IR Model and Tensorflow Versioning
Mspiz
Is the IR transformation model dependent from Tensorflow version?
I mean, can I convert to IR a model trained with Tensorflow 0.12 , or there is some restriction in the conversion process ?
Mark_L_Intel1
Hi Carmine,
Model optimizer is more focusing on the model version rather than the framework version, so shouldn't the question be:
For specific model, doesn't its version validated by model optimizer can be trained by Tensorflow 0.12?
Mark
Mspiz
Hi Mark,
thanks to addressing me on the question proposal, do you know also the right answer ? ;)
Cheers,
Carmine
Mark_L_Intel1
Hi Carmine,
Looks like I was wrong, you can check the following file, in Rel 3, this should be at line 51, it seems support TensorFlow >=1.2.0:
<OpenVINO install dir>/deployment_tools/model_optimizer/mo/utils/versions_checker.py
Let me know if it helps.
Mark
