KEY_CPU_THREADS_NUM in Python API
levchik__anatoly
I'm trying to set KEY_CPU_THREADS_NUM for Python API.
For this fragment:
plugin = IEPlugin(device='CPU')
exec_net = plugin.load(network=net, config={
    'KEY_CPU_THREADS_NUM': '1',
i'm getting:
  File "ie_api.pyx", line 85, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 92, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: [NOT_FOUND] Unsupported property KEY_CPU_THREADS_NUM by CPU plugin
Same error i'm getting for:
ie = IECore()
exec_net = ie.load_network(network=net, device_name='CPU', config={
How set custom KEY_CPU_THREADS_NUM for python api? Maybe not with python but with env vars?
JesusE_Intel
Hi Anatoly,
Could you try using the set_config function from the IECore to specify the CPU_THREADS_NUM? I ran the Hello_Query_Device sample to see available configuration parameters and it looks like the parameter name has changed from KEY_CPU_THREADS_NUM to CPU_THREADS_NUM.
Use this code snip to set the parameter and display the parameter value.
ie.set_config({"CPU_THREADS_NUM" : "1"}, "CPU")
print(ie.get_config("CPU", "CPU_THREADS_NUM"))
Please let me know if this answers your question.
Jesus
