6614 Discussions
Intel Movidius Myriad X Openvino Version and Support
jordimale
Hi!
I've been trying to run different models i had exported on onnx into my Myriad X. After doing all conversions, i get into the error:
Failed on MYRIAD: [ GENERAL_ERROR ]
/home/jenkins/agent/workspace/private-ci/ie/build-linux-ubuntu20/b/repos/openvino/src/plugins/intel_myriad/graph_transformer/src/frontend/frontend.cpp:596 Failed to compile layer "/GridSample": unsupported layer type "GridSample"
These raises multiple questions:
1. Which is the latest Openvino version that has Myriad X support? If not, are future versions going to support it? Im using 2022.3.2, as I read that this seems to be the last with Myriad X support
2. I see GridSample is supported on the Openvino documentation, but clearly my version does not support it.
3. Is there a better approach into running Deep Learning models into Myriad X? If not, what is the best solution on my problem?
Jordi
Wan_Intel
Hi jordimale,
For your information, OpenVINO™ 2022.3 LTS will be the last version of OpenVINO™ to support the Myriad plugin. OpenVINO™ 2023 and onwards will not support Myriad plugin.
Referring to the latest OpenVINO™ Operation Specifications, GridSample is supported by OpenVINO™ 2025. To check supported operation on OpenVINO™ plugins, please refer to Section - Device-operation conformance reports in OpenVINO™ Supported Operations.
On another note, you may use the following command to infer your model on several devices:
device = "HETERO:MYRIAD,CPU"
For more information, please refer to OpenVINO™ Heterogeneous Execution.
Wan
jordimale
Hi Wan,
Understood. This raises a couple of questions, just to confirm.
As you said, GridSample is supported by OpenVINO™ 2025. But, OpenVINO™ 2022.3 LTS will be the last version of OpenVINO™ to support the Myriad plugin. So, if I update to  OpenVINO™ 2025 to use GridSample I cannot run my model on my Miriad X. Is this correct?
The only option I have while working with Myriad X is to use OpenVINO™ 2022.3 LTS (currently using 2022.3.2), and run either on CPU or using the hetero option you commented. Is this correct?
Thanks again,
Jordi
Wan_Intel
Hi jordimale,
  1. Correct. OpenVINO™ 2025 does not support Myriad X. If you update to OpenVINO™ 2025, you may run the model with GridSample operation on CPU or GPU plugin.
  2. Correct. To use Myriad X, the only option is to use OpenVINO™ 2022.3 LTS. For unsupported operation on Myriad X, you may use CPU plugin or use the hetero option as a workaround.
Hope it helps.
Wan
Wan_Intel
Hi jordimale,
Thank you for your question.
This thread will no longer be monitored since we have provided suggestions. If you need additional information, please submit a new thread.
Wan
