Labels for class ID
JVond
New to the compute stick. I've been using the google coral and jetson nano.
I was running the alexnet and googlenet caffe model and got outputs with no labels. Is there a list somewhere or a way to input labels?
googlenet
classid probability
616  0.4355762
50   0.1069827
836  0.0557207
36   0.0534245
429  0.0518655
494  0.0363212
452  0.0321387
544  0.0257031
600  0.0205605
772  0.0144706
alexnet
classid probability
88   0.9810570
12   0.0157526
7   0.0009286
90   0.0009172
14   0.0005626
136  0.0002139
92   0.0001659
129  0.0001552
91   0.0000463
17   0.0000393
Aroop_B_Intel
Hello JVond,
GoogLeNet v1 was trained on ILSVRC2012 sysnset_words.txt from http://dl.caffe.berkeleyvision.org/caffe_ilsvrc12.tar.gz . You can rename the synset_words.txt file to "googlenet-v1.labels" and move it to the same directory as your GoogLeNet model.
Alexnet was trained on Imagenet so the same label file as above should work.
Please give it a try and let me know if you have any additional questions.
Aroop
Aroop_B_Intel
Hello JVond,
Aroop
JVond
I put the file in the folder with the Alexnet.xml file... still just displays the number. Is there a tag to make it use the label file or what is the file that alexnet uses that needs to be replaced?
Aroop_B_Intel
Hi JVond,
Depending on the sample that you are using, you can specify the labels file with "--labels". You can also rename the labels file to match your .xml file and place it in the same directory.
For example: The corresponding label file for "example.xml" would be "example.labels".
Aroop
JVond
That worked...now i'm noticing a new issue. It looks like it is one off. I am using the sample image and imagenet labels from the google coral. It is identifying (with 99%) certainty that it is 88 (african grey) when it is clearly 89 (macaw). Do you have a link to a fresh imagenet labels file so I can see if it somehow differs in your models?
JVond
Why don't the labels come with the models or be available for download on github?
Aroop_B_Intel
Where did you download Alexnet from? Could you share a link? I am downloading the Alexnet model from the Open Model Zoo using the model downloader and it categorizes a macaw correctly with classid 88.
Aroop
JVond
I downloaded it the same as you from the openzoo downloader. And yes, it comes up correct as "88". What I'm telling you is the labels file I used from my google coral has the macaw as 89. So the files are off by one.
What i'm asking is why intel doesn't provide copies of the labels to prevent confusion and issues like this?
Aroop_B_Intel
I understand how this can be confusing. However, I am unsure why the developers chose not to include the label files with the models. I will definitely provide your feedback to the appropriate team.
Aroop
