Device and GPU for DDPM Device and Decoder Device.
Peh
Aznie_Intel
Hi JohnnieBG,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
