Installation issue
Following the SDK installation instructions, I encountered the following error. I am running on a recently upgraded ubuntu 16.04 running with VMWare on an OS X host. Any ideas?
Output is in the following gist: https://gist.github.com/jbirchfield-ps/ac84626d2229ca3663f7cec07705b460
I guess you have Anaconda on your system, installed. Try removing the anaconda from your PATH environment variable. in ~/.bashrc and then try to install it again on a new terminal
if didn't work, try this after that,
Ty. I was able to get further with the second suggestion. However, I did a fresh install of ubuntu and retried and everything installed fine.
However, it is not recognizing the device. I am using VMWare Fusion on a Mac, and it says the device is connected to my VM. Are there any additional steps for running in VMWare?
@birchsport Make sure you set two USB filters for the NCS. You can check out AshwinVijayakumar's post for more information at: https://ncsforum.movidius.com/discussion/406/ncs-on-windows-10-with-virtualbox#latest. You can visit https://movidius.github.io/ncsdk/VirtualMachineConfig.html for more information on virtual machine configurations.
Thank you everyone…I eventually got it running in VMWare….the frustrating thing was, it worked fine in my second usb port, but not the one I was originally trying in!
