6605 Discussions
I improved the precision of my tiny-YoloV3's Github repository
Hyodo__Katsuya
Innovator
Hello everyone. I solved the problem of low precision. (Python) There was a mistake in the logic of preprocessing and postprocessing. It can be estimated with accuracy of 2 to 3 times of the previous one. I'm sorry for the inconvenience. https://github.com/PINTO0309/OpenVINO-YoloV3.git
McDonald__Shaun
A good man admits his mistakes - a great man corrects them! Thank you, sir!
Shubha_R_Intel
Wonderful Katsuya  !
Thanks !
Shubha
Lee__Terry
That is great Katsuya. I have being waiting for a solution to the problems. I will try it out with NSC2.
Terry
nikos1
Valued Contributor I
Thank you Katsuya-san!
Lee__Terry
Hello Katsuya,
Thanks again for solving the yolo3 precision issue.
I was able to see the precision improvements when running your example with my data.
I get an error when converting weight using the weight from the download.
The command is: python convert_weights.py  --weights_file E:\t\yolo3\OpenVINO-YoloV3-master\weights\yolov3-tiny.weights --class_names coco.names --size 416 --data_format NHWC
Output:
detect_1.shape = (1, 507, 85)
detect_2.shape = (1, 2028, 85)
detect_3.shape = (1, 8112, 85)
Traceback (most recent call last):
  File "convert_weights.py", line 52, in <module>
    tf.app.run()
  File "C:\ProgramData\Anaconda3\lib\site-packages\tensorflow\python\platform\app.py", line 125, in run
    _sys.exit(main(argv))
  File "convert_weights.py", line 40, in main
    scope='detector'), FLAGS.weights_file)
  File "E:\t\yolo3\OpenVINO-YoloV3-master\utils.py", line 122, in load_weights
    (shape[3], shape[2], shape[0], shape[1]))
ValueError: cannot reshape array of size 391694 into shape (512,256,3,3)
Did I missed something simple ?
Should I follow the link  https://github.com/jinyu121/DW2TF to convert  yolo model to tensorflow ?
Terry
Hyodo__Katsuya
Innovator
I am also examining the problem now.
It takes a little time.
Lee__Terry
Thanks for looking into it.
Golkar__Grace
Lee, Terry wrote:
Hello Katsuya,
Output:
    tf.app.run()
Terry
Hi Terry,
Actually ,I have exact problem with yolo tiny version3 .I was wondering whether you have found a solution for it .If yes could you please share it with me .Thanks .
Golkar__Grace
Hi Terry,
 I have the same problem with Yolo tiny v3 .
File "load_weights.py", line 44, in load_weights
I was wondering whether you found a solution and if yes could you please share it with me .
Thanks .
Grace
Hyodo__Katsuya
Innovator
