Installation failed
Hi
I am trying to install nc sdk on a raspberry with stretch.
I am following the instructions on https://developer.movidius.com/start but after run "make install" I get this error:
Caffe not found, installing caffe…
/opt/movidius/bvlc-caffe
HEAD is now at eeebdab1 Merge pull request #5530 from willyd/nccl-py3
Switched to branch 'master'
Your branch is up-to-date with 'origin/master'.
error: cannot open .git/FETCH_HEAD: Permission denied
Switched to a new branch 'fathom_branch'
Compiling Caffe…
./install-ncsdk.sh: line 481: 23113 Segmentation fault cmake ..
make[1]: Entering directory '/opt/movidius/bvlc-caffe/build'
make[1]: *** No rule to make target 'all'. Stop.
make[1]: Leaving directory '/opt/movidius/bvlc-caffe/build'
Installing caffe…
make[1]: *** No rule to make target 'install'. Stop.
Installation failed. Error on line 522
So I tried with sudo make install:
Already up-to-date.
Compiling Caffe…
./install-ncsdk.sh: line 481: 23683 Segmentation fault cmake ..
Installing caffe…
what I am doing wrong?
