INT8 calibration_tool error
Hou_y_1
I have a model trained offline, I converted it  to IR (xml and bin, fp32). when I used the calibration_tool to generate INT8 model,  met a exception:
my command :  ./calibration_tool -t C -i ../../data/ -m ../../xx_tensor.xml
[ INFO ] InferenceEngine:
	API version ............ 1.4
	Build .................. 19154
[ INFO ] Parsing input parameters
[ INFO ] Loading plugin
	API version ............ 1.5
	Build .................. lnx_20181004
	Description ....... MKLDNNPlugin
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 32
[ INFO ] Collecting accuracy metric in FP32 mode to get a baseline, collecting activation statistics
Progress: [....................] 100.00% done
  FP32 Accuracy: 0.00%
[ INFO ] Verification of network accuracy if all possible layers converted to INT8
Validate int8 accuracy, threshold for activation statistics = 100.00
/opt/intel/computer_vision_sdk/inference_engine/samples/calibration_tool/main.cpp_440
/opt/intel/computer_vision_sdk/inference_engine/samples/calibration_tool/main.cpp_442
/opt/intel/computer_vision_sdk/inference_engine/samples/calibration_tool/calibrator_processors.cpp_217
/opt/intel/computer_vision_sdk/inference_engine/samples/calibration_tool/calibrator_processors.cpp_232
../../xx_tensor.bin
/opt/intel/computer_vision_sdk/inference_engine/samples/calibration_tool/calibrator_processors.cpp_243
/opt/intel/computer_vision_sdk/inference_engine/samples/calibration_tool/calibrator_processors.cpp_249
[ ERROR ] Inference problem:
min and max sizes should be equal to channels count
The model (IR) can be excute normally with mkldnn plugin. how can i convert to int8 model by calibration tool?
Hou_y_1
I attach my model.
Shubha_R_Intel
Hi Hou. I was able to reproduce your problem however xx_tensor.labels is missing from your zip file. I don't think it has any relevance to the issue however. Please remain patient while I investigate this issue. Thanks for using OpenVino !
Shubha
Hou_y_1
Shubha
thanks for you reply, the model is binary classfication.  I upload a part of data and label file.
Shubha_R_Intel
Dear Hou:
If you look at your IR XML your output dimensions are 2x32 which is not the output size for a traditional classification network. So instead of -t C use instead -t RawC and it will work.
layer id="77" name="ip2" precision="FP32" type="FullyConnected">
            <data out-size="2"/>
            <input>
                <port id="0">
                    <dim>32</dim>
                    <dim>256</dim>
                </port>
            </input>
            <output>
                <port id="2">
                    <dim>32</dim>
                    <dim>2</dim>
                </port>
            </output>
Thanks for using OpenVIno !
Shubha
Hou_y_1
Dear Hou:
            <input>
                <port id="0">
                    <dim>32</dim>
                    <dim>256</dim>
                </port>
            </input>
            <output>
                <port id="2">
                    <dim>32</dim>
                    <dim>2</dim>
                </port>
            </output>
Shubha
I excute the command as "./calibration_tool -t RawC -i ../../data/ -m ../../xx_tensor.xml",  generate xx_tensor_i8.xml and bin. But I inference with Int8 model, met the same error.
LoadNetwork error
..\src\inference_engine\cnn_network_int8_normalizer.cpp:106[NETWORK_NOT_LOADED]
../src/inference_engine/cpp_interfaces/impl/ie_plugin_internal.hpp:132_k:\openclworkspace\openvino_proj\openvino_proj\inferenceengine.cpp_214
32 is just batch size, in my deploy model, the num is 1. I alter it to 32 in order to  speed up  processing of calibration. I changle it to 1, and excute  "./calibration_tool -t C -i ../../data/ -m ../../xx_tensor.xml",  the same error is still happened. I attach my model.
______________________________________________________________________________________________________________________________________
I have other question. how to calibrate  Metric learning model ?  I train model as classification, but I don't need results of the  last softmax layer, or other classifcation layers.  the number of the classifcation is huge. I can delete the last layer, using "-t RawC" to get  statistics ?
Looking forward to your reply. thanks.
Shubha_R_Intel
Dear Hou, sorry about that. What do you mean by "Metric learning model"  or is that the kind of model you're dealing with here  (it's just a name, in other words) ?
May I ask, how are you inferencing ? Are you running one of the OpenVino samples ? Or have you written your own code ?
If you have written your own code can you also include that in the zip file - or you can send me a private message with the attachment (use Send Author A Message link).
Shubha
