6616 Discussions
Incorrect responses when running OpenVINO Inference
Zimm__Chris
I have been trying to convert my custom segmentation model to run on the OpenVINO target. I have generated the ir file and was trying to do inference from inference samples. I am getting incorrect responses on the OpenVINO Inference but when run normally it is working fine. Would you have any tips on why this might be happening. Expecting help from your side on this.
SuryaPSC_Intel
Hi Chris,
Can you please share following information:
  1.  Which model are you using and is it one of the supported models of OpenVINO?
  2.  What command did you use to convert the model?
  3.  Which sample are you using with your model?
Best Regards.
Surya
