Protobuf error when use model optimizer
Morishige__Akihito
When I convert the caffemodel by use follow command, error is occured.
I used install prerequisities.bat and protobuf-3.5.1-py3.6-win-amd64.egg,  but error is not revised. What should I do ?
[command]
・mo.py --framework caffe --input_model ○○○.caffemodel --input_proto ○○○.prototxt --input_shape [1,3,300,300] --output_dir ○○○ --scale 1 --data_type FP32
[ ERROR ]
Detected not satisfied dependencies:
        protobuf: not installed, required: 3.5.1
Please install required versions of components or use install_prerequisites script
C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\install_prerequisites\install_prerequisites_caffe.bat
Note that install_prerequisites scripts may install additional components.
mahinlma
Upgrade protobuf
pip install -U protobuf
which helps to resolve the issue
Monique_J_Intel
Hi Akihito,
Are you still facing the issue?
Kind Regards,
Monique Jones
Morishige__Akihito
Yes, I still facing the issue.
Could you tell me how to upgrade protobuf except for using openvino folder.
I used install_prerequisites_caffe.bat, and  protobuf-3.5.1-py3.6-win-amd64.egg, i don't know why protobuf doesn't upgrade.
Tay_L_Intel
Hope it's not too late. I had the same issue and resolved it by updating protobuf. I used anaconda package manager to install protobuf.
# install the latest protobuf using anaconda package manager: conda install -c anaconda protobuf
Or if you don't use anaconda package, try this link: https://stackoverflow.com/questions/13616033/install-protocol-buffers-on-windows
(Not sure if this link works tho, cuz I'm working on Ubuntu.)
Morishige__Akihito
Thanks much. I solved thid problem.
