6598 Discussions
I'm using Open VINO in Audacity. Does this support Intel Neural Compute Stick 2 as an NPU?
JohnnieBG
i.e. would I be able to use CPU as the Encoder Device, the INCS2 as the NPU for DDPM device and GPU as the decoder device?
Thank you.
Peh_Intel
Hi JohnnieBG,
For your information, OpenVINO™ AI Plugins for Audacity is used to run AI models on supported accelerators found on the user’s system such as CPU, GPU and NPU.
However, Intel Neural Compute Stick 2 is not the NPU device and not supported. NPU is a low-power hardware solution, introduced with the Intel® Core™ Ultra generation of CPUs (formerly known as Meteor Lake).
Peh
Peh_Intel
Hi JohnnieBG,
This thread will no longer be monitored since we have provided answer. If you need any additional information from Intel, please submit a new question.
Peh
