IECore fails to load custom network
CSche22
Hello
When I try to load my network with the IECore.load_network() function I get the following error:
exec_net = ie.load_network(model, device_name="MYRIAD")
Traceback (most recent call last):
  File "<ipython-input-16-ffe86d643791>", line 1, in <module>
  File "ie_api.pyx", line 178, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 187, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Failed to find reference implementation for `Select83_clip` Layer with `Clamp` Type on constant propagation
The network was converted with the model optimizer from .onnx to .xml and .bin everything worked fine. As far as I know the Clip layer should be supported. When I try to load a model dowanloaded from the model zoo everything just works fine. Maybe someone has an idea how I could troubleshoot this?
Thanks for your help
David_C_Intel
Hi chrisschelle,
Thanks for reaching out. This thread is being discussed here.
David
