Hello, I am using the openvino_2019.2.242 toolkit and trying to run a GAN exported from Keras to ONNX and then converted to IR on the Intel Neural Compute Stick 2. I am trying to run it using the benchmark_app, in both it's compiled and Python versions.
The model runs on the CPU, but fails when I try to run it on the NCS2 (using the -d MYRIAD option):
python benchmark_app.py -m /home/tzeny/Other/Projects/XVision/Benchmarks/BogdanKerasONNX/OpenVinoFP16/bogdan_onlyh5.xml -d MYRIAD
[Step 1/11] Parsing and validating input arguments
[Step 2/11] Loading Inference Engine
[ INFO ] InferenceEngine:
2.0.custom_releases/2019/R2_f5827d4773ebbe727c9acac5f007f7d94dd4be4e
[ INFO ] Device is MYRIAD
MYRIAD
myriadPlugin............ version 2.0
Build................... 27579
[Step 3/11] Read the Intermediate Representation of the network
[Step 4/11] Resizing network to match image sizes and given batch
[ INFO ] Network batch size: 1, precision MIXED
[Step 5/11] Configuring input of the model
[Step 6/11] Setting device configuration
[Step 7/11] Loading the model to the device
[Info ][VPU][MyriadPlugin] Device #0 MYRIAD-X (USB protocol) allocated
E: [xLink] [ 395328] [EventRead00Thr] handleIncomingEvent:267 handleIncomingEvent() Read failed (err -4)
E: [xLink] [ 395328] [Scheduler00Thr] dispatcherEventSend:923 Write failed (event) (err -4)
E: [xLink] [ 395328] [EventRead00Thr] dispatcherEventReceive:336 dispatcherEventReceive() Read failed (err -4) | event 0x7fc94e701e40 XLINK_WRITE_REQ
E: [xLink] [ 395328] [EventRead00Thr] eventReader:223 eventReader thread stopped (err -4)
E: [xLink] [ 395328] [python] XLinkReadDataWithTimeOut:1323 Event data is invalid
E: [ncAPI] [ 395328] [python] ncGraphAllocate:1911 Can't read input tensor descriptors of the graph, rc: X_LINK_ERROR
E: [watchdog] [ 395328] [WatchdogThread] sendPingMessage:120 Failed send ping message: X_LINK_ERROR
[ ERROR ] Failed to allocate graph: NC_ERROR
Traceback (most recent call last):
File "/opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/samples/python_samples/benchmark_app/benchmark/benchmark.py", line 193, in main
num_requests=args.number_infer_requests if args.number_infer_requests else 0)
File "ie_api.pyx", line 85, in openvino.inference_engine.ie_api.IECore.load_network
File "ie_api.pyx", line 92, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Failed to allocate graph: NC_ERROR
W: [ncAPI] [ 395342] [python] ncDeviceClose:1629 Failed to close stream, rc: X_LINK_ERROR
W: [ncAPI] [ 395342] [python] ncDeviceClose:1635 Failed to close stream, rc: X_LINK_ERROR
W: [ncAPI] [ 395342] [python] ncDeviceClose:1647 Failed to reset, rc: X_LINK_ERROR
I tried running another model (a basic densenet121) on the NCS2 and it worked. Do you have any idea what I'm doing wrong?
Hi Andrei,
Can you please upgrade to the latest version of the OpenVINO Toolkit 2019 R3 and try again?
Let me know if you have any further questions!
Sincerely,
Sahira
I have upgraded to openvino_2019.3.376, and I get this error:
./benchmark_app -m /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/./bogdan_onlyh5.xml -d MYRIAD [Step 1/11] Parsing and validating input arguments [ INFO ] Parsing input parameters [ WARNING ] -nstreams default value is determined automatically for a device. Although the automatic selection usually provides a reasonable performance,but it still may be non-optimal for some cases, for more information look at README. [Step 2/11] Loading Inference Engine [ INFO ] InferenceEngine: API version ............ 2.1 Build .................. custom_releases/2019/R3_ac8584cb714a697a12f1f30b7a3b78a5b9ac5e05 Description ....... API [ INFO ] Device info: MYRIAD myriadPlugin version ......... 2.1 Build ........... 32974 [Step 3/11] Reading the Intermediate Representation network [ INFO ] Loading network files [ INFO ] Read network took 36.00 ms [Step 4/11] Resizing network to match image sizes and given batch [ INFO ] Network batch size: 1, precision: MIXED [Step 5/11] Configuring input of the model [Step 6/11] Setting device configuration [Step 7/11] Loading the model to the device E: [global] [ 484330] [Scheduler00Thr] dispatcherEventSend:1013 Write failed -4 E: [xLink] [ 484331] [EventRead00Thr] eventReader:218 eventReader thread stopped (err -4) E: [global] [ 484331] [Scheduler00Thr] dispatcherEventSend:1004 Write failed (header) (err -4) | event XLINK_WRITE_RESP E: [xLink] [ 484331] [Scheduler00Thr] eventSchedulerRun:626 Event sending failed E: [xLink] [ 484331] [Scheduler00Thr] eventSchedulerRun:576 Dispatcher received NULL event! E: [global] [ 484331] [benchmark_app] XLinkReadDataWithTimeOut:1494 Event data is invalid E: [ncAPI] [ 484331] [benchmark_app] ncGraphAllocate:1947 Can't read output tensor descriptors of the graph, rc: X_LINK_ERROR E: [watchdog] [ 484331] [WatchdogThread] sendPingMessage:121 Failed send ping message: X_LINK_ERROR W: [ncAPI] [ 484340] [benchmark_app] ncDeviceClose:1662 Failed to close stream, rc: X_LINK_ERROR W: [ncAPI] [ 484340] [benchmark_app] ncDeviceClose:1666 Failed to close stream, rc: X_LINK_ERROR W: [ncAPI] [ 484340] [benchmark_app] ncDeviceClose:1678 Failed to reset, rc: X_LINK_ERROR E: [ncAPI] [ 494340] [benchmark_app] ncDeviceClose:1737 Device didn't appear after reboot [ ERROR ] Failed to allocate graph: NC_ERROR
Running the model on the CPU (./benchmark_app -m /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/./bogdan_onlyh5.xml -d CPU) works.
Running a DesneNet121 exported form PyTorch on the NCS2 works.
Hi Andrei,
Can you please provide your model so I can run it on my end? If you'd like to send it over a PM, please let me know and I will message you.
Sincerely,
Sahira
Sadly the model I am working with is private Intelectual Property, belonging to the company I work for so I cannot send it to you. If you have any other suggestions I would be happy to try them :).
Thank you,
Andrei
Hi Andrei,
I understand. Can you please try upgrading OpenVINO to the latest version and try again?
Since your model runs on the CPU but not on the NCS2, there might be an issue when converting from Keras, or when converting from ONNX to IR. Can you please provide the command you used to convert your model to IR to run on the NCS2?
Sahira
Hello Sahira,
I am using the latest vesion (openvino_2019.3.376), this is the command I used:
python3 mo.py --input_model ~/ONNX/bogdan_onlyh5.onnx --input_shape "[1,1024,1024,1]" --data_type=FP16
Thank you for your help,
Andrei
Hi Andrei,
Since this was a custom trained model, it could be possible that it is not supported on Myriad, which is probably why it runs on the CPU but not on the NCS2. Can you give me some more information about your model:
- What base model was used for training?
- What Framework & Topology is the model?
Sincerely,
Sahira
