6585 Discussions
Installation timing out for python server (Open vino installation)
Pulkit_J_Intel
I am unable to get past install_prerequisites.bat. It tries to retrieve from python network, but times out. Desperately seeking some help on this.
I have followed the instructions below. I even tried reinstalling and installing again. Still doesn' work.
Please see the image link of the error in this url.
https://imgur.com/a/tL4ssc1? (failing)
https://imgur.com/a/QHq0kjw (passing)
Pulkit
Microsoft Visual Studio* with C++ 2017 , with MSBuild, and the Build tools for Microsoft Visual Studio
CMake* 3.4 or higher
Python* 3.6.5 with the Python libraries, 64-bit
IMPORTANT: As part of this installation, make sure you click the option to add the application to your PATH environment variable.
Shubha_R_Intel
Pulkit are you behind a network proxy ? The only reason install_prerequisites.bat would time out is if network connectivity can't be  established.
Pulkit_J_Intel
Thanks for the tip. It seems it doesn't work inside Intel or at home with VPN.
At home without VPN it seems to work.
How do I disable the proxy to make it work at Intel office?
Pulkit
