6594 Discussions
Issue when using two IP cameras with OpenVINO OMZ Demo
DarkHorse
My customer is trying out this demo by using 2 IP cameras.
https://docs.openvinotoolkit.org/2021.3/omz_demos_multi_channel_face_detection_demo_cpp.html
When they are using 1 IP Camera it worked perfectly but when 2 IP cameras it came out with errors as attached.
Command line as below:
-i rtsp://admin:gamma@172.18.70.113:8554/CH001.sdp/ rtsp://admin:admin@172.18.70.125:8554/CH001.sdp/
Any idea?
Thanks,.
Vladimir_Dudnik
I see error message on your screenshot: 404 stream not found. Is there streaming going on this rtsp connections?
DarkHorse
Hello @Vladimir_Dudnik
Yes the streaming is ongoing with RSTP connections.
We did tried a few scenario:
1) Command: multi_channel_face_detection_demo.exe -i rtsp://admin:gamma@172.18.70.113:8554/CH001.sdp/ rtsp://admin:admin@172.18.70.125:8554/CH001.sdp/ -m face-detection-retail-0004.xml
Result: Only show Inference on rtsp://admin:gamma@172.18.70.113:8554/CH001.sdp/
2) Command (Adding comma in between the rstp input):
multi_channel_face_detection_demo.exe -i rtsp://admin:gamma@172.18.70.113:8554/CH001.sdp/, rtsp://admin:admin@172.18.70.125:8554/CH001.sdp/ -m face-detection-retail-0004.xml
Seems like the OMZ Demo is unable to run Inference on the 2nd RSTP input.
Any idea?
Wan_Intel
Hi DarkHorse,
I encountered the same error method DESCRIBE failed: 404 Not Found as your customer did when I run Multi-Channel Face Detection C++ Demo with your command:
multi_channel_face_detection_demo.exe -m "<path_to_xml_file>\face-detection-adas-0001.xml" -i rtsp://camera_address_1/ rtsp://camera_address_2/
On another note, I successfully run the Multi-Channel Face Detection C++ Demo by using a comma instead of a space to seperate two IP camera address. The command is:
multi_channel_face_detection_demo.exe -m "<path_to_xml_file>\face-detection-adas-0001.xml" -i rtsp://camera_address_1,rtsp://camera_address_2
Wan
DarkHorse
Hello @Wan_Intel ,
Thanks, we managed to get it run also on the following command:
multi_channel_face_detection_demo.exe -m "<path_to_xml_file>\face-detection-adas-0001.xml" -i "rtsp://camera_address_1,rtsp://camera_address_2"
I guess the openvino documentation need to be updated..
https://docs.openvinotoolkit.org/latest/omz_demos_multi_channel_face_detection_demo_cpp.html
Vladimir_Dudnik
@DarkHorse sure, we will update demo documentation for the nearest release
  Vladimir
Vladimir_Dudnik
@DarkHorse just to note, we have corrected documentation for C++ multi-channel demos, you may review changes in pull-request on github .
Wan_Intel
Hi Allen Seng Hung Wong,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Wan
