Incorrect conversion from Tensorflow model
Sitnikov__Igor
Hi everyone,
I have next problem: I had trained model that had h5 format using keras. Then I converted this model to tensorflow pb model. And after conversion tensorflow model using model optimizer, I get incorrect inference output result. I'm using OpenVINO toolkit R4.
Commands were used for conversion model:
1. python3 mo.py --input_model tf_model.pb -b 1
2. python3 mo.py --input_model tf_model.pb -b 1 --reverse_input_channels
3. python3 mo.py --input_model tf_model.pb -b 1 --reverse_input_channels --scale_values [255,255,255]
4. python3 mo.py --input_model tf_model.pb -b 1 --reverse_input_channels --mean_values [255,255,255]
5. python3 mo.py --input_model tf_model.pb -b 1 --reverse_input_channels --scale_values [255,255,255] --mean_values [255,255,255]
6. python3 mo.py --input_model tf_model.pb -b 1 --disable_nhwc_to_nchw
All these commands weren't work for me.
And one more thing: my original tf model had shape [1, 224, 224, 3], but after conversion it shape had [1, 3, 224, 224]. Is it OK?
In archive: pb model, bin and xml files of IR model, demo that demontrate inference output of models. And requirements.txt for dependencies. Command for running:
For tensorflow model inference:
For IR model inference:
Thanks for your help and I'm sorry for my english.
Hyodo__Katsuya
Innovator
You'd better use R5 and "mo_tf.py".
