Installing openvino raspberry pi 4
fpardo
I've been trying to install openvino in a raspberry pi 4 using several methods. The last one is that pointed in this link:
https://www.intel.com/content/www/us/en/support/articles/000057005/boards-and-kits.html
I use as host machine Ubuntu 20.04 and following the steps in the guide I always got the same error when I try to build the image:
I've looking in forums but I couldn't found a solution to this problem. Any suggestions? Thanks in advance.
Peh_Intel
Hi Fpardo,
I would strongly recommend you to install OpenVINO™ Runtime for Raspbian OS using OpenVINO Runtime archive file for Debian (l_openvino_toolkit_debian9_2022.3.1.9227.cf2c7da5689_armhf.tgz).
  1. Download and extract the archive file.
  2. Install required system dependencies on Linux by running install_openvino_dependencies.sh script.
  3. Set the Environment Variables by sourcing setupvars.sh script.
  4. Setup Intel® Neural Compute Stick 2 by follow the steps in Configurations for Intel® Neural Compute Stick 2.
Peh
fpardo
I tried that way but when I install openvino development tools:
pip install openvino-dev==2022.3.1
I get an error duting the process. I have tried with both 32/64 bits and bullseye/buster and none of the installation worked.
Thanks for your time.
Nando
Peh_Intel
Hi Nando,
Installing Intel® Distribution of OpenVINO™ Toolkit from PyPI Repository (pip install openvino-dev==2022.3.1) is only available for the following supported OS:
  • Ubuntu* 22.04 long-term support (LTS), 64 bit (Kernel 5.15+)
  • Ubuntu 20.04 LTS, 64 bit (Kernel 5.15+)
  • Ubuntu 18.04 LTS with limitations, 64 bit (Kernel 5.4+)
  • Windows® 10 and 11
  • macOS* 10.15 and later, 64 bit
  • Red Hat* Enterprise Linux* 8, 64 bit
Hence, we additionally provide OpenVINO™ Runtime archive file for Debian. Since, this package doesn’t include Model Optimizer/Model Downloader, the ideal scenario is to use another machine to convert your model with Model Optimizer, then do your application development on the Raspberry Pi for a convenient build/test cycle on the target platform.
For OpenVINO™ Toolkit Intel’s Pre-Trained Models, you can directly download them through the following link:
https://storage.openvinotoolkit.org/repositories/open_model_zoo/2022.3/models_bin/1
Peh
fpardo
Thanks for the information !!!
Fernando
Peh_Intel
Hi Fernando,
This thread will no longer be monitored since we have provided suggestion and answer. If you need any additional information from Intel, please submit a new question.
Peh
